Modelism - RHC Forum: VAND Flight Controller performant JIYI P2 v2 cu GPS NOU - Modelism - RHC Forum
VAND Flight Controller performant JIYI P2 v2 cu GPS NOU JIYI P2 Multirotor Autopilot Flight Control System v2
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 13 July 2016 - 09:22 AM
VAND Flight Controller JIYI P2 v2 cu GPS NOU la cutie cu toate accesoriile, vine gata programat, minime setari si calibrari necesare inaintea zborului, procesor modern 32bit, multiple cadre si configuratii suportate, 3 moduri de zbor, return to home si aterizare foarte precisa, setari fail-safe, monitorizare tensiune baterie, in modul GPS deviaza <5-10cm pe orice axa perfect pentru filmari, se poate monta si OSD.
Lafel de performat ca un Naza, functionalitate asemanatoare si hover hold la 50% throttle in toate modurile.
http://www.hobbyking...System_V2_.html
Features:
• Supports PPM, PWM and SBUS Receivers
• Provides superior stability and precise spot hovering
• Supports multirotor type aircraft with rotor diameter up to 800mm
• Designed for X-type and hexcopter
• Supports PWM ESC below 490hz
• Suits PCM or 2.4Ghz radio systems
• Compatible with windows XP, Windows 7/8.1/10
• Flight modes: GPS, headless mode, intelligent direction mode, Hover and return to home.
• Low voltage protection
• Micro USB connectivity
Package Contains:
Main Controller
GPS Compass Module
LED/USB module (cu mufa USB pentru acces usor)
Power module
Jumper cables
Fixtures and fittings
USB Cable
Manual
Pret: 300lei
Tel: 0749 121 132
Aceasta postare a fost editata de andrewbt: 13 July 2016 - 09:23 AM
Andrei
#2 Useril este offline   andrewbt
  • Postari: 1014
Postat 20 July 2016 - 07:41 AM
UP, valabil reducere la =>250lei, am nevoie de ceva bani momentan.
Aceasta postare a fost editata de andrewbt: 20 July 2016 - 07:44 AM
Andrei
#3 Useril este offline   andrewbt
  • Postari: 1014
Postat 22 July 2016 - 10:34 AM
a plecat la OldMann.
Andrei
