Vand un set de zbor compus din urmatoarele componente :
-Statie Turnigy TGY I10 ,10 canale cu touch screen full pachet absolut noua si include
(TGY-iA10) 10 Channel 2.4GHz receiver
(TGY-BA1700) Li-ion battery 1700mah
(TGY-ATM01) Thermometer sensor
(TGY-AVT01) Voltage sensor (optical module)
(TGY-APD02) RPM sensor
(TGY-AEV01) I-bus receiverMicro USB cable
Stylus pen
User Manual (CD)
-Controller zbor cu carcasa Flip32 10DOF, soft urcat CLEANFLIGHT
Features:
3-axis MEMS gyro+accelerometer(MPU6050)
3-axis magenetometer (HMC5883L)
Pressure sensor (MS5611)
Flexible motor output,support various airframe types
Quad/Hexa/Tri/Bi/Y4/Y6/Octo/Camera Gimbal(Default is Quad-X)
Up to 8 ch RC input-supports standrad receivers(PWM),PPM Sum receiver(FrSky,etc),or Spektrum Stellite receiver
Battery voltage monitoring
Modern 32 processor running at3.3V/72MHz(STM32F103CB)
Onboard MicroUSB for setup and configuration
MultiWii-based configuration software for easy set up
reV4 hardware
Note: This version included (HMC5883L) and (MS5611) sensors.
-Camera video / foto full HD cu tot cu montura si protectie XiaoMI YI.
Ambarella A7LS Image Processor
16.0MP Sony Exmor R BSI CMOS image sensor,F2.8 aperture and with 155°wide angle
40m Waterproof Depth ( Need waterproof case )
40m waterproof sport DV, especially design for extreme sports’ shooting ( Need waterproof case )
Wireless Connection
Built-in WiFi and bluetooth 4.0 function, quick connection and real-time preview
HD Video Recording
Adopted H.264 video decoding, capture in 1080p 60fps, 960P/60,48 fps, 720P/120,60,48 fps
Super battery capacity
Equipped with 1010mAh detachable battery
Other features
The porous shell design protects from overheating; Supports max up to class10 64GB TF Card
-Frame Tricopter TRIFECTA
-Set 4 motoare si 4 ESC , impreuna cu mai multe seturi de elicii.
Specs:
System: D250-2
Motor Type: MT2206- 1900kv (x4)
Prop Size and Type: 6 x 3 inch Plastic (x4)
ESC: 15A (x4)
-Servo mecanism pentru motorul din spate.
-2 bucati baterii + avertizor luminos/sonor descarcare
Rhino 1750mAh 3S1P 20C Lipoly
-Diverse alte maruntisuri , multe elici de rezerva
Toate sunt absolut noi
Pret 1300 lei
Contact PM
Tricopter, Statie Turnigy I10,XiaoMI IY-set de zbor
Acest topic e inchis
