The Turnigy AE series are based on new powerful microprocessor.
The new CPU means ultra fast sync timing, crisper throttle response, less battery load and reduced FET heat buildup. Also there is a separate voltage regulator IC for microprocessor providing good anti-jamming capability.
Specification:
Output: Continuous 65A, burst 70A up to 10 seconds.
Input Voltage: 2-6 cells lithium battery or 5-18 cells NIMH battery.
BEC: Linear 4A @ 5V
Control Signal Transmission: Optically coupled system.
Max Speed:
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 Pole: 35,000rpm
Size: 70mm (L) * 34mm (W) * 17mm (H).
Weight: 73g.
Aceasta postare a fost editata de pescarul36: 14 December 2016 - 01:47 PM
