Specificatii:
FOV: 30 degrees
Resolution: 854x480 (WVGA) 1230k
Interpupillary (IPD) distance: 60-68mm adjustable, Diopter with optional lenses
Channels: 32CH 4band 5.8GHz (Fatshark, Boscam & Skyzone compatible)
Receiver: Dual ISM 32ch Diversity receiver -90dbm Sensitivity
Video format: NTSC/PAL
Antenna connector: 2x SMA 50ohm
Video in/out: 1.0VP/75ohm
Audio in/out: 1.0VP/10kohm
Front internal camera: 120 degree 640x480
head tracker: Compass/ Inertial and gyro ppm selectable channel output
A/V port: 3.5mm
Ear Out: 3.5mm with volume control
power Supply: dc7-28v / 1A
Power consumption: 4.3w
Ochelarii vin cu toate accesroriile originale ( cabluri pentru Head Tracking, cablu AV, husa pentru transport, instructiuni, protectiile pentru ochi originale de cauciuc)
Accesorii:
2 x Antene Aomway - Clover + Patch (6dBi)
1 x Acumulator LiPo 2S Rhino 1750mAh
1 x Faceplate Fatshark cu ventilator pentru dezaburire. Faceplatul este fixat cu ajutorul unor cleme printate 3D. Ofer 10 cleme de rezerva in caz ca se rup.
Se vinde totul intr-un singur pachet!
Pret 1100 RON usor negociabil.
Contact PM sau Tel 0728.269.700
Acest topic e inchis
