Modelism - RHC Forum: Set 6 motoare multicopter NTM Prop Drive - Modelism - RHC Forum
Set 6 motoare multicopter NTM Prop Drive Uzura minima
#1 Useril este offline   SHAKS
  • Postari: 1059
  • Inregistrat: 17-January 05
Postat 25 June 2015 - 01:51 PM
NTM Prop Drive Series 28-30 800kv
6 bucati, se dau doar impreuna. - 360 ron
Adaptoare incluse.
Specs:
Model: NTM Prop Drive Series 28-30A 800kv (short shaft version)
Kv: 800rpm/v
Max current: 20A
Max Power: 300W
Shaft: 3mm
Weight: 65g
ESC: 20~30A
Cell count: 3s~6s Lipoly
Bolt holes: 16mm & 19mm
Bolt thread: M3
Connection: 3.5mm Bullet-connector
Prop Tests:
8x4E - 22.2V / 310W / 13.9A / 1.11kg thrust
10x5E - 18.5V / 315W / 17.3A / 1,27kg thrust
11x7E - 14.8V / 260W / 17.8A / 1.05kg thrust
12x6E - 14.8V / 276W / 18.7A / 1.20kg thrust
0730583513
20cm of RC experience
#2 Useril este offline   SHAKS
  • Postari: 1059
Postat 09 July 2015 - 11:39 AM
Puff. Vandute..
