Placa a fost folosita la 2 zboruri, fara defecte fara probleme ! (telefon : 0720069015)
Pachetul contine placa APM 2.6 si modulul de alimentare !
Arduino Compatible!
Can be ordered with top entry pins for attaching connectors vertically, or as side entry pins to slide your connectors in to either end horizontally
Includes 3-axis gyro, accelerometer and magnetometer, along with a high-performance barometer
Onboard 4 MegaByte Dataflash chip for automatic datalogging
Optional off-board GPS, uBlox LEA-6H module with Compass.
One of the first open source autopilot systems to use Invensense's 6 DoF Accelerometer/Gyro MPU-6000.
Barometric pressure sensor upgraded to MS5611-01BA03, from Measurement Specialties.
Atmel's ATMEGA2560 and ATMEGA32U-2 chips for processing and usb functions respectively.
Data Sheet:
3-Axis Gyro
3-Axis Accelerometer
High Resolution Altimeter
5Hz GPS Module
Dimension: Approx 70.5x45x13.5mm
Weight: 31g
