Modelism - RHC Forum: Vand UBEC Jeti MAX BEC 2 - Modelism - RHC Forum
#1 Useril este offline   fadini
  • Postari: 319
  • Inregistrat: 30-October 09
  • Interests:RC Jets &EDF
Postat 20 August 2015 - 07:18 AM
Specificatii (copy-paste) :
MAX BEC is designed to power the receiver and servos in the model. MAX BEC is a linear voltage stabilizer with an adjustable output voltage. The output voltage is set using a jumper and in one of four positions: 5.0V, 5.4V, 5.7V or 6.0V. MAX BEC can be powered using NiXX and Li–XX cells. MAX BEC also gives an indication of used capacity of the battery with four LEDs.
Part of MAX BEC is an electronic switch, which uses a highly efficient type of MOSFET transistor. The main benefits of the MAX BEC include a high voltage rating (to 12 cells NiXX) and low current in the off state (170 μA). The analog voltage stabilization does not contribute to radio interference.
Recommended input voltage [V] 5,5 - 8,4
Max. input voltage [V] 16
Number of inputs (accu) 2
Output voltage [V] 5,0 / 5,4 / 5,7 / 6,0
Pulsed current [A] 20
Sustained current [A] 12
Idle current [µA] 170
Max. power loss [W] 20
Temperature Range max. [°C] 130
Weight [g] 85
Dimensions [mm] 100 x 29 x 16
Mentionez ca este folosit 1-2 ore.
Pret : 200 ron nenegocibil
Aceasta postare a fost editata de fadini: 20 August 2015 - 07:19 AM
SU27 Frank Raptor 180
Rafale Wren SuperSport
CARF Eurosport Frank Raptor 180
MIG29 Kolibri T35
MIG21 Kolibri T35
#2 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2396
  • Inregistrat: 05-August 09
Postat 20 August 2015 - 07:20 AM
Vezi postareafadini, la 20 August 2015 - 07:18 AM, a spus:
Weight [g] 85
Salut.
Ma intereseaza.Un nr de contact!!
Olivian Diaconescu
Radio:
Multiplex Royal Pro 16 2.4GHz
Aero:
FREEWING - F22 Xicoy X45 Jet
T one F22-2.7 m in curand..
ROBBE - Mistral 2.0m
AERONAUT - Triple RES 2.0m
Auto:
TRAXXAS - E Revo 1/16
ARRMA - Typhon 6S
  • Postari: 19179
Postat 20 August 2015 - 09:37 AM
adjudecat, se poate inchide
#4 Useril este offline   fadini
  • Postari: 319
Postat 21 August 2015 - 06:30 PM
Vandut !
MIG29 Kolibri T35
MIG21 Kolibri T35
