Modelism - RHC Forum: Vand Holybro Kakute F4 V2 Flight Controller - Modelism - RHC Forum
Vand Holybro Kakute F4 V2 Flight Controller Holybro Kakute F4 V2 OSD Baro 5UART
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 23 July 2018 - 10:00 AM
Vand flight controller Holybro Kakute F4 V2, la cutie cu toate accesoriile in stare perfecta, vine cu 5 porturi seriale HW, Barometru, 32khz Gyro soft mount, conector pt ESC 4in1 sau dedicate, etc.
Specification:
MCU: STM32F405RGT6 32-bit processor
IMU: ICM20689 (SPI)
Barometer: BMP280
USB VCP Driver (all UARTs usable simultaneously; USB does not take up a UART)
5 hardware UARTS (UART1,3,4, 5, 6)
Supports serial receivers (SBUS, iBus, Spektrum, Crossfire) only. PPM and PWM receivers are not supported.
128 Mbit Dataflash chip for Blackbox logging
Dimensions: 35x30x8mm (includes USB in height)
Mounting Holes: Standard 30.5mm square to center of holes
Weight: 7g
New V2 Features:
-Additional UART (UART 4) added to support serial camera communication such as to RunCam Split. Please note this is NOT
the same as Betaflight Camera Control feature, which controls the menu of FPV cameras like Swift, etc.
-Additional UART (UART 5) added to support ESC telemetry such as from BLHeli_32 and KISS.
-Through-hole solder pads instead of flat pads for more secure soldering especially for beginners.
-Barometer sensor on board allows altitude hold mode.
-I2C pad available for certain external sensors.
Features:
-Supports Betaflight and Cleanflight.
-Betaflight OSD. Change PIDs, adjust common configuration parameters, and change video transmitter channel and power level,
all using your transmitter sticks and goggles.
-Soft-mounting built in. The IMU (“gyro”) chip on this board is mounted on vibration-isolating foam. This means that there is no need
to soft-mount the board itself.
-New high-performance / low-noise / high sensitivity IMU. ICM20689 with 6-axis gyro and accelerometer. Can run at up to 32 kHz.
-2 oz. copper PCB allows up to 120A maximum continuous current.
-Dedicated bootloader button for easy firmware flashing.
-Low-profile design fits into even very compact frames.
-Input voltage 7v to 42v. Power the board directly from the flight pack, up to 6S (on “B+” pad only).
-Automatic voltage monitoring. No need to run a separate vBat wire for voltage monitoring; the Kakute F4 AIO monitors voltage
directly from the battery power lead.
-Filtered voltage output for clean, noise-free video. On-board regulators output 5v at up to 1.5 amps and 3.3v at up to 200 mA to power
peripherals such as receiver, video transmitter, FPV camera, or LED strip.
-Supports BLHeli pass-through for easy ESC upgrade and configuration.
Pret: 125lei
Tel: 0749 121 132
  • Fisier atasat  f4.jpg (262.61K)
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 30 July 2018 - 08:27 AM
up 120lei
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 03 August 2018 - 02:18 PM
vandut
Andrei
