VAND un motor SAITO 180 30cc cu urmatoarele specificatii:
Benchmark Prop: 16x8 APC @ 9300
Bore: 1.41 in (36.00 mm)
Carb Type: barrel 2 Needle Valve
Crank Type: Ball Bearing
Crankshaft Threads: M8x1.25mm
Cylinder Type: AAC
Cylinders: Single
Displacement: 1.80 cu. in. (29.10 cc)
Engine (Only) Weight: 31 oz
Mounting Dimensions: 138 x 69 x 135 mm
Muffler Type: Cast
Prop Range: 15x8 - 18x6
RPM Range: 2000 - 10000
Recommended Fuel: Glow
Stroke: 1.12 in (28.60 mm)
Motorul este folosit da cateva ori si merge foarte bine, ca orice SAITO este un motor pe viata.
PRET 600 RON negiciabil.
Relatii pe PM sau la 0723004415
Revin cu poze dupa ce le micsorez putin caci nu intra.
SAITO180 30cc folosit dar merge perfect ca orice SAITO
Postat 19 October 2016 - 06:50 PM
Postat 19 October 2016 - 07:00 PM
Poze promise
Number of downloads: 81 -
Number of downloads: 68 -
Number of downloads: 73 -
Aceasta postare a fost editata de Teo-Costin: 19 October 2016 - 07:00 PM
Postat 19 October 2016 - 07:40 PM
Revin cu o adaugire .... trimit doar prin FANCURIER in tara cu plata transportului facuta de destinatar iar banii in cont nu la curier caci platesc taxe de nu face.
Motorul il vand la pretul acesta mic pentru ca renunt la aero-avioane din lipsa de timp.
Postat 19 October 2016 - 07:50 PM
Teo-Costin, la 19 October 2016 - 07:40 PM, a spus:
Ce faci Teo ? Nu il vinde !
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
FW 190 HYPE
Futaba T-8FG x 2
Postat 19 October 2016 - 08:17 PM
tantar, la 19 October 2016 - 07:50 PM, a spus:
Asta este doar inceputul ca mai urmeaza sa scot la vanzare si alte motoare in 4 timpi dar sa le fac poze.
Vreau sa bag banii in quad-race FPV.
Postat 21 October 2016 - 08:30 AM
S-a dat
Acest topic e inchis
