Modelism - RHC Forum: VAND modul GPS Ublox 7 - Modelism - RHC Forum
VAND modul GPS Ublox 7 Mini Ublox7 GPS Module GPS+Glonass 10Hz NOu
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 23 January 2017 - 09:53 AM
Vand modul GPS Mini Ublox7 compatibil cu controlere: Multiwii, CC3D, Naze32, APM, Clean/Betaflight sau alte modele, model compact cu carcasa pentru drone mici, receptioneaza sateliti GPS si Glonass, pana la 10Hz rata refresh, baudrate configurabil din U-Center, are doar un led de power, nou.
-High accuracy, great for applications in remote control and tracking.
-Baudrate: 9600 (ajustable) , 10Hz refresh rate.
-Internal Ublox 7 series chip can receive GPS + Glonass Satellites.
-Super mini size, weigh only 8g with protective case.
-Best choice for racing drones like QAV250, ZMR250, etc.
-Standard 2.54mm pin headers.
Specifications:
-Size: 25mm x 20mm x 7mm
-Wire length: 15cm
-Wiring instruction:
Black to GND
Red to +5V
Green to TX
White to RX
Notes: Because of the super mini size ,there is only power LED on the GPS, so you'd better use with OSD.
Pret: 70lei
Tel: 0749 121 132
Andrei
#2 Useril este offline   zigotu
  • Postari: 231
  • Inregistrat: 29-June 09
Postat 26 January 2017 - 01:25 AM
Il dai cu 50 de ron si platesc transportul?
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 26 January 2017 - 09:19 AM
Vezi postareazigotu, la 26 January 2017 - 01:25 AM, a spus:
Mersi, dar va pleca la vvrest ca ma contactat mai repede.
Andrei
#4 Useril este offline   Razvan1974
  • Postari: 162
  • Inregistrat: 01-July 14
Postat 26 January 2017 - 12:22 PM
Ma intereseaza si pe mine daca nu finalizezi cu vvrest
#5 Useril este offline   andrewbt
  • Postari: 1014
Postat 28 January 2017 - 10:40 AM
Vezi postareaRazvan1974, la 26 January 2017 - 12:22 PM, a spus:
L-am trimis deja la vvrest, mai am unul dar il dau la Doru Brad.
Andrei
