Modelism - RHC Forum: Vand Aeromodel Ryan NY-P 1.600 mm - Modelism - RHC Forum
#1 Useril este offline   dan1972
  • Postari: 1453
  • Inregistrat: 03-December 11
Postat 30 October 2015 - 04:46 AM
Vand aeromodel Ryan NY-P - 1600 mm
- Anvergura - 1600 mm
- Lungime - 1000 mm
- Greutate - 980...1150 gr (fct de LiPo)
- Motor 2826 -1000 kv
- Elice 10x6 GWS
- Servo 2buc 17 gr + 2 buc 9 gr HXT
- Mai sant necesare:
ESC de 25...30 Amp. si LiPo 3s-1300...2200 mAh
Aeromodelul a fost construit de mine la scara dupa planuri, din depron, intarit cu baghete de pin.Constructia este corect realizata si este robusta, dar foarte usoara.
Aeromodelul zboara calm, cu viteza redusa, dar poate face si acrobatie, daca este echipat cu un motor mai puternic.Eu am preferat o echipare mai usoara, pt. a nu-l ingreuna.
Pret: 400 RON
Tel.: 0746/322.021
Messersmitt ME 109 G - Parkzone - 1100mm
Magister-MULTIPLEX - 1630mm
Ryan NY-P - 1600mm
Piper Cub J3- 2310 mm - 28cc benzina
Diamond 1800mm
P40-Warhawk mini (645mm)
W-Fly-Flaspeed 2,4 GHz
#2 Useril este offline   dan1972
  • Postari: 1453
Postat 30 October 2015 - 04:48 AM
Ryan NY-P - 1600mm
Diamond 1800mm
#3 Useril este offline   dan1972
  • Postari: 1453
Postat 30 October 2015 - 04:50 AM
Aeromodelul poate fi infoliat sau vopsit, dar am preferat sa-l las asa, pt. ca este foarte vizibil pe cer si nu am vrut sa adaug greutate pe el.
Ryan NY-P - 1600mm
Diamond 1800mm
#4 Useril este offline   dan1972
  • Postari: 1453
Postat 27 November 2015 - 04:13 AM
Anunt valabil! Pret 380 RON.
Ryan NY-P - 1600mm
Diamond 1800mm
#5 Useril este offline   dan1972
  • Postari: 1453
Postat 06 December 2015 - 04:32 AM
Anunt valabil! 350 RON
Ryan NY-P - 1600mm
Diamond 1800mm
#6 Useril este offline   dan1972
  • Postari: 1453
Postat 14 December 2015 - 03:37 AM
Anunt valabil!
Ryan NY-P - 1600mm
Diamond 1800mm
#7 Useril este offline   cosmin77
  • Postari: 253
  • Inregistrat: 24-March 15
  • Interests:Aeromodelism
Postat 28 December 2015 - 10:22 AM
Ai PM.
#8 Useril este offline   cosmin77
  • Postari: 253
Postat 30 December 2015 - 04:53 PM
Il astept cu nerabdare !:drinks:
Va fi primul pe 2016 si sper ca o sa ma mai potolesc putin ca nu mai am loc in casa ......
#9 Useril este offline   dan1972
  • Postari: 1453
Postat 01 January 2016 - 06:00 PM
Salut Cosmin!
Am cumparat ambalaje pe 31 Dec..Maine cred ca reusesc sa il ambalez si in prima zi lucratoare la Fan Courier, ti-l trimit.
Probabil o sa faca 2 zile pana la tine, pt. ca au jonctiune la Brasov. Tot ce pleaca spre Ardeal face 2 zile...Oricum te sun dupa ce ti-l trimit, ca sa stii ca a plecat spre tine.
Vorbim!
Ryan NY-P - 1600mm
Diamond 1800mm
#10 Useril este offline   cosmin77
  • Postari: 253
Postat 04 January 2016 - 12:51 PM
OK, il astept.
M-as bucura sa il pui cat mai repede saptamana aceasta sunt in concediu si ma pot ocupa linistit de el.
Am mai gasit prin cutii un motor 2830 DE 980 KV si cred ca pe acesta il voi pune cu elice de 10 x 4 SAU... 8 + ESC DE 30A.
Vorbim.
#11 Useril este offline   dan1972
  • Postari: 1453
Postat 06 January 2016 - 06:45 AM
Salut Cosmin,
Sa-l zbori cu placere si sa te bucuri de el! Azi cred ca il vei primi.
Motorul e un pic mai puternic decat cel initial. E un pas bun.Cred totusi ca cel mai potrivit pt. acest aeromodel este un motor 2834-1000 kv, sau unul plat 4015-960 kv (cel de pe trainerul Wing Tiger si alte modele chinezesti...il gasesti pe HobbyKing...).
...Masoara distanta de la batiu la marginea capotei motorului, apoi compara cu dimensiunile motorului pe care vrei sa il cumperi, ca sa nu ai surprize (sa nu fie prea lung motorul). Nu e un capat de tara, dar va sta mai departe conul elicei de capota si nu va arata OK.
...Totusi il vei putea zbura fara probleme si cu motorul pe care il ai acum. Eu cu un motor mai mic (2825-1000 kv si elice 10x7 am reusit sa fac looping cu el...Deci...)
...Elicea maxima recomandata pt. motoarele acestea este 10x6 GWS sau 10x5 APC....Daca montezi o elice mai mare vei incinge motorul si il scoti din zona de eficientza (va consuma curentul neeficient...).
Teoretic daca vrei mai multa tractiune, folosesti o elice mai mare cu pas mai mic...Daca vrei viteza, folosesti o elice mai mica cu pas mai mare...Daca maresti si diametrul si pasul, soliciti motorul peste curentul maxim admisibil. Nu e recomandat!!!
Daca ai nelamuriri cu privire la montajul aeromodelului, suna-ma fara nici o problema.
...Sper sa ajunga bine la tine!
Toate cele bune!
Ryan NY-P - 1600mm
Diamond 1800mm
#12 Useril este offline   dan1972
  • Postari: 1453
Postat 06 January 2016 - 06:46 AM
Aeromodelul s-a vandut.Subiectul se inchide. Multumesc!
Ryan NY-P - 1600mm
Diamond 1800mm
