Modelism - RHC Forum: Vand OrangeRX Open LRS 433MHz Transmitter 1W (compatible with Futaba r - Modelism - RHC Forum
Vand OrangeRX Open LRS 433MHz Transmitter 1W (compatible with Futaba r Nou in cutie
#1 Useril este offline   Ervin
  • Postari: 344
  • Inregistrat: 06-October 08
Postat 26 March 2016 - 08:19 PM
Features:
• 3.3v FTDI support for easy programming (DO NOT use 5V serial / AVRISP adapters)
• Serial Port for firmware upload and telemetry application
• I2C port for sensor applications (Wii Motion Plus based Headtracker)
• 16Mhz Atmega328 processor with Arduino Pro Mini compatible bootloader.
• LM2937 3.3v voltage regulator
• U.F.L connector between PCB and antenna
• Buzzer for audible information
• 1000mW output, frequency hopping capability and hundreds of features
Specs:
Compatibility: 5-pin Futaba compatible module-based transmitters
Frequency: 433MHz
Voltage input: 6.8~12VDC
IC: Atmega328P
Power: 1000mW
Range: Full range system
Includes:
OrangeRx OpenLRS Tx Module (Futaba compatible)
Antenna
*Note: The setup and use of Open LRS requires computer programming skills and basic Arduino experience. This is not a "plug and play" system. See the attached document under the "Files" tab for resources on programming info, firmware downloads and more.
*Note: Open LRS uses 3.3v FTDI support, DO NOT use a 5V serial / AVRISP adapter or damage will occur.
Fisier atasat  P1180935.JPG (416.57K)
Pret: 120 lei.
Extra 260 1.8m electric 6s 5000mAh
Hyperlite Floss 3.0 FPV racer
Multiplex Funglider FPV plane
#2 Useril este offline   Ervin
  • Postari: 344
Postat 09 April 2016 - 11:34 PM
up
#3 Useril este offline   Ervin
  • Postari: 344
Postat 24 April 2016 - 09:35 AM
up
