Nu a zburat nicio data, nu are nici-o piesa electronica conectata(lipita)!
Este cumparat din Germania, adus si construit de mine personal pana la punctul la care este construit. Am documentat constructia intr-un time lapse si o pun la dispozitie in intregime cumparatorului. Fotografiile din constructie sunt fotograme din timelapse. L-am contruit cu spirit de raspundere si folosind cele mai bune materiale pentru ca l-am construit pentru mine. Acum sunt obligat sa il vand deoarece trebuie sa finantez altceva si elecopterul nu mai reprezinta o prioritate.
Kitul contine (asa cum arata si bonurile):
1. | KIT | Align KX018E06 T-REX 700E F3C Super Combo RC Model Heli
/Link: http://www.shop-rc-m.../align/kx018e06
_ Kit de competitie
_ Specifications:
- Length: 1343mm
- Height: 424mm
- Width: 210mm
- Main Blade Length: 700mm
- Main Rotor Diameter: 1582mm
- Tail Rotor Diameter: 281mm
- Motor Drive Gear:12T
- Main Drive Gear:112T
- Autorotation Tail Drive Gear: 104T
- Tail Drive Gear: 24T
- Drive Gear Ratio: 1:9.33:4.33
- Weight(With Motor): 3230g
- Flying Weight: Approx. 5200g
_ Accessories:
-T-REX 700E F3C Kits Set X1
-Aluminum Tail Boom X1
-3K Carbon Fiber Tail Boom X1
-F3C 700mm Carbon fiber blades X1
-DS610 Digital servoX3 set
-DS650 Digital servo X1
-GP780 Head Lock Gyro X1
-700MX Brushless Motor(470KV) X1
-Castle ICE HV 120 Brushless ESC X1
-6A External BEC w/ 5.1V Two-way Step-down voltage regulator X1
-105mm 3K Carbon Fiber Tail Blades X1 Set
2. | Telecomanda + Receiver + Baterie NiMH 2700Ah | Futaba 10CG (FF10) 2.4G 10ch Transmitter & R6014HS 14ch High Speed Receiver Combo
/Link: http://www.goodluckbuy.com/futaba-10cg-t10cg-2-4-ghz-fasst-transmitter--r6208sb-receiver-tx-rx-radio-set.html
_ Este o telecomanda ideala din toate punctele de vedere. Beneficiaza de toate tehnologiile de ultima ganeratie, este ultra configurabila si are un numar remarcabil de canale.
3. | Simulator + Adaptor pentru telecomanda FUTABA 10CG | Phoenix RC
/Link: https://www.horizonh...odNr=094RTM5500
/Link: http://www.rc711.com/shop/futaba-10cg-ff10-24g-10ch-transmitter-r6014hs-14ch-high-speed-receiver-combo-p-1610.html
_ Simulatorul care se leaga direct la telecomanda cu care se comanda elicpoterul real. Este metoda ideala de a invata. Este, dupa parerea mea, cel mai realist simulator RC. Versiunea de pe CD este 3 dar dupa instalare face update automat la 5.5.
4. | Incarcator/Balancer | Intelli-BiPower special, Akku-Ladegerät und Balancer, 12V und 220V, 6 Lipo, 6 A
/Link: https://www.hoelleinshop.com/Alles-fuer-den-Elektroflug/Lader-und-Netzteile/Ladegeraete-12V-und-230V/Simprop/Intelli-BiPower-special-Akku-Ladegeraet-und-Balancer-12V-und-220V-6-Lipo-6-A.htm?shop=hoellein&a=article&ProdNr=S0100986&t=49302&c=25704&p=25704
_ Incarca, descarca si balanseaza foarte multe tipuri de baterii. NiCd/NiMH, LiPo/LiIo/LiFe, Acid. Se foloseste pentru a incarca toate bateriile din kit.
5. | Baterii x 2 | Li-Polar 22,2V 6S1P 5800mAh 30C
/Link(nu mai face parte din oferta): https://www.freakwar...0020-a48446.htm
_ Capacitatea cea mai mare ceea ce inseamna mai mult timp in aer.
6. | Pale de rezerva | 700 F3C Carbon Rotorblätter
/Link: https://www.freakwar...pos=a18-2687007
7. | Boom coada de rezerva |
8. | Pitch Gauge si toate accesoriile necesare pentru zbor |
Manual TREX:
http://www.align.com...er/KX018E06.pdf
PRET 8800RON negociabil.
Telefon 0724002777
Mai multe fotografii la calitate buna: http://s.go.ro/paakbjm8
