• Safety timer
• Capacity Limit
• Temperature monitoring
• Input power monitoring
• Individual cell monitoring
• 5 battery memory
• 2 Line back lit LCD display
• Built in Balancer to 6S packs
• Cycle charging/discharging (not available for Li-xx cells)
• Includes "FAST" & "STORAGE" Li-xx programs
• Easy to use
Specs:
Max output: 50W
Max discharge: 5W
Balancing current: 300mAh/cell
Input voltage: 10~18V DC
Ni-Cad / Ni-MH: 1~15 Cells
Li-Ion / Li-Po / Li-Fe: 1~ 6 Series
PB / Lead Acid: 2~20V
Charge current: 0.1~6.0A
Discharging current: 0.1~1.0A
Balance connectors: JST-XH connectors
No. of Cycles: Up to 5 Cycles (not available for Li-xx cells)
Dimensions: 137 x 74 x 26mm
Weight: 164g
Includes:
1 x Turnigy B6 Pro Pocket Charger
1 x XT60 Connector Charging Lead
1 x XT60 to Alligator Clip Adapter
1 x Input Alligator Clip Lead
1 x Glow/Futaba/JST adapter
1 x Comprehensive instruction manual
Pret 140 lei
NOU
0722359121
