Sunt branduite Freeflight, provin dintr-un pachet octo Freeflight.
Nu am hardware de prindere sau pt montaj elice, elicele se prind direct.
Am 8 bucati, se vand 4 sau 8.
Pret 4buc 500ron
Pret 8buc 900ron
Sunt deschis pentru negot, dar nu le grupez altfel ca sa nu raman cu motoare nevandute.
Each motor is QC checked for balance, performance and mechanical tolerance.
Features:
• High Power N42sh magnets
• Precision NSK bearings
• Ample cut to length motor wires for a clean install
• Direct mount propeller or Hub style compatible
Specs:
KV: 400
Stator Diameter: 41mm
Stator Length: 14mm
Shaft Diameter: 4.00mm
Weight: 146g
Battery: 5-6S Lipoly
Max Continuous current: 33.8A
Max Power(W): 400
Tel: 0730583513
Number of downloads: 74 -
Acest topic e inchis
