vand motor rc smart 1600kv
Postat 21 October 2016 - 07:16 AM
Continuous Current: 45A
Max. Current: 55A
Input Voltage: 8 - 24V
Max. Efficiency: 96%
No Load Current: 1.1A
Internal Resistance: 42m ohm
Motor Dimensions (Diameter x Length): 36.5mm x 52.2mm
Shaft Dimensions (Diameter x Length): 3.97 x 18mm
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Recommend Model: Helicopter / Airplane
Package Included
Postat 21 October 2016 - 07:18 AM
as2008, la 21 October 2016 - 07:16 AM, a spus:
Max. Current: 55A
Package Included
Number of downloads: 117pret 100 lei
Postat 22 April 2017 - 09:17 PM
as2008, la 09 December 2016 - 09:37 PM, a spus:
Salut. Ce greutate,are?
Vreau sa-l folosesc pe un polaris. Daca se incadreaza,batem palma. Mentionez,polaris,decoleaza de pe iarba,apa,zapada,de aceea ma intereseaza greutatea. In eventualitatea unui regulator,ptr. el,sunt dispus. Sa auzim de bine.
Postat 22 April 2017 - 10:20 PM
hype, la 22 April 2017 - 09:17 PM, a spus:
buna seara , are cam 170 gr,, stima
Postat 22 April 2017 - 10:23 PM
as2008, la 22 April 2017 - 10:20 PM, a spus:
http://www.rcecho.co...less-Motor.html
Postat 22 April 2017 - 10:55 PM
as2008, la 30 October 2016 - 01:55 PM, a spus:
50=80km/h? 2 kg?
macar nu mai scrieti. :)))
Postat 23 April 2017 - 08:41 AM
fulgerica, la 22 April 2017 - 10:55 PM, a spus:
Salut. Modelul meu,gata de zbor are 760g. La proba pe apa,fara vant,este la limita decolarii. Lansat din mana,este ok.o idee cam puturos. Daca la greutatea actuala mai adaug cca.40g.la 1600 rpm/v cu o elice 8x6 preferabil tripala,cred ca obtin decolarea in toate conditiile.
0764485822 un beep, stabilim detaliile. Respect.
Acest topic e inchis
