Modelism - RHC Forum: Futaba T6J - Modelism - RHC Forum
Futaba T6J Cu rx, charger
#1 Useril este offline   SHAKS
  • Postari: 1059
  • Inregistrat: 17-January 05
Postat 05 August 2015 - 04:28 PM
De vanzare Futaba T6J FHSS cu receptor R2006GS, acumulator si charger de perete.
Pret 500 ron
Caracteristici:
- 15-model memory
- 4-character model naming
- Simple 1-lever/3-button programming
- Data reset
- Airplane & heli software
- FHSS/S-FHSS modes
- Mode 1-4 selectable
- 127-segment, 40 x 40 LCD
- Digital trims/trim memory
- Endpoint adjustment (EPA), sub-trims & servo reversing
- Dual rates & exponential (ail/ele/rud)
- Fail-safe (all channels; in S-FHSS mode only)
- Throttle cut
- Trainer system (cord required)
- Throttle position, mix & low battery warnings
- Up/down & model timer
- Range check mode
- R2006GS S-FHSS Receiver
Functii avioane:
- 2 programmable mixes, plus:
- (2) 5-point throttle curves
- (2) 5-point pitch curves
- Flaperon w/differential rate
- Flap trim (2 rates)
- V-tail mixing
- Elevon mixing
Functii elicoptere:
- (3) 5-point pitch curves
- Throttle hold
- Hover pitch
- Gyro mixing
- Revo mixing
- 4 swash plate types (H1, H3, HR3 & H3 w/AFR)
- Swash AFR (ail/ele/pitch)
- Throttle mix
- Electronic swash ring
- Throttle delay
- Pitch delay
Specificatiile emitatorului:
Type: 2-stick, 6-channel
Functions: 12/6 Servos
Transmission system: FHSS/ S-FHSS selectable
Frequency band: 24004
Spotfrequencies: 30
Current Drain: 150 mA
Power Supply: 4.8-6 V
Dimensions: 185 x 200 x 80 mm
Weight: 740 g
28 simultaneous users
Not compatible with FASST receivers; only with FHSS receivers, e.g. R603 GF, R2004GF, R2104GF, R2006GF.
Raza actiune pe apa: 350 m
Specificatiile receptorului:
R2006GS 2.4GHz S-FHSS 6-Channel Receiver
Type: Full-range flight receiver
Modes: FHSS or S-FHSS
Features: Easy-Linkā„¢ binding, high-voltage operation, frequency-hopping, spread-spectrum design & Dual Antenna Diversity
Voltage Input: 4.8V-7.4V
Compatible Batteries: NiCd, NiMH, LiPo, LiIon & LiFe
Dimensions: 1-11/16 x 15/16 x 516 in (43 x 24 x 7.9 mm)
Weight: 8.3 grams
Current Drain: 80 mA (@ no signal)
Tel: 0730583513
20cm of RC experience
#2 Useril este offline   SHAKS
  • Postari: 1059
Postat 06 August 2015 - 10:14 PM
Vandut, se poate inchide.
Pfffff, de cand vroiam sa spun asta!... :))
