De vanzare kit ImpulseRc Helix 2018 5 inch sigilat.
Pachetul contine:
1. frame complet 5” carbon ImpulseRc Helix 2018
2.Flight controller(FC) + PDB
3.Transmitter video(VTX)+ OSD ImpulseRC
4.2 LED Strips(benzi LED)
Pachetul vine cu toate accesoriile necesare (cabluri, mufe, suruburi, suport camera si vtx).
Pret: 110€ Negociabil.
Contact: 0751868239
Se poate preda personal in Cluj-Napoca sau trimitere cu curier cu verificare colet.
Pentru poze va rog sa ma contactati pt a le trimite pe email, whatsapp sau facebook.
Toate componentele sunt noi, sigilate.
SPECIFICATIONS
Helix Frame -
• Fully chamfered, high quality carbon fiber frame
• Grade 12.9 high tensile alloy steel and 7075 black anodised aluminium hardware
• 30, 45 and 60 degree FPV camera plates
• 45 degree HD camera plates
• Custom machined antenna clamps
• Injection molded ESC fairings
• High grade natural rubber Lipo pad
• Self adhesive foam-rubber isolation pad for the flight controller
• Set of diamond files
• Nylon 6 antenna tubes
• 45 degree SMA adapter
Flight Controller
• Integrated high current PDB
• STM32F3 based flight controller
• SPI based low noise MPU6000 gyro
• Up to 40V input BEC - 6S capable, no extra filtering
• PPM, SBUS, Spektrum, Serial rx receiver input
• Filtered RSSI input
• Hardware UART telemetry output
• 128Mbit Blackbox flash
• Reinforced USB connector
• Dual mirrored LED strip outputs
• Tactile boot button
• Integrated voltage monitoring
Video Transmitter
• Integrated OSD
• Integrated microphone
• 40 Channels
• 25/200/500mW switchable output power
• Power and channels selectable via OSD
• Cascaded switching and linear regulators for ultra clean power
• Rock solid 5V camera output
• Hardware jumper for removing power to module
Kit ImpulseRC Helix Frame + pdb + vtx + accesorii
Postat 10 January 2018 - 12:44 PM
"If you can't explain it simply, you don't understand it well enough."-Albert Einstein
