Suporta si baterii Li-HV, masoara si Rezistenta Interna a celulelor, conexiune USB si soft de configurare, are si port pentru sensor de temperatura pentru celule, etc.
Features:
• Microprocessor controlled
• Individual cell balancing
• LiHV, Li-ion, LiPoly and LiFe capable
• Ni-Cd and NiMH capable
• Delta-peak sensitivity (NiMH/NiCd)
• Lead Acid capable
• Large range of charge currents
• Terminal Voltage Control (TVC)
• Lipo Battery Meter
• Battery Internal Resistance Meter
• Store function, allows safe storage current
• Time limit function
• Temerature Cut-off (20-80 degree Celcius/68-176 Fahrenheit)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 10 packs in memory)
• Battery break in and cycling. (1-5 cycles)
Specs:
Input Voltage: 11~18v
Circuit Power: Max Charge: 80W / Max Discharge: 10W
Charge Current Range: .1~10.0A
Balance Cells: 2-6 cells
NiMH/NiCd Cells: 1~15
LiHVLiIon/LiPoly Cells: 1~6
Pb battery Voltage: 2~20v
Weight: 270g
This charger has a JST-XH charge plug, which makes it compatible with Zippy, HXT, TURNIGY and any pack with a JST-XH adapter.
Includes:
1. Accucell 6 80W Charger
2. XT60 with Banana connector Charging Cable (430mm)
3. XT60 with Banana connector Charging Cable (300mm)
4. XT60 with Alligator Clip Charging Cable
Pret: 120lei
=>Vand senzori de temperatura externi, se pun pe celule in timpul incarcarii ca chargerul sa detecteze daca se incalzesc prea tare celulele, compatibili cu incarcatoare Turnigy Accucel sau Imax B6, clone, etc.
Features:
• This temperature sensor support Accucel series/MEGA series/Quattro/IMAX B6 charger
• Velcro tape included for easy secure the sensor on different battery
Specs:
Wire length: 440mm
Velcro tape length: 22mm
Pret:15lei/buc
Tel: 0749 121 132
Number of downloads: 79 -
