Modelism - RHC Forum: Diverse accesorii aero - Modelism - RHC Forum
#31 Useril este offline   Adyn
  • Postari: 1142
  • Inregistrat: 30-August 07
Postat 17 May 2015 - 10:07 PM
up
#32 Useril este offline   Adyn
  • Postari: 1142
Postat 24 May 2015 - 10:06 AM
up
#33 Useril este offline   Adyn
  • Postari: 1142
Postat 31 May 2015 - 07:06 AM
1- pompa benzina -65 ron
2- pompa electrica Magnum pentru nitro – 65 ron
3- sistem alternator pentru motoare termice Genesys In-Flight Power System -150 ron
4- regulator Mystery 30A – 60 ron
5- regulator Hobbyking 35-40A -55 ron
6- regulator Heli TowerPro H40A- 70 ron
7- regulator TowerPro L40 40A cu card programare – 90 ron
8- regulator Turnigy Sentry 40A - 80 ron
9- elice 3 pale 12x8 Master Airscrew - 30 ron
10- elice 3 pale 13x8 Master Airscrew - 30 ron
11- sistem lumini Turnigy R/C -35 ron
12- sistem lumini neon (2x port glow driver hexTronik +8 neoane diferite culori) -50 ron
13- valva alimentare Magnum – 35 ron
14- filtru alimentare -10 ron
15- deflector toba – 12 ron
16- indicator voltaj acumulator NiMh GWS sau Hextronic -10 ron
17- LiPo monitor GT -10 ron
18- retract mecanic plastic D2,5xL130mm (talpa L27*W25*w12*h16,5) -25 ron
19- retract mecanic plastic D3,5xL140mm (talpa L38*W38*w20*h24) -25 ron
20- placa distributie alimentare quad – 15 ron
21- pirghie reglabila eleroane (L parghie: 40 mm,L portiune filetata: 25 mm) - 12 ron
22- con Graupner aluminiu D64 -30 ron
23- con aluminiu D58 -25 ron
24- ansamblu bechie cu roata 18mm – 20 ron
25- ansamblu bechie - 10ron
26- motor Welgard A28/14/06, 115g (tractiune aprox 1,3kg cu 3s si regulator 40A elice 9x4,5) - 70 ron
27- servo digitale VSD-6 , 0,1s-0,6kgf -4,8V, 6g, 21,2x11,6x22,1- 25ron , 4buc
28- adaptor con E-prop ax motor 2,3mm ax elice 4,7mm – 10 ron, 3buc
29- adaptor con E-prop ax motor 3mm ax elice 8mm – 10 ron, 2buc
30- adaptor con E-prop ax motor 2,3mm ax elice 6mm – 10 ron , 1buc
31- figurine pilot (L65xl40xh75) - 15 ron
32- starter bujie Ofna aluminiu cu baterie sau accumulator R6 (neinclus) – 35 ron
33- bujie OSmax F pt 4 timpi – 35ron, 3buc
34- bujie O’Donnell ODO56OS medium hot -25 ron , 2buc
35- conectori 6,5mm 3 seturi – 30 ron
36- upgrade pt walkera 4#3,4G3 motorADH50 11500kv +regulator 5A 1s – 50 ron
37- motor Turnigy 2204-14T 19g + regulator Mystery 12A – 80 ron
38- motor 1504, KV=2900, 2-3LiPo, 8,8g + regulator Pulso DL11A+,8,5g – 140ron
39- regulator motor perii Jotronik 20A, 4-14,4V, LiPo sau Ni – 40ron
40- imbus 1,3 Align -15 ron
41- imbus 1,5 XTM -40 ron 2 buc
42- servo HK-282 2,2g, 0,08s 4buc- 65ron
43-TURNIGY8-15A UBEC - 65 ron
44-termometru infrarosu Turnigy - 45 ron
45-conectori Deans (mama+tata+termocontractibil) set de 5buc - 10ron
#34 Useril este offline   Adyn
  • Postari: 1142
Postat 07 June 2015 - 06:59 PM
5- regulator Hobbyking 35-40A -50 ron
6- regulator Heli TowerPro H40A- 60 ron
26- motor Welgard A28/14/06, 115g (tractiune aprox 1,3kg cu 3s si regulator 40A elice 9x4,5) - 65 ron
35- conectori 6,5mm 3 seturi –25 ron
39- regulator motor perii Jotronik 20A, 4-14,4V, LiPo sau Ni – 30ron
41- imbus 1,5 XTM -25 ron 2 buc
#35 Useril este offline   Adyn
  • Postari: 1142
Postat 14 June 2015 - 08:53 AM
#36 Useril este offline   Adyn
  • Postari: 1142
Postat 21 June 2015 - 06:13 PM
up
#37 Useril este offline   mikmak
  • Postari: 20
  • Inregistrat: 13-December 13
Postat 25 June 2015 - 01:38 PM
Salut ma interesaza 6 si 17 regulator Heli TowerPro H40A- 60 ron
#38 Useril este offline   Adyn
  • Postari: 1142
Postat 25 June 2015 - 02:15 PM
ambele disponibile
#39 Useril este offline   Adyn
  • Postari: 1142
Postat 02 July 2015 - 11:47 AM
#40 Useril este offline   Adyn
  • Postari: 1142
Postat 09 July 2015 - 11:21 PM
up
#41 Useril este offline   Adyn
  • Postari: 1142
Postat 17 July 2015 - 10:44 PM
up
#42 Useril este offline   Adyn
  • Postari: 1142
Postat 24 July 2015 - 08:28 AM
up
#43 Useril este offline   Adyn
  • Postari: 1142
Postat 31 July 2015 - 12:14 AM
up
#44 Useril este offline   Adyn
  • Postari: 1142
Postat 07 August 2015 - 07:29 AM
up
#45 Useril este offline   Adyn
  • Postari: 1142
Postat 17 August 2015 - 12:32 PM
up
#46 Useril este offline   as2008
  • Postari: 730
  • Inregistrat: 04-May 10
Postat 17 August 2015 - 02:09 PM
Vezi postareaAdyn, la 17 August 2015 - 12:32 PM, a spus:
up
buna ziua , punctul 26 -motor si esc - mai este valabil? . va rog raspuns , stima
#47 Useril este offline   as2008
  • Postari: 730
Postat 17 August 2015 - 02:17 PM
Vezi postareaas2008, la 17 August 2015 - 02:09 PM, a spus:
daca nu mai este valabil atunci punctul 5 ? esc hk
#48 Useril este offline   as2008
  • Postari: 730
Postat 17 August 2015 - 02:19 PM
#49 Useril este offline   Adyn
  • Postari: 1142
Postat 24 August 2015 - 08:10 AM
#50 Useril este offline   Adyn
  • Postari: 1142
Postat 03 September 2015 - 09:27 AM
#51 Useril este offline   Adyn
  • Postari: 1142
Postat 10 September 2015 - 09:28 AM
up
#52 Useril este offline   as2008
  • Postari: 730
Postat 14 September 2015 - 03:36 PM
Vezi postareaAdyn, la 10 September 2015 - 09:28 AM, a spus:
up
buna ziua , poate din intamplare aveti un hub pt elice pliabila 4mm , multumesc
#53 Useril este offline   Adyn
  • Postari: 1142
Postat 24 September 2015 - 09:19 AM
#54 Useril este offline   Adyn
  • Postari: 1142
Postat 01 October 2015 - 02:10 PM
1- pompa benzina -60 ron
3- sistem alternator pentru motoare termice Genesys In-Flight Power System -130 ron
6- regulator Heli TowerPro H40A- 55 ron
7- regulator TowerPro L40 40A cu card programare – 80 ron
13- valva alimentare Magnum – 30 ron
15- deflector toba – 10 ron
18- retract mecanic plastic D2,5xL130mm (talpa L27*W25*w12*h16,5) -20 ron
19- retract mecanic plastic D3,5xL140mm (talpa L38*W38*w20*h24) -20 ron
21- pirghie reglabila eleroane (L parghie: 40 mm,L portiune filetata: 25 mm) - 10 ron
26- motor Welgard A28/14/06, 115g (tractiune aprox 1,3kg cu 3s si regulator 40A elice 9x4,5) - 60 ron
27- servo digitale VSD-6 , 0,1s-0,6kgf -4,8V, 6g, 21,2x11,6x22,1- 20ron , 4buc
35- conectori 6,5mm 3 seturi –20 ron
38- motor 1504, KV=2900, 2-3LiPo, 8,8g + regulator Pulso DL11A+,8,5g – 130ron
42- servo HK-282 2,2g, 0,08s 4buc- 60ron
#55 Useril este offline   Adyn
  • Postari: 1142
Postat 08 October 2015 - 04:05 PM
up
#56 Useril este offline   octaviu
  • Postari: 203
  • Inregistrat: 29-June 14
Postat 11 October 2015 - 08:14 PM
Vezi postareaAdyn, la 10 May 2015 - 01:21 AM, a spus:
up
PC. 36 CEL CU MOTORASUL PT. WALKERA IL VREAU EU. Luam legatura maine. Tavi. Deva. tel. 0723003480
