Modelism - RHC Forum: Vand FC Omnibus F4 OSD BEC, Modul GPS M8N cu busola, Camera AIO cu VTX - Modelism - RHC Forum
Vand FC Omnibus F4 OSD BEC, Modul GPS M8N cu busola, Camera AIO cu VTX Omnibus F4 Nano, GPS M8N cu busola, Camera FPV cu 5.8GHz VTX
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 16 January 2019 - 04:53 PM
=>FC Omnibus F4 Nano 20x20mm cu BEC 5V, OSD si blackbox. =>70lei
Specification:
Item name: Omnibus F4 Nano
Mounting hole: 20*20mm
Weight: 3.3g
Processor: STM32F405RGT6
Sensor: MPU-6000 (connected by SPI)
Firmware version: betaflight_3.0.1_OMNIBUSF4
Built-in BEC: 5V/1A
Power supply: 2-4S lipo battery
Features:
-PPM/SBUS/DSM2/DSMX input
-LED_STRIP solder pin
-Buzzer solder pin
-With LC filter
-With 128Mb flash (16M type)
-Built-in OSD (Using F4 MCU controls OSD over SPI bus in DMS mode)
-Built-in voltage detection, alarm
-Support the newest DSHOT ESC
-Support programmable LEDSD (turn off transponder before using)
-Support BLheli suite
=>Modul GPS M8N cu busola I2C, model performant cu antena mare. =>90lei
Description:
Weight: 20g
Positional accuracy: 50 centimeter precision when working with concurrent GNSS
Velocity precision: 0.1m/s
Max height: 50000m
Max speed: 515m/s
Max acceleration: 4G
Max update rate: up to 10Hz
Sensitivity:
Tracking & Nav.: -167dBm, Reacquisition: -163dBm
Cold start: -151dBm, Hot start: -159dBm
Time to first fix: Cold start: 26s, Hot start: 1s
Connect ports:
Power supply: voltage 5VDC+-5%, current 50~55mA
Ports:
A. GPS UART interface
baud rate: 1.2K/4.8K/9.6K/19.2K/38.4K/57.6K/112.5K
B. Geomagnetic I2C interface
Top configuration:
GPS decoder chip: Radiolink M8N GPS, with u-blox UBX-M8030(M8), 72-channel, is much better than single GNSS 7N.
Geomagnetic: QMC5883L which with same technology as HMC5983 form Honeywell
Antenna: 2.5dbI high gain and selectivity ceramic antenna
Double filter: SAWF(Surface acoustic wave filter) form Murata
=>Mini camera FPV 5.8GHz 25mW 48CH VTX NTSC/PAL 600TVL, noua la cutie. =>80lei
Features:
• Nano sized camera/transmitter
• Simple installation
• 600TVL camera
• 48 Channel transmitter
• Integrated whip antenna
• 120° Field of view
• Image inverting
Specs:
Frequency: 5362~5945 MHz
Output: 25mW
Supply Voltage: 2.9~5.5v
Power consumption: 200~215mA
Channels: 48
Modulation: FM
Channel Indicate: LED
Format: NTSC/PAL
Sensor: PAL 720 X 540/NTSC 640 X 480 1/4"
FOV: Horizontal 120°/Vertical 100°
Operating Temperature: -10~60℃
Dimensions: 14.5 X 12.2 X 12mm
Weight: 3.35g
Tel:0749 121 132
Aceasta postare a fost editata de andrewbt: 16 January 2019 - 04:55 PM
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 28 January 2019 - 10:36 AM
UP
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 12 February 2019 - 02:37 PM
UP
=>Mini camera FPV 5.8GHz 25mW 48CH VTX NTSC/PAL 600TVL, noua la cutie. =>70lei
Features:
• 600TVL camera
• Image inverting
Specs:
Output: 25mW
Channels: 48
Modulation: FM
Format: NTSC/PAL
Weight: 3.35g
Andrei
#4 Useril este offline   andrewbt
  • Postari: 1014
Postat 19 February 2019 - 09:15 AM
UP
Andrei
#5 Useril este offline   andrewbt
  • Postari: 1014
Postat 26 February 2019 - 03:45 PM
UP
Andrei
