Modelism - RHC Forum: Regulator Electronic Brushless - Modelism - RHC Forum
Regulator Electronic Brushless Turnigy AE-65A Brushless ESC
#1 Useril este offline   pescarul36
  • Postari: 273
  • Inregistrat: 08-August 07
Postat 14 December 2016 - 01:44 PM
Vand regulator electronic, Turnigy AE-65A Brushless ESC (fara revers) 100 Lei
The Turnigy AE series are based on new powerful microprocessor.
The new CPU means ultra fast sync timing, crisper throttle response, less battery load and reduced FET heat buildup. Also there is a separate voltage regulator IC for microprocessor providing good anti-jamming capability.
Specification:
Output: Continuous 65A, burst 70A up to 10 seconds.
Input Voltage: 2-6 cells lithium battery or 5-18 cells NIMH battery.
BEC: Linear 4A @ 5V
Control Signal Transmission: Optically coupled system.
Max Speed:
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 Pole: 35,000rpm
Size: 70mm (L) * 34mm (W) * 17mm (H).
Weight: 73g.
  • Fisier atasat  reg.jpg (75.44K)
Aceasta postare a fost editata de pescarul36: 14 December 2016 - 01:47 PM
O treaba inceputa este pe jumatate terminata.
#2 Userul este online   Richard 59
  • ex garorich
  • Postari: 138
  • Inregistrat: 09-July 08
Postat 14 December 2016 - 07:17 PM
Vezi PM.
#3 Useril este offline   pescarul36
  • Postari: 273
Postat 15 December 2016 - 01:35 PM
Vandut
