The Turnigy HV SBEC 5A Switch Regulator is perfect for large electric models using high voltage power setups. With its high voltage (8-42V) input capability, you will have the option to run this unit off of your main battery or off a separate 2-10S lipo. This voltage regulator will provide a sustained 4A output at 5V or 6V, and has a max current capability of 5A.
Give your RX and servos the power they need with this high quality HV SBEC by Turnigy.
Specs:
Input Voltage: 8-42V (2-10S Lipo)
Output Voltage: 5V or 6V (user selectable)
Max Load: 4A continuous/5A max
Weight: 21g
Dimensions: 59x10x25mm
Pret 50 lei.
