Se vinde asa cum se vede in poza: unitatea centrala, gyro, senzor CCD si cablul de date.
Pret: 180 lei, transport cu curier rapid, inclus in pret.
Contact pe e-mail sau la telefon: 0723243678
Mai multe detalii,despre sitem gasiti pe:
https://www.kdsmodel...p/2007a11-5.htm
si un ghid de instalare/ utiizare:
http://shop.textalk....tting_guide.pdf
Si cate detalii tehnice:
Flymentor 3D is a stabilization unit that helps the helicopter to self-stabilize in hover and also self recovery during 3D manuever.
Features:
>Control all movement, including attitude stabilization, speed control, position locking.
>CCO sensor to capture picture of ground, comparing pictures to avoid drifting.
>Switch working mode (horizontal mode and position mode) through AUX channel.
>Integrating head locking gyro and swash plate mixer.
>Control sensitivity and mode of internal gyro through GEAR channel.
>Support swash plate 3S 120°, 3S 140°, 4S 90°, 4S 90°+45°
>Keep balance in inverted flight.
>Configured by computer through USB.
>If you are using FM/PPM remote control device, when helicopter is out of control, the Flymentor 3D will set aileron, elevator, rudder to neutral, and keep pitch in the final signal position, and switch to positioning mode automatically, the sensitivity is 70%.
Specification:
Voltage: 4.8-6.0V
Current: 55mA (under 5V)
Weight:37g
Temperature: O'C~ +40'C
Under the stabilisation mode and positioning mode, maximum rotate speed allowed:
Aileron and Elevator: ,;2000 / s
Tail turning (if using external gyro): ,;3600 / s
Aceasta postare a fost editata de Virgil: 23 May 2019 - 10:09 AM
Acest topic e inchis
