Impecabil !
SPECIFICATIONS:
Input Voltage: 11-15V DC
Battery Types, # of cells:
1-10 Nickel Cadmium cell (1.2-12V)
1-10 Nickel Metal Hydride cells (1.2-12V)
1-4 Lithium Ion or Lithium Polymer cells
(3.6-14.8V)
Battery Capacity Range: 100-9900mAh
Fast Charge Current: .1-8A Linear, Reflex, Impulse and 4-step
Fast Charge Termination: Peak Detection for NiCd and NiMH
"Constant Current/Constant Voltage" for
Li-Ion/LiPo, optional thermal cutoff for
all battery types
Peak Sensitivity: 0-25mV adjustable
TRICKLE Charge Current: 0-500mA (n/a for Li-Ion/LiPo)
Discharge Current: .1-10A adjustable
Discharge Cut-Off Voltage: .8-1.1V per cell NiCd & NiMH
2.5-3.7V per cell Li-Ion/LiPo
Temperature Cut-Off Range: 50-132°F
Cycle Count: one to ten (n/a for Li-Ion/LiPo)
Cycle Cooloff Delay: 1-30 minutes, adjustable
Battery Memories: 10
Display Type: 8x21 LCD (168 characters max)
Graphical Displays: Graphs Charge and Discharge Voltage curves
Output Connectors: Banana jacks
Motor Break-in: 1-8V selectable, 1-120 minutes, 10A constant
Case Size: 5.5" x 1.8" x 5.9" (140x45x150mm)
Weight: 21oz (605g)
Poze reale:
https://goo.gl/photo...8XZLJVgdkq446t9
https://photos.googl...DZJV2pYX2FHX2Rn
Pret: 250 RON
Contact: Razvan 0721.846.149
Charger Duratrax ICE + Battery Medic / LiPo balancer Charge 8A / Discharge 10A
