Modelism - RHC Forum: Merita cumparat un asemenea multicopter ? - Modelism - RHC Forum
  • 4 Pagini +
Merita cumparat un asemenea multicopter ? HobbyKing Black Widow 260 FPV
#1 Useril este offline   bernek
  • Postari: 177
  • Inregistrat: 26-February 16
Postat 02 April 2016 - 08:35 AM
Salutari !
De ceva timp ma uit la un multicopter gata de zbor mai exact HobbyKing Black Widow 260 - http://www.hobbyking...idproduct=79021
Cateva informatii din descrierea lui:
Features:
• Ready to Fly solution - Just requires 4 x AA batteries
• Includes TGY-i6 radio system
• Pre-installed brushless power system
• Pre-tuned and pre-configured quadcopter with CC3D flight controller
• Upswept arms for improved stability and faster forward flight
• Large main deck provides plenty of space for FPV equipment
• Packs away into a neat and tidy storage/ transportation case
Specs:
Motors: 2204-2300kv Brushless
Flight Controller: CC3D
Battery: 11.1v 1300mah LiPoly Included
Transmitter: TGY-i6 2.4Ghz 6 channel, 20 model memory radio system
Package Includes:
1 x Black Widow 260 class quadcopter
1 x TGY-i6 Radio system
1 x 6 inch prop set
1 x 1300mAH LiPoly battery pack
1 x Battery charger
Required:
4 x AA batteries
11-14V power supply for charger
FPV Gear optional.
Intrebarile mele ar fi urmatoarele:
1. Merita achizitionat asa ceva ? (luand in vedere faptul ca e RTF si pretul pare mic)
2. Componentele folosite sunt cat de cat calitative ?
3. Exista posibilitatea programarii modulelor (eventual update) ? in special al radio comenzii ?
4. Ce autonomie si ce distanta de vizibilitate radio ar avea ?
5. Ar fi capabil acest multicopter sa zboare cu un Runcam 2 sau Mobius/GoPro ?
6. E compatibil cu Goggles2 sau FatShark ? (daca in viitor as dori sa conectez niste ochelari FPV fara alte cheltuieli)
7. Exista posibilitatea montarii unui GPS si al zborului autonom ?
Va multumesc anticipat al vostru incepator,
Bernek
P.S. sper ca nu am incalcat prea grav regulile forumului postand un link spre un site.
  • Postari: 19189
Postat 02 April 2016 - 09:20 AM
Raspund numai la ce stiu, despre meritat sau calitatea componentelor nu ma pot pronunta, dar este destul de cert ca sa faci altceva in aceiasi bani nu este usor, chiar daca presupui ca iese ceva mai bun. Statia merita cu siguranta.
Da, exista soft alternativ care o face de 8 canale
De autonomie sa iti raspunda cei ce zboara 250, statia oricum bate mai mult decat poti vedea tu.
Chiar si FPV, daca faci un calcul elementar pentru 1km, dus si intors face 2 km, daca ai autonomie de 10 minute inseamna ca trebuie sa zbori cu 12 km pe ora deci o viteza moderata, cam ca un alergat sau mers pe bicicleta linistit.
Da
Asta depinde ce sistem video iti pui, nu are treaba cu platforma.
Daca resoftezi CC3D cu Cleanflight iNav
#3 Useril este offline   bernek
  • Postari: 177
Postat 02 April 2016 - 10:19 AM
In primul rand multumesc pentru raspunsuri renatoa !
Ma bucur sa aud ca statia merita banii si ca radiocomanda se poate programa.
Referitor la resoftare cu Cleanflight iNav am sa ma documentez (acum stiu de ce soft am nevoie).
Ma gandesc ca cei de la HobbyKing au preturi mult mai bune per componenta(de la furnizor/producator) si astfel pot oferi aceasta solutie completa la acest pret.
Sincer mi-ar fi frica sa comand toate componentele si sa am probleme de compatibilitate ulterior (mai frica imi este de calibrari).
Am descoperit (tot pe acelasi site) si sisteme FPV care am observat ulterior raspunsului tau ca nu au legatura modelul efectiv al aparatului.
Din cate am inteles (citind pe internet) aceasta clasa de multicoptere (facute practic pe bucati) functioneaza modular si se pot schimba ulterior motoare de exemplu cu unele mai puternice sau cu o eficienta mai buna etc.
Referitor la calitatea componentelor am sa caut review-uri individuale pe internet poate gasesc ceva ... Nu caut performanta absoluta nici nu imi doresc sa tina o vesnicie doar imi doresc sa pot sa ma bucur de cateva ore bune de zbor fara sa fiu nevoit sa investesc prea multi bani in reparatii (exclus accidentele evident).
Momentan sunt la scoala pe un AR Drone 2.0 pe care il comand cu un gamepad analog Thrustmaster si zbor cu niste ochelari made in China - VR BOX (gen Google Cardboard). Zborul il fac pe manual trim cu hover lock dezactivat. La 15 FPS este destul de agitant si nu pot scapa de transpiratii ! sper ca un sistem FPV normal nu artizanal m-ar ajuta in aceasta problema !
De asemenea am intrebat de distanta fata de radio comanda deoarece in momentul de fata sunt nevoit sa folosesc un access point (TPLINK cu DD-WRT) pe un trepied foto inalt ca sa nu raman fara semnal in zbor.
Aceasta postare a fost editata de bernek: 02 April 2016 - 10:20 AM
  • Postari: 19189
Postat 02 April 2016 - 11:12 AM
"...Ma gandesc ca cei de la HobbyKing au preturi mult mai bune per componenta(de la furnizor/producator) si astfel pot oferi aceasta solutie completa la acest pret."
De obicei afirmatia ca cea de mai sus ma intarata si incerc sa demonstrez contrariul :)
Si iata ca exista un set competitiv, pe care poate ca l-as alege fata de cel de la HK.
La aproape acelasi pret, doar 1$ !!! :D in plus, adica 196 free shipping fata de 180+15 de la HK EU, ai in plus:
- camera si VTx integrat
- brate foldabile rotunde, deci de inlocuit mai putin la impact ;)
- overall mai aerodinamic si mai sexy
dar si in minus... statie de doar 4 canale ne programabila :(
Cum camera + vtx costa cam cat statia... in jur de 60$... si poti vinde la pescari statia de 4ch... e o optiune...
Despre testul postarii nu am ce comenta, probabil ca au fost reflexii personale, nu astepti aprobari sau dezaprobari :)
  • Postari: 19189
Postat 02 April 2016 - 11:52 AM
... restul postarii... :)
#6 Useril este offline   bernek
  • Postari: 177
Postat 02 April 2016 - 06:46 PM
Vezi postarearenatoa, la 02 April 2016 - 11:12 AM, a spus:
Multumesc pentru sfaturi !
Sunt tare curios sa vad si eu setul respectiv ! Oricat am cautat cu mouse-ul prin postarea facuta de tine nu am gasit link-ul spre magazinul respectiv.
Te rog daca poti sa postezi link-ul sau un PM cu el.
Cu respect,
Bernek
  • Postari: 19189
Postat 02 April 2016 - 07:12 PM
oups... prietenul Alz ma tinea de vorba :D
http://www.banggood....-p-1017505.html
#8 Useril este offline   bernek
  • Postari: 177
Postat 02 April 2016 - 08:40 PM
Vezi postarearenatoa, la 02 April 2016 - 07:12 PM, a spus:
Merci ! M-am uitat la acest Parkhour 280 este foarte interesant !
- mi-au placut bratele rabatabile si mai ales daca spui ca la mica cazatura supravietuiesc mai bine sunt o alegere mai buna !
- e mai sexy si mai colorat, mai viu
- are VTX cu antena aferenta
- care e diferenta 4 ch vs 6 ch ? range mai bun ? am vazut ca receiver are 6ch doar radio comanda e cu 4.
- camera vad ca este CCD asta ar insemna ca imaginea e captura integral nu ca la CMOS pe fragmente - asta elimina efectul de jello ?
- un plus pentru mine ar fi si incarcatorul de LiPo care cealalta drona nu il are.
Am urmarit video care este postat (ma gandesc review/reclama) pe banggood chiar pe pagina cu multicopterul: https://youtu.be/zvRJKcqqhc4 si m-am cam speriat de setari (multitudinea lor) si de throttle glitch
Daca ar fi acest glitch pe pitch eu cel putin in 5-10 minute as cadea pe undeva cu ea :)
Bernek
#9 Useril este offline   MR-JW
  • Postari: 530
  • Inregistrat: 15-May 10
Postat 02 April 2016 - 08:42 PM
De ce nu un kit complet :
http://www.banggood....-p-1008942.html
Aceasta postare a fost editata de MR-JW: 02 April 2016 - 08:42 PM
#10 Useril este offline   bernek
  • Postari: 177
Postat 02 April 2016 - 09:22 PM
Vezi postareaMR-JW, la 02 April 2016 - 08:42 PM, a spus:
Sincer putin cam scump pentru mine ! Cautam ceva la sub 200 EUR - aici e mai greu sa gasesti ceva bun si ieftin stiu :)
#11 Useril este offline   MR-JW
  • Postari: 530
Postat 02 April 2016 - 09:45 PM
Poti incerca kitul fara statie care este in promo la 116 EURO:
http://www.banggood....n-p-995366.html
La care mai pui statia 47 EUR:
http://www.banggood....-2-p-47904.html
  • Postari: 19189
Postat 02 April 2016 - 10:06 PM
Eu vad statia 71 Euro... :unsure: De unde 9x 47, ar fi prea bine...
  • Postari: 19189
Postat 02 April 2016 - 10:13 PM
Nu, cred ca foloseste acelasi sistem RF, receptorul fiind acelasi, transmite doar 4 canale.
Da, CCD nu are jeleu, pentru ca foloseste global shutter, jeleul e provocat de rolling shutter caracteristic CMOS
http://www.red.com/l...rolling-shutter
buna observatie, mi-a scapat
...m-am cam speriat de setari (multitudinea lor)
cam asa e la toate, dar nu se umbla chiar la toate :)
...si de throttle glitch
La ce minut e glitch-ul asta ?
#14 Useril este offline   EBA
  • Postari: 956
  • Inregistrat: 09-April 09
  • Interests:AEROMODELISM
Postat 03 April 2016 - 12:01 AM
OMG.Vorbiti de efect de jello la camerele cmos?.Si ma rog cu ce fel de monitor LCD FPV vedeti acel efect?
SUNTEM FUDULI
#15 Useril este offline   MR-JW
  • Postari: 530
Postat 03 April 2016 - 12:07 AM
Vezi postarearenatoa, la 02 April 2016 - 10:06 PM, a spus:
Am pus gresit link-ul era vorba de i6 :
http://www.banggood....r-p-983537.html
#16 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 12:48 AM
Vezi postarearenatoa, la 02 April 2016 - 10:13 PM, a spus:
De la 7:35 -> incolo este ! Tot se plange individul de "throttle glitch" de cateva ori odata si aterizeaza "panicat" cica.
E frumos si Eachine 250-ul am impresia ca seamana mult cu Walkera Runner 250.
M-am uitat putin la Open Pilot si nu e chiar asa de speriat. Backup frumos inainte si cam orice strici cred ca e reparabil :)
Sper sa primesc acordul iubitei mele sotii sa achizitionez cat de curand un multicopter care sa inlocuiasca AR Drone 2.0-ul care a devenit cam lent pentru mine !
Imperecherea statie -> receiver (de pe multicopter) este "greoaie" ? (de multe ori am vazut ca aceste multicoptere nu prea vin cu un manual bine pus la punct).
Tare m-as bucura sa pot veni la o intalnire cu viitoare jucarie sa pot invata lucruri noi de la voi :)
#17 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 01:09 AM
Vezi postareaEBA, la 03 April 2016 - 12:01 AM, a spus:
Daca miscarea imaginii e brusca, mai ales continua pe CMOS apare destul de urat acel si creaza impresia de imagine deformata/jeleu. De fiecare data cand faci un roll puternic sau un pitch agresiv imaginea e deformata, daca faci roll/pitch continu si ai in imagine niste stalpi/blocuri ai impresia ca sunt strambi in directia in care imaginea se misca. Nu conteaza monitorul sau ochelarii prin care te uiti si nici refresh rate-ul imaginea oricum e deformata din cauza ca senzorul CMOS creeaza imaginea "pe linii" pornind de sus in jos de obicei.
Vezi te rog acest video: https://youtu.be/R_qOW-Fm0Zg - in acesta se vad mai bine efecte asupra vibratiilor
Un alt video: https://youtu.be/tPL1Pzb_Hf8 - in acesta se vad deformarile imaginii
Personal imi place cum se percep imaginile pe CCD vs CMOS.
Aceasta postare a fost editata de bernek: 03 April 2016 - 01:12 AM
#18 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 01:22 AM
Vezi postareaMR-JW, la 02 April 2016 - 09:45 PM, a spus:
Ar fi o solutie interesanta ! As putea achizitiona in prima etapa doar multicopterul si ulterior o radio comanda ! Nu suna rau deloc desi nu stiu cum as rezista sa ma uit la el fara sa pot sa zbor :)
GPS-ul este optional la majoritatea acestor modele ? De exemplu au "return to home" ? Cum functioneaza aceasta functie ?
Am citit despre modurile de zbor printre care am vazut altitude hold. Cum face acest lucru ? barometru ? sonar ? amandoua ?
Tot ce am "prins" despre multicoptere este de la un AR DRONE 2.0 amarat care am descoperit cum functioneaza.
Multumesc pentru timpul acordat si link-uri.
#19 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 09:18 AM
Vezi postareaMR-JW, la 03 April 2016 - 12:07 AM, a spus:
Am citit aici despre numarul de canale: http://www.rchelicop...ter-radios.html
Oare merita investitia la unul cu 9ch ? sau ma descurc si cu 6ch la inceput. Ulterior trebuie sa schimb si RX si TX cu cate canale vreau ...
Sa caut un multicopter cu receiver de 9ch pe el ? pairing-ul se face usor sau pot aparea probleme ?
Multumesc.
  • Postari: 19189
Postat 03 April 2016 - 10:04 AM
Vezi postareabernek, la 03 April 2016 - 01:09 AM, a spus:
Teoria asta este pentru camerele mici de supraveghere, care nu au proceoare de imagine corespunzatoare pentru ca sunt destinate sa fie fixe.
La Bebop are CMOS si nu ai jeleu deloc. Dar are si proc video quad core cu ventilator :)
Vezi postareabernek, la 03 April 2016 - 01:22 AM, a spus:
Se cheama masochism :)
Obligatoriu nu este cu siguranta :) mai ales ciuperca aia ridicola...
Cam toate care au GPS au cel putin stationare la punct fix (loiter) si RTH, sunt functiile primare
Cum functioneaza? pai isi memoreaza locatia de decolare si cand ii zici "hai acasa" printr-o anumita valoare a unui canal din statie, de regula ch5, calculeaza drumul cel mai drept si revine.
La pierdere semnal trebuie sa ai la receptor failsafe setata ca sa dea comanda de revenire ca si cum ar fi venita de la statie.
barometru
Nu e amarat deloc, e mai destept ca multe multicoptere cu care vrei sa il inlocuiesti.
Are limitarile lui, le vad si la Bebop, dar invat sa traiesc cu ele, are multe alte puncte care nu mi le ofera nimic de pe piata.
In locul tau as lua un Bebop second, acum se gateste si sub 200 euro. Dar cu siguranta nu e masina de racing !
Vezi postareabernek, la 03 April 2016 - 09:18 AM, a spus:
Multumesc.
Depinde cat vrei sa te intinzi, nevoia de canale peste 6 apare cand pui si gimbal sau vrei sa actionezi ceva suplimentar pe copter, strict pentru zbor se folosesc doar 5ch.
FS-i6 se poate resofta la 8 canale si mie personal imi place mai mult decat 9X ca feeling.
Sa resoftezi 9X fara sa treci si transmisia pe Frsky ca sa ai telemetrie aproape ca nu merita, iar asta inseamna alti 50$ peste 80 cat e statia.
Probleme de pairing/binding au de obicei cei care nu citesc manualul :)
Aceasta postare a fost editata de renatoa: 03 April 2016 - 10:06 AM
#21 Useril este offline   andrewbt
  • Postari: 1014
Postat 03 April 2016 - 12:31 PM
Vezi postarearenatoa, la 02 April 2016 - 09:20 AM, a spus:
Da
Salut, am vazut ca ai scris ceva de upgrade pt TGY-i6 la 8ch? se poate face din soft :) ? ca simt nevoia de ceva canale in plus. Poti sa ma indrumi cum se poate face si va trebui sa iau alt receptor gen http://www.hobbyking...idproduct=60357 ?, mersi.
Aceasta postare a fost editata de andrewbt: 03 April 2016 - 12:36 PM
Andrei
  • Postari: 19189
Postat 03 April 2016 - 12:40 PM
Da, la 8 canale trebuie receptorul de 10.
Link-urile la upgrade sunt in topicul statiei, are si pe rcgroups thread dedicat operatiei.
#23 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 01:34 PM
Sunt surprins placut ca am primit atatea raspunsuri si informatii intr-un timp atat de scurt !
- ma bucur sa aud ca CMOS de pe camerele TVL este mai performant. Personal stiu de la DSLR-uri CCD vs CMOS (sunt fotograf amator)
- sper sa nu fie un caz de masochism :D cu achizitionarea fara radio comanda.
- receptoarele (care le-am insirat pana acum) suporta vreunu fail-safe-ul respectiv ?
- barometru ar trebui sa fie destul de exact oricum nu m-as astepta sa stea in aer ca ArDrone 2.0 sau Bebop.
- referitor la receptorul cu 6 canale o sa imi fie deajuns !
- imi place sa lecturez (asa ca sper sa nu am probleme ... ma asteapta o lectura serioasa)
- referitor la Parrot Bebop am vazute cateva in jur de 900 RON singurul minus pentru mine fiind WiFi care are range-ul mic si imaginea transmisa are o latenta maricica (cel putin la ArDrone 2.0). Sa achizionez Skycontroller-ul e prea scump ... Bebop 2 ar fi o varianta prea scumpa pentru mine din nou ...
Nu caut viteza prea mare doar imi doresc un FPV pe viitor (cu ochelari) si o autonomie de 10-15 min si un aparat de zbor cat de cat agil pe care sa montez un Runcam 2 eventual pentru mici filmutele hobby.
Ma gandesc ca avand acumulatori de capacitati diferite pot "jongla" timpul de zbor vs agilitate cu ajutorul Open Pilot pentru calibrarile de rigoare.
Bebop sau Bebop 2 are stabilizare digitala si pan and tilt la inregistrare pe senzorul de 12 sau 14 Mpix. Sincer tind sa cred ca acesta e viitorul stabilizarii optice la aparate de zbor cel putin.
Aceasta postare a fost editata de bernek: 03 April 2016 - 01:36 PM
  • Postari: 19189
Postat 03 April 2016 - 02:19 PM
Daca adaugi si un runcam deja bebop este mai ieftin. Doar fa o adunare si te lamuresti... deja esti la 200 eur = 900 lei fara runcam
Tableta daca are iesire HDMI vei putea baga in ea cat de curand GogglesOne pe HDMI si atunci deja esti in alta galaxie decat FPV-ul analogic
Range mic se rezolva cu range extender, care oricum e mai putin ancombrant decat un GS de FPV. Chiar azi testez unul de 100 lei si iti zic daca reusesc sa trec de 150m cat poate acum tableta mea.
Cu acumulator de 2500mAh ultrausor 140g am trecut de 15 minute, deci si autonomia e rezolvata.
Urmeaza o modare cu elici mai mari si acumulator HV care sper sa ma duca la 25 minute.
Mai spre vara vreau sa modez si sonarul, sa pun inca unul pe directia inainte ca sa evite obstacole ;)
Ai berechet spatiu de bricoleala si la Bebop daca esti nelinistit...
#25 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 02:30 PM
Vezi postarearenatoa, la 03 April 2016 - 10:04 AM, a spus:
Daca te rog poti sa imi precizezi care sunt punctele care nu sunt oferite de alt model pe piata (comparativ cu ArDrone 2.0 sau Bebop/Bebop 2)? Poate imi scapa ceva foarte evident !
Visul meu este sa "zbor liber" (FPV cu ochelarii pe viitor) la o distanta de maxim 1500-2000 metrii. Ma gandesc sistemele RX TX de pe aceste modele care sunt in discutie pot acoperi pana aproape de 1000 metrii.
O ordine de prioritati (personala) pentru multicopter-ul la care visez este:
1. Pret pana in 200 EUR (fara ochelari si camera secundara).
2. Siguranta in zbor (nu sunt expert si nici nu cred sa ajung curand).
3. Filmare/video stream FPV bun eventual cu o camera secundara gen Mobius/Runcam 2.
4. Stabilitate in aer si manevrabilitate acceptabila pentru un "pilot" in devenire.
5. Autonomie decenta (pentru mine decent inseamna 10-15 minute).
6. Viteza cat de cat (pentru mine asta ar insemna 30-40 km/h).
7. Posibilitate de upgrade la un GPS pentru zbor autonom (cu ArDrone folosesc UGCS si sunt foarte multumit doar ca exista niste limitari la varianta FREE).
Aceasta postare a fost editata de bernek: 03 April 2016 - 02:30 PM
#26 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 02:49 PM
Vezi postarearenatoa, la 03 April 2016 - 02:19 PM, a spus:
Am facut doua poze rapid cu ce folosesc eu acum. Momentan range extenderul (access point cu DD-WRT pe el) merge la 150m destul de bine - dar nu sunt multumit.
Acumulatori am si eu de 2300 mAh cu care zbor pana in 20 minute fara probleme dar sunt mai grei cu cca 50g decat cei originali de 1500 mAh.
Pozele :)
http://s22.postimg.org/wvflpapfh/DSC_0529.jpg
http://s8.postimg.org/bqzaclhnl/DSC_0532.jpg
Mai am si o mica problema aerodinamica (cred) la viteza mare se intoarce 180 grade ... am incercat cu o aripa de ghidaj pe hull de exterior (cam fara success) si urmeaza sa ii tai "nasul" in curand.
P.S. TP-LINK-ul din imagine il alimentez cu o bateria orignala de AR DRONE 2.0 (cea de 1000 mAh) care nu mai e buna la nimic altceva.
Aceasta postare a fost editata de bernek: 03 April 2016 - 02:52 PM
#27 Useril este offline   REAL DESIGN
  • R.D.
  • Postari: 5484
Postat 03 April 2016 - 08:19 PM
Vezi postareabernek, la 03 April 2016 - 02:49 PM, a spus:
Pozele :)
Cum se vede cu VR-BOX-ul si mobil ? .. folosesti Easy Cap cu ce receptor de semnal ?
Sunt interesat de o astfel de solutie pentru ochelari dar nu am avut posiibilitatea sa vad unii la lucru ..
#28 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 09:11 PM
Vezi postareaREAL DESIGN, la 03 April 2016 - 08:19 PM, a spus:
Cred ca este o mica neintelegere dar am sa clarific imediat situatia. VR BOX = Google Cardboard (cu lentile de sticla si din plastic avand curele de elastic ~ 30 USD in China si vreo 160 RON la noi).
Telefonul este Android si am instalata aplicatia AR Flight Pro (http://meavydev.co.uk/ARDrone.html) aceasta suporta Google Cardboard si o setez evident in acest mod cand folosesc VR BOX-ul.
Aceasta aplicatie suporta si gamepad-uri analogice pentru controlul dronei Parrot si astfel folosesc gamepad-ul din imagine cu un cablu OTG (pot configura fiecare axa buton etc asta e foarte ok).
Practic telefonul e ori pe suport (care l-am lipit pe gamepad cu un epoxy) ori este introdus in VR BOX (intr-un suport gen caseta) cand vreau sa zbor asa.
Este o solutie mai "ghetto" dar functioneaza binisor ! pe ecranul telefonului am un OSD (din aplicatia respectiva) si vad toate informatiile de care am nevoie. Claritatea imaginii daca ai un telefon cu peste 500 ppi ar fi superba !
Galaxy S3 cred ca are undeva sub 350 ppi daca tin bine minte. Oricum imaginea e superioara sistemelor FPV dar latenta e mai mare si am doar 25-30 fps practic e latenta cu care AR Drone 2.0 trimite imaginile pe telefon (ca e Apple ca e Android tot acolo e cand vine vorba de video stream-ul de pe ArDrone - testat de mine si cu iPhone 6 si cu Galaxy S5 Neo).
Aceasta postare a fost editata de bernek: 03 April 2016 - 09:12 PM
#29 Useril este offline   bernek
  • Postari: 177
Postat 03 April 2016 - 10:36 PM
@renatoa
Ai apucat sa folosesti range extenderul azi ? Eu cu TP-LINK-ul meu cu DD-WRT si 17 dBm cu o antena gain de 5 dBi si una de 9 dBi omnidirectionale nu am reusit mai mult de 125-150 metrii lucru care il realizez si cu Galaxy S3 cu WiFi power saving turned off.
Ma gandesc la o antena sectoriala mica (ar arata ca un Flight Controller de Bebop sau Bebop2) sau o antena panou directionala mica de 10-14 dBi.
Cat de cat situatia mea e incurcata cu ArDrone 2.0 si sincer m-as feri de control tot pe WiFi cand imi doresc range mult mai mare si cat am cheltuit cu ArDrone 2.0 puteam lua un Phantom 2 second hand. (am gasit pe la 1500 RON)
Oricum daca ai ceva rezultate sa ma anunti !
Multumesc,
Bernek
  • Postari: 19189
Postat 04 April 2016 - 11:21 AM
Da, apucat sa testez, dezamagitor...nu e mult mai mare, sau ar trebui sa dau din coada ca am 150m cu antene simple stoc omni de 2db ? :unsure:
Mda, un calcul simplu arata ca un patch sectorial de 14db ar insemna 4x range, 600m ar fi prea frumos... incercam si asta... :)
Nu imi doresc range mult mai mare... nu in detrimentul altor factori, cu siguranta.
La mine este mult mai importanta portabilitatea solutiei, chestii gen gimbal mecanic sunt excluse, daca nu o pot trece in rucsac prin control aeroport bagaj de mana acea solutie nu exista.
Sau sa am nevoie de masina ca sa ma deplasez cu drona in anumite puncte... solutia care nu e "biciclabila", nu exista pentru mine.
Oricum pe langa Bebop mai am si alte jucarii, doar ca au ajuns sa stranga praf tocmai din motivele de neatractivitate enumerate mai sus, plus calitatea imaginii inferioara.
Ce crezi ca realizai cu phantomul in plus ? Cu statia proprie erai blocat in sistem... plus necesita fpv si camera care ii dublau valoarea... chiar nu poti pune pe hartie sa vezi ca nu poti egala ce ofera bebop in aceiasi bani ?
Si acum raspund din urma la celelalte :)
  • 4 Pagini +
