Mach3 setari, probleme, pareri, discutii...
Postat 26 February 2017 - 09:45 PM
"10.1.16 Path Control Modes
The machining system may be put into any one of two path control modes: (1) exact stop
mode, (2) constant velocity mode. In exact stop mode, the machine stops briefly at the end
of each programmed move. In constant velocity mode, sharp corners of the path may be
rounded slightly so that the feed rate may be kept up. These modes are to allow the user to
control the compromise involved in turning corners because a real machine has a finite
acceleration due to the inertia of its mechanism.
Exact stop does what it says. The machine will come to rest at each change of direction and
the tool will therefore precisely follow the commanded path.
Constant velocity will overlap acceleration in the new direction with deceleration in the
current one in order to keep the commanded feedrate. This implies a rounding of any corner
but faster and smoother cutting. This is particularly important in routing and plasma cutting."
OK, inteleg ca s-a facut un compromis din cauza ca nu poti schimba directia de miscare instant, la viteze mari, din motive de inertie.
Ce nu inteleg este cum poate rezolva un CONTROLER aceasta problema, a.i. sa pastreze viteza si sa nu "altereze piesa"... poate explica cineva, teoretic si simplificat... :).
... niste lucrari :)
Postat 26 February 2017 - 10:47 PM
Acceleratia trebuie sa o ai atat de mare setata, incat sa ajungi la viteza propusa in cateva fractiuni de secunda. Sa zicem ca la limita te intinzi la o jumate de secunda, dar nu spre secunde intregi. Nu merge chiar procentual cum ziceam mai devreme, dar daca iti stii masina stii care-i acceleratia maxima pe care o suporta pe fiecare axa. Cum ziceam, la mine, cu materiale slabute, merg pe un oarecare 30% din valoarea vitezei, asa cum se declara in mach. Doar ca eu am motoare de imprimanta la CNC. Dar in mod normal, mecanica si actionarea trebuie sa suporte acceleratii mari. In nici un film de pe net nu o sa observam la ochi perioada de accelerare sau franare in timpul prelucrarilor. Ele sunt la locul lor acolo. De multe ori nici nu se atinge valoarea setata pentru viteza ca segmentul prelucrat fiind scurt, nu ne incadram cu cei trei timpi in el, pentru viteza dorita.
Aceasta postare a fost editata de bitex: 26 February 2017 - 10:48 PM
Postat 26 February 2017 - 10:54 PM
Si nu asta face Mach3 cu "exact stop"?
Ce nu mi-e clar este cum face "concurenta" de o face mai bine si mai repede si din miscare? :)
Postat 26 February 2017 - 11:01 PM
Am facut modificarea in soft, chiar pe dreptunghiul ala si ai dreptate, rotunjeste coltul.
Cu constant velocity, daca nu ai setata acceleratia corect, iti rotunjeste coltul. Si asta face de cele mai multe ori, necontrolat. Ar trebui sa mergi cu exact stop si poti folosi ce valori vrei.
Dar setarea asta nu te avantajeaza la arcurile de cerc facute din segmente scurte, ca se va opri freza la fiecare capat de segment. Adica obtii pozitia exacta, dar si suprafata poligonala. Aici e treaba de CAM, si fiecare arc sa fie facut cu interpolare circulara. Da-i treaba de finete, in functie de cum selectezi curbele.
Eu zic sa ramai cu viteza constanta, sa reduci viteza ca oricum nu o atingi niciodata si sa maresti acceleratia. Fiecare colt o sa fie exact ca in desen. Ma rog, nesesizabil la mana.
Postat 26 February 2017 - 11:07 PM
bitex, la 26 February 2017 - 11:01 PM, a spus:
bitex, tu mie mi-ai raspuns? :) Io n-am nici o problema, la mine colturile is OK... da ` nah, o sa iau o lupa mai mare data viitoare. :)
Io eram doar curios cum la unii exista inertie iar la altii nu... .
:drinks:
Postat 26 February 2017 - 11:08 PM
informer, la 26 February 2017 - 10:54 PM, a spus:
Asta o face CAM.ul si partial Mach-ul.
Cand virezi brusc la dreapta, de fapt conturul piesei vireaza brusc la dreapta. Axa de rotatie a sculei (implicit scula) urmeaza un arc de cerc, de 90 grade. Nu trebuie sa te opresti complet inainte de colt. Trebuie sa intri corect in acea traiectorie curba si sa iesi din ea, fara mari diferente intre cele doua forme geometrice.
Si asta se face bine cand sunt acceleratii foarte mari, astfel incat timpii de oprire si pornire pe noua traiectorie sa nu conteze. Zecimi sau chiar mai putin, de secunde.
PS. Am incercat sa-i raspund lui mincof, dar se cam amesteca mesajele. Nu-i problema, ne descurcam. Luam din ce gasim ce se potriveste...
Scuze de confuzie.
Aceasta postare a fost editata de bitex: 26 February 2017 - 11:09 PM
Postat 26 February 2017 - 11:21 PM
bitex, la 26 February 2017 - 11:08 PM, a spus:
OK, mie-mi plac simplificarile: cu alte cuvinte inteleg ca daca vrei "tăiș" la colt, te opresti... altfel ai colt rotunjit, oricat de "smecher" esti. :)
Asta in conditiile in care la o masina data ai acceleratii/deceleratii cu valori maxime care nu de depind de ce software folosesti.
Mie-mi convine explicatia asta. :drinks:
asta e problema la mine in c.v.
dupa cum se observa ce e prelucrat pe exteriorul vectorului e ok.
la interior,coltul de intrare si iesire a frezei este in regula dar celelalte...ies numai cu e.s.
coltul de start si end este cel din dreapta sus
Aceasta postare a fost editata de ionutb71: 26 February 2017 - 11:22 PM
Postat 26 February 2017 - 11:34 PM
ionutb71, la 26 February 2017 - 11:21 PM, a spus:
Pai io din ce-am copy/paste la inceputu` topicului inteleg ca daca freza mere spre nord si urmeaza s-o ia spre vest, incepe sa decelereze pe directia nord si sa accelereze spre vest inainte sa ajunga la coltu` propriu zis. Daca tie raza iti iese prea mare inseamna ca decelerarea ii prea lenta iar avand in vedere ca-i un arc de cerc inseamna ca nu-i diferenta intre accelerare si decelerare, adica-i conform cu mach3... doar ca-s prea mici, setate sau realizate practic. Io cel putin asa vad lucrurile. :|
Postat 26 February 2017 - 11:39 PM
Si mai e un aspect pe care multi il ignora, niciodata nu se face racordare interioara cu o raza egala cu raza frezei utilizate, folosind CV ca nu va iesi decat din intamplare. Contrurile in prelucrarile CNC se fac prin generare nu prin copiere. Deci nu folosesti freza de 3 ca sa obtii o raza de racordare interioara de 1,5. Ori o desenezi in cad de 3,5 sau oricat dar mai mare de 3 ori o lasi 3 daca e musai, dar folosesti freza mai mica sa o obtii. Merge si cu 3 dar atunci setat pe exact stop si se opreste in fiecare colt, face conturul prin copierea formei sculei si pleaca mai departe.
PS. Pentru colturi exterioare am gasit pe net cele 3 cazuri (link aici), unde se vede clar ca traiectoria si viteza pot fi corelate. Parerea mea este ca asta se seteaza din CAM si nu din Mach. Pun si poza direct.
Aceasta postare a fost editata de bitex: 26 February 2017 - 11:55 PM
Postat 04 March 2017 - 02:57 PM
Postat 04 March 2017 - 05:56 PM
florianmro, la 04 March 2017 - 02:57 PM, a spus:
Faptul ca schimbi interfata nu rezolva nimic....
Postat 05 March 2017 - 08:17 AM
Pentru asta mach3 trimite la intervale precise (sa zicem la 1ms) viteza.
De exemplu:
1 ms viteza 0 m/s
2 ms 0.3 m/s
3 ms 0.6 m/s
4 ms 0.9 m/s
5 ms 1.2 m/s s.a.m.d pana la ajunge la viteza dorita. Functionare normala si liniara.
Sa zicem ca la milisecunda 4 tu deschizi wordul. Sistemul intrerupe rularea mach3 pana termina de deschis word-ul,
Asta inseamna ca noua informatie de viteza va fi transmisa , sa zicem, dupa 33 ms; ceea ce se vede ca o neuniformitate in functionarea masinii.
Imprimana are un buffer unde PC-ul incarca caracterele pentru printat si de unde calculatorul imprimantei citeste cand are nevoie.
De obicei bufferul are caractere pentru cateva secunde de lucru si nu se observa ca tu lucrezi in alt program.
Imprimanta lucreaza asincron fata de calculator, iar stepperele lucreaza sincron, daca m-am facut inteles.
Postat 05 March 2017 - 08:59 AM
florianmro, la 04 March 2017 - 06:25 PM, a spus:
La printer comanda motoarelor se face de catre un Arduino sau alt sistem inteligent cu rol de controller, aflat in imprimanta.
La CNC, controllerul este Mach3 si PC-ul pe care ruleaza, nu exista nici un intermediar.
#20
Postat 05 March 2017 - 10:53 AM
florianmro, la 05 March 2017 - 09:33 AM, a spus:
Un sistem de comunica pe usb, cu softul corespunzator trece de 2-300 euro.
Ce te deranjeaza ca folosesti un PC antic dedicat Mach3 ? Cost sub 100 euro.
Am mai intrebat ce program folosesti sa generezi codul pentru 5 axe. Cu putina intelegere poti face modelul 3d in artcam. Il prelucrezi pe fata de sus si pe fata de jos.
#21
Postat 05 March 2017 - 11:14 AM
Maxim 110E pentru un controller beton, care include si plugin-ul pentru mach, plus 60E pentru licenta noului soft UCCNC..
Sau la oferta, pachet 160E.
Si eu cred ca merita toti banii. Practic cu banii de licenta de la mach, iti iei tot.
Aceasta postare a fost editata de mincof: 05 March 2017 - 11:15 AM
#22
Postat 05 March 2017 - 12:01 PM
La Trovanti, la 05 March 2017 - 10:53 AM, a spus:
Nu cred ca merge asa ceva in ArtCam
https://www.youtube....h?v=3NIzRTho8ho
#23
Postat 05 March 2017 - 12:08 PM
florianmro, la 05 March 2017 - 12:01 PM, a spus:
Eu am lucrat pe un cnc in 3 axe fata de sus si fata de jos. Nu-ti trebuiesc 5 axe.
Probabil o sa aiba mici imperfectiuni la imbinare pe care trebuie sa le slefuiesti.
Nu stiu daca s-a mai discutat aici cum sa aliniezi o piesa cand o intorci pe partea cealanta, dar este posibil.
#24
Postat 05 March 2017 - 12:41 PM
Și artcam rămâne totuși soft de desene animate
Însă mach3 poate gestiona onorabil lucrul în 5 axe simultan, asta e altă discuție
Mașina sa fie și să ducă tot atât cât poate mach3, aia e problema reală în domeniul nostru
Gone Sailing! S/Y Haimana
#25
Postat 05 March 2017 - 12:50 PM
La Trovanti, la 05 March 2017 - 12:08 PM, a spus:
Nu prea merge cu slefuitul aici .
Da ,merge pana la un anumit punct cum spui tu 3 axe ,intorci materialul si iar 3 axe , insa la ce inaltime stabilesti planul , la dinti planul aste variabil in functie de convexitati , nu este drept ca la artcam , acolo tai volumul in 2 si te joci cu planul , il urci sau cobori .Daca as sta sa slefuiesc dupa frezare mi-ar lua mai mult timp decat i-a luat masinii sa frezeze ,destul ca trebuiesc taiate tab-urile care cer atentie si timp.Soft-urile cad dentare sunt mai specializate pe astfel de amanunte Pana la un punt e acelasi lucru cu frezarile care le facem pe aici dar nu in totalitate . Stau si ma intreb daca Mach 3 imi poate sincroniza miscarile exact ca in video ce l-am postat mai sus
#26
Postat 05 March 2017 - 01:06 PM
Incearca si apoi spui ca nu se poate.
Mach 3 poate comanda 5 axe, dar cine face programul ? In 3 axe exista program
#27
Postat 05 March 2017 - 01:42 PM
o simpla axa in care sa rotesti piesa nu-ti ajunge sa faci prelucrari in toate unghiurile necesare unei prelucrari complexe, gen dinti/masele
ca un soft de 3 axe este limitat la 3 axe... ce nu e clar aici?
ca o masina in 3 axe e la fel de limitata? la fel, aceeasi intrebare: ce nu e clar?
sa facem din rahat bici, sa pocneasca si sa nu stropeasca nu prea se poate
sau se poate, dar in conditii "demo, uz didactic", nu "biznis"
cand ajungi sa ai nevoie de prelucrari in 5 sau chiar 6 axe deja treci la alta clasa, la alte preturi, unde suruburile chinezesti si sinele hiwin nu au ce cauta
si daca ajungi sa dai 4-500 euro pe o simpla patina, un pret de 5000 euro pentru un cam de 5 axe devine deja mizilic
eu am impresia ca discutia initiala era despre mach3 si ce poate face acesta, si nu despre 5axe sau cum le putem inlocui cu lucrul in 3 axe indexat
ajungem sa comparam merele din caruta cu caii ce o trag dar uitam ca a noastra caruta este un biet carucior de butelii, vizitiul este beat si drumul este plin de gropi! dar vrem sa facem drift-uri si nici sa nu ne sara merele in sant
:drinks: :drinks: :drinks:
#28
Postat 05 March 2017 - 01:54 PM
florianmro, la 05 March 2017 - 12:50 PM, a spus:
Mach3-ul poate sincroniza miscarile ca de fapt sincronizarea nu o face el. Conteaza cum faci CAM-ul si in ce soft. Daca ala poate, Mach-ul poate sa le miste.
Mach trimite direct paralel informatia, altele trimit serial. De nevoie, transmisia seriala necesita buffer, care este din fericire direct pe placa de baza a calculatorului. Plus ca mai este si urias, incape destul in el. Pe langa asta, mai are si electronica legata la portul USB un fuffer, cat se poate de incapator. Ma refer la electronica pe care o cumperi separat.
La paralel, cu setarile corecte peste tot (BIOS, windows, Mach3 - corelat cu caracteristicile driverelor), nu sunt nici un fel de probleme. Cum n-au fost niciodata nici la tiparirea textelor pe hartie, in timp ce utilizatorul facea alte operatii pe PC.
Pentru problemele dentare, cand ai o masina de 40.000 euro nu prea isi face nimeni ganduri la un soft de cateva mii de euro. Poate softul n-ar valora atat din cauza legaturii, ca-i pe USB sau pe altceva. Cu USB-ul i-a prins vremea, dar candva vor aparea discutii si pentru acest port, ca va aparea altul mai potrivit. Acolo softul e dedicat pe dantura, ca sunt probleme specifice, pe care nu le poti face in nimic altceva la fel de usor. Adica poti, dar ar insemna sa platesti operatorul sa le faca si nu cred ca se merge pe ideea asta. Toata treaba o face softul, dupa ce alegi corect ce trebuie.
Legat de porturi, Catia trimite fara probleme pe COM si nu mai plange nimeni ca nu-si face treaba. Asa au fost timpurile, USB-ul nu era atat de sigur ca acum. Mai de incredere si implementat peste tot era COM-ul ala chior la care noi nu mai legam nimic in ziua de azi.
Eu tot zic ca trebuie sa ai tot sistemul setat foarte bine si nu vor fi probleme. Masina si operatorul vor limita performantele prelucrarii mai mult decat celelalte. Celelalte trebuiesc setate bine si nu gresesc. Intai ar trebui cunoscut calculatorul pe care ruleaza. Ce are si ce poate. Configurat corect bios-ul. Instalat si setat bine windows-ul. Setat corect Mach-ul, tinand cont neaparat de masina si drivere (eventual si de cunostintele sau preferintele utilizatorului). Si cam la fel de importanta e setarea driverelor pentru motoare. Apoi se merge spre masina, cat se poate de serios si nu la final trebuie investit timp in pregatirea operatorului. In perfectionarea lui ca sa fiu mai corect.
Revin la o idee anterioara de care ne tot legam. O imprimanta pentru hartie chiar neperformanta va tipari continuu, fara pauze, indiferent de ce softuri ruleaza pe PC. Si ma refer al imprimanta veche, pe LPT. E drept ca are in ea bufferul. La fel este si cu un CNC. Daca asta cu intreruperile prelucrarii la unele procese era o problema reala, nu era greu pentru nici un electronist sa monteze un buffer in BOB. Parca am vazut candva si un astfel de BOB, dar vad ca nu s-a generalizat ideea.
Eu n-am freza acasa si ajung mai rar pe la ea, dar o sa verific toate problemele de care discutam, poate reusesc sa le gasesc si sa vad de la ce provin.
Trebuie sa cunosti foarte bine softurile pe care le folosesti si ce probleme pot ele sa creeze. Desi nu-i chiar cum zicea La Trovanti, unele procese pot duce la mici pauze. Oricum, cam aia era ideea. Nu-i normal sa nu le cunosti si sa nu stii sa le gestionezi. Daca stii ca deschiderea unui program iti intrerupe procesul, pai deschide programul inainte de prelucrare si lucreaza in el cat vrei. Ca lucrul in el nu-i tot atat de solicitant...
O sa fac niste teste candva si o sa revin cu film.
Aceasta postare a fost editata de bitex: 05 March 2017 - 01:58 PM
Postat 05 March 2017 - 02:08 PM
bitex, la 05 March 2017 - 01:54 PM, a spus:
Timime-mi te rog o dresa de email pe pm ,vreau sa iti trimit ceva
#30
Postat 05 March 2017 - 02:18 PM
PS. am uitat ca am sters mai demult adresa de mail din semnatura. Revin cu ea.
Aceasta postare a fost editata de bitex: 05 March 2017 - 02:35 PM
