Specificatii:
Bixler™ v1.1 EPO 1400mm
Specs:
Material: EPO Foam
Wingspan: 1400mm
Length: 925mm
Wing Area: 26dm2
Wing Loading: 25g/dm2
Flying Weight: 650g
Motor: 2620-1900kv Brushless Outrunner (Included)
ESC: 20A w/BEC (Required)
Servo: 4 x 9g (Included)
Statie TGY I6
Features:
• 6 channel 2.4gHz radio with telemetry capability
• Dual Rate/Trims/Gear/Flap/Gyro Gain Adjust/Flight Mode/Throttle Hold/Hover Pitch Switches
• Easy to use Programming & Navigation Buttons
• Supports Heli/Standard Wing/Elevon/V-Tail
• 20 Model Memory
• 8 Character Model Name
• Trainer and charging ports
• Backlit LCD Screen displays real time transmitter and receiver voltage
• 4 Stick Mode Selectable
• Optional telemetry receivers and sensors available separately
Basic Programming Functions:
Dual Rates
Sub Trim
Travel Adjust
Channel Reverse
Swash Mix
Gyro Sensitivity
Throttle Curve
Monitor
Pitch Curve
Throttle Hold
Model Name
Timer
Plush 30A Brushless Speed Controller
Cont Current: 30A
Burst Current: 40A
BEC Mode: Linear
BEC : 5v / 2A
Lipo Cells: 2-4
NiMH : 5-12
Weight: 25g
Acumulator: 1500 mA 25C
