Modelism - RHC Forum: Vand senzor optical flow si Lidar Matek - Modelism - RHC Forum
Vand senzor optical flow si Lidar Matek Matek OPTICAL FLOW & LIDAR SENSOR 3901-L0X
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 18 February 2020 - 12:52 PM
Vand Matek optical flow si lidar sensor, contine o mica camera care scaneaza solul pentru positionare foarte precisa fara GPS, in plus are si senzor de inaltime laser precis. Bun pentru position si altitudine hold fara GPS sau busola si chiar si inauntru, se poate monta si pe drone foarte mici folosind doar un port UART serial.
-Specifications
Optical Flow: PMW3901
Lidar: VL53L0X
Interface UART
Protocol: INAV MSP
Working Range: 8cm~200cm
Field of view: 42 degree(PMW3901), 27 degree(VL53L0X)
Minimum Illumination >60Lux
Input voltage: 4.5~5.5V
Power Consumption: 40mA
-Tips
Make sure Optical Flow lens to ground >2cm for opflow initialization while FC starting up.
Maximum range of VL53L0X is 2m, Altitude hold 0~2m @ throttle 0~100% if VL53L0X is enabled.
Any unused UART of FC supports it
Sonar connection (Trig & Echo) has not been implemented
Pret: 130lei
Tel: 0749 121 132
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 12 March 2020 - 11:43 AM
UP 120lei
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 23 March 2020 - 03:16 PM
up
Andrei
#4 Useril este offline   andrewbt
  • Postari: 1014
Postat 01 April 2020 - 11:20 AM
up, bun pentru drone mici indoor sa fie stabile.
Andrei
#5 Useril este offline   andrewbt
  • Postari: 1014
Postat 15 May 2020 - 08:21 AM
up
Andrei
