Modelism - RHC Forum: vand motor rc smart 1600kv - Modelism - RHC Forum
#1 Useril este offline   as2008
  • Postari: 733
  • Inregistrat: 04-May 10
Postat 21 October 2016 - 07:16 AM
vand motor rc smart , in stare de functionare , 1600kv , Rotational Speed: 1600 RPM/V
Continuous Current: 45A
Max. Current: 55A
Input Voltage: 8 - 24V
Max. Efficiency: 96%
No Load Current: 1.1A
Internal Resistance: 42m ohm
Motor Dimensions (Diameter x Length): 36.5mm x 52.2mm
Shaft Dimensions (Diameter x Length): 3.97 x 18mm
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Recommend Model: Helicopter / Airplane
Package Included
#2 Useril este offline   as2008
  • Postari: 733
Postat 21 October 2016 - 07:18 AM
Vezi postareaas2008, la 21 October 2016 - 07:16 AM, a spus:
Max. Current: 55A
Package Included
Fisier atasat  IMG_20160729_121346.jpg (378.11K)
Number of downloads: 117pret 100 lei
#3 Useril este offline   hype
  • Postari: 1283
  • Inregistrat: 05-February 11
Postat 30 October 2016 - 09:44 AM
Vezi postareaas2008, la 21 October 2016 - 07:18 AM, a spus:
Cat poate trage?
#4 Useril este offline   as2008
  • Postari: 733
Postat 30 October 2016 - 01:55 PM
Vezi postareahype, la 30 October 2016 - 09:44 AM, a spus:
Cat poate trage?
buna ziua , a fost folosit pe o salupa de viteza 60-80 km , am mai dat 1 buc si este folosit pentru un elicopter clasa 600 , deci probabil sa zic 2-3 kg , stima
#5 Useril este offline   as2008
  • Postari: 733
Postat 09 December 2016 - 09:37 PM
Vezi postareaas2008, la 30 October 2016 - 01:55 PM, a spus:
pret nou 85 lei
#6 Useril este offline   as2008
  • Postari: 733
Postat 05 March 2017 - 08:29 AM
Vezi postareaas2008, la 09 December 2016 - 09:37 PM, a spus:
pret nou 85 lei
valabil
#7 Useril este offline   hype
  • Postari: 1283
Postat 22 April 2017 - 09:17 PM
pret nou 85 lei
Salut. Ce greutate,are?
Vreau sa-l folosesc pe un polaris. Daca se incadreaza,batem palma. Mentionez,polaris,decoleaza de pe iarba,apa,zapada,de aceea ma intereseaza greutatea. In eventualitatea unui regulator,ptr. el,sunt dispus. Sa auzim de bine.
#8 Useril este offline   as2008
  • Postari: 733
Postat 22 April 2017 - 10:20 PM
Vezi postareahype, la 22 April 2017 - 09:17 PM, a spus:
buna seara , are cam 170 gr,, stima
#9 Useril este offline   as2008
  • Postari: 733
Postat 22 April 2017 - 10:23 PM
Vezi postareaas2008, la 22 April 2017 - 10:20 PM, a spus:
http://www.rcecho.co...less-Motor.html
#10 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 22 April 2017 - 10:55 PM
50=80km/h? 2 kg?
macar nu mai scrieti. :)))
Laser frate!
#11 Useril este offline   hype
  • Postari: 1283
Postat 23 April 2017 - 08:41 AM
Vezi postareafulgerica, la 22 April 2017 - 10:55 PM, a spus:
50=80km/h? 2 kg?
Salut. Modelul meu,gata de zbor are 760g. La proba pe apa,fara vant,este la limita decolarii. Lansat din mana,este ok.o idee cam puturos. Daca la greutatea actuala mai adaug cca.40g.la 1600 rpm/v cu o elice 8x6 preferabil tripala,cred ca obtin decolarea in toate conditiile.
0764485822 un beep, stabilim detaliile. Respect.
#12 Useril este offline   hype
  • Postari: 1283
Postat 26 April 2017 - 09:27 PM
A ajuns la mine,totul este ok.Multumesc.
