Modelism - RHC Forum: Corsair F4U 1885 mm - Modelism - RHC Forum
Corsair F4U 1885 mm Modelul de la ESM
#1 Useril este offline   tantar
  • Postari: 2748
  • Inregistrat: 01-November 08
Postat 06 October 2014 - 02:05 PM
Mi-am cumparat proiectul de iarna .
Corsair F4 U de la ESM
Anvergura 1885 mm
Greutate 6,7 kg
Cei de la Big Models recomanda motor clasa 1.2 in 4 timpi , tinand cont ca modelele de la ESM sunt un pic grele de coada m-am decis sa-l motorizez cu SAITO Golden Knight clasa 1.5
  • Imagine atasata: 2014-10-06 11.28.01.jpg
  • Imagine atasata: 2014-10-06 11.35.57.jpg
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#2 Useril este offline   tantar
  • Postari: 2748
Postat 06 October 2014 - 02:06 PM
Asa ar trebui sa arate :
  • Imagine atasata: F4U%20Rear%20quarter%20view.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#3 Useril este offline   flypol
  • Postari: 4092
  • Inregistrat: 01-January 09
Postat 06 October 2014 - 06:37 PM
Da,asa da flotila ! Felicitari si succes!
#4 Useril este offline   LaserCut
  • Postari: 289
  • Inregistrat: 08-November 12
Postat 06 October 2014 - 08:17 PM
Sporuri maxime!
#5 Useril este offline   tantar
  • Postari: 2748
Postat 06 October 2014 - 09:04 PM
Multumesc domnilor .
Fly ce zici , ma primesti in vizita spre sfarsitul lui octombrie ?
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#6 Useril este offline   tantar
  • Postari: 2748
Postat 18 December 2014 - 08:53 PM
Motorul este pe drum
  • Imagine atasata: saito_12_15_2014.jpg
Aceasta postare a fost editata de tantar: 18 December 2014 - 08:55 PM
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#7 Useril este offline   bogdantocaci
  • Postari: 231
  • Inregistrat: 21-March 13
Postat 30 December 2014 - 09:31 AM
Aaaaaa.... bunnnnn.. ati prins gustul la motoarele in 3 cilindri...... mai stiu eu pe cineva,....:-):-):-):-):-):-):-)
  • Postari: 19187
Postat 30 December 2014 - 09:49 AM
Vezi postareatantar, la 06 October 2014 - 09:04 PM, a spus:
Esti binevenit daca opresti si la Craiova in drum :)
#9 Useril este offline   tantar
  • Postari: 2748
Postat 30 December 2014 - 10:14 AM
Domnilor , multumesc .
Bogdane , tu stii de la cine mi se trage cu 3 cilindri , SAITO FA 200 R3...
In cateva zile ajung si retracturile , normal de la ESM generatia 4
  • Imagine atasata: esm-f4u-30cc-g4.jpg
Aceasta postare a fost editata de tantar: 30 December 2014 - 10:16 AM
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#10 Useril este offline   tantar
  • Postari: 2748
Postat 30 December 2014 - 10:18 AM
Vezi postarearenatoa, la 30 December 2014 - 09:49 AM, a spus:
Pai , cat ar fi sa deviez un pic ,,,, dar poate trec in drum spre Drobeta .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#11 Useril este offline   tantar
  • Postari: 2748
Postat 01 January 2015 - 12:07 PM
Au ajuns retracturile , generatia asta se alimenteaza cu pack separat si se inchid secvential :
https://www.youtube....e&v=FyZ8Zm94y5k
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#12 Useril este offline   edisultan
  • Postari: 2105
  • Inregistrat: 16-March 08
Postat 01 January 2015 - 01:21 PM
Interesant :clapping: , abia aştept să la văd pe viu.
Sultan Eduard
  • R.D.
  • Postari: 5484
Postat 03 January 2015 - 04:00 PM
Vezi postareatantar, la 01 January 2015 - 12:07 PM, a spus:
Foarte atractive retracturile electrice ( scapi de furtune, supape , butelie , unitate etc ) DAR .. trebuie studiate putin
caci am impresia ca nu au nici un sistem de zavorare si toata forta este preluate de pasul filetului de pe axul motorului si
in caz de ... ceva ... se barbiereste tare usor ( nu stiu exact care se strica : filetul de pe ax sau cel din bucsa dar rezistent nu este )
.. unul din colegi a patit asta si la cel de la Robart electric inca de la primele zboruri ....
In rest .. spor la construit si grija cu motorul sa nu se incinga ca daca se opreste in aer vine mai greu fara motor la aterizare ... trebuie ceva
experienta pe astfel de modele ( warbird-uri mai mari .. nu din spuma ) ....
A fost unul la Adunati care .... a decedat destul de repede ( tot motor radial dar parca cu 5 cilindrii - nu sunt sigur .. nu l-am vazut decat in poze si nu mai retin )
#14 Useril este offline   tantar
  • Postari: 2748
Postat 04 January 2015 - 01:51 PM
Vezi postareaREAL DESIGN, la 03 January 2015 - 04:00 PM, a spus:
Multumesc pentru sfaturi . Zavorarea a fost una din conditiile pentru care le-am luat , toate din generatia 4 au ,le-am mai avut sub ochi si pe cele de la :https://wingspanretracts.3dcartstores.com/LGR610T
Avantajul este ca cele de la wingspan se deschid la 100 grade si pot prelua aterizari mai dure , dar .... ESM a castigat
Mai am ceva pasari mari, am adunat un pic de experienta .
Stiu Corsair'ul de la Adunati , este unul de la Hangar 9 motorizat cu un motor in stea , la aceasa ora proprietarul la dotat cu unul in 3 cilindri .
Problema la cele din tipul asta este ca cilindrii pozitionati inferior se incing mai tare decat cei pozitionati superiori , asa ca reglajele de alimentare trebuiesc facute diferit .
Aceasta postare a fost editata de tantar: 04 January 2015 - 01:54 PM
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#15 Useril este offline   tantar
  • Postari: 2748
Postat 04 January 2015 - 02:00 PM
Saito FA 200 R3 setup .
https://www.youtube....h?v=qM3QmSPuX08
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#16 Useril este offline   tantar
  • Postari: 2748
Postat 06 January 2015 - 01:01 PM
My precious !
  • Imagine atasata: 2015-01-06 12.44.17.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#17 Useril este offline   tantar
  • Postari: 2748
Postat 06 January 2015 - 01:03 PM
  • Imagine atasata: 2015-01-06 12.44.39.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#18 Useril este offline   tantar
  • Postari: 2748
Postat 06 January 2015 - 01:04 PM
Aprinderea ar trebui sa ajunga in app 10 zile .
  • Imagine atasata: 2015-01-06 12.44.51.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#19 Useril este offline   Teo-Costin
  • T.C.I.
  • Postari: 1399
  • Inregistrat: 13-June 07
Postat 06 January 2015 - 01:05 PM
Eheeee ..... ca tare frumusel mai este EL, sa-l stapinesti sanatos si cat mai multe zboruri sa ai cu el.
Sa pui un filmulet cand il pornesti sa-l aud si eu cum papa nitro.
#20 Useril este offline   tantar
  • Postari: 2748
Postat 06 January 2015 - 01:13 PM
Vezi postareaTeo-Costin, la 06 January 2015 - 01:05 PM, a spus:
Desigur ,de sapatamana viitoare ma apuc sa fac standul , si imediat ce vine aprinderea ....
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#21 Useril este offline   GigiGL
  • Postari: 2109
  • Inregistrat: 10-March 11
  • Interests:Aero
Postat 06 January 2015 - 04:07 PM
Bravo Tantare! Astept cu nerabdare sa ne delectezi privirile si urechile! La multi ani si spor la mesterit! :drinks:
Gigi Sterian
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
#22 Useril este offline   tantar
  • Postari: 2748
Postat 06 January 2015 - 04:37 PM
Vezi postareaGigiGL, la 06 January 2015 - 04:07 PM, a spus:
Multumesc Gigi , ne vedem pe camp la zbor .
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#23 Useril este offline   tantar
  • Postari: 2748
Postat 27 January 2015 - 07:26 PM
Din lipsa timpului avansez in pasi mici .
Am montat trenurile principale .
  • Imagine atasata: 2015-01-27 18.01.49.jpg
  • Imagine atasata: 2015-01-27 17.57.31.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#24 Useril este offline   tantar
  • Postari: 2748
Postat 27 January 2015 - 07:28 PM
Am terminat standul , am primit si aprinderea . Din viteza nu am comandat furtune noi , am doar unul cu diam de 2 mm la interior , asa ca rodajul mai asteapta .
Motorul intra perfect in canopie .
  • Imagine atasata: 2015-01-27 18.29.09.jpg
  • Imagine atasata: 2015-01-27 18.06.07.jpg
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#25 Useril este offline   bogdantocaci
  • Postari: 231
Postat 05 February 2015 - 04:42 PM
Ai rezolvat-o cu standul,... Dar am o observație, dacă îmi permiți, vad din poza ca ai ales ca și material bradul, un material f. moale, lateralele pa care sta prins asa zisul panou de foc sunt tăiate cu fibra pe orizontal asta face ca din cauza cuplului motor și a trepidatiilor ca cedeze lemnul sa se spargă pe fibra cum se zice, eu personal asi fi ales același material din care este făcut standul, placaj multi
strat
#26 Useril este offline   tantar
  • Postari: 2748
Postat 05 February 2015 - 05:22 PM
Good point . O sa folosesc standul doar pentru prima pornire și apoi îl montez pe avion pentru rodaj.
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#27 Useril este offline   incepatoru
  • Girls In Your City - Anonymous Casual Dating - No Verify
  • Postari: 2869
  • Inregistrat: 30-May 09
  • Gender:Female
  • Interests:Girl,Woman
Postat 05 February 2015 - 06:36 PM
Vezi postareatantar, la 05 February 2015 - 05:22 PM, a spus:
...daca nu zici :girl_devil: este la mine in dotare ..mostenire.. :hi:
https://SecreLocal.com - Private Dating Chat - No Verify - Anonymous Sex Dating - Secret Dating
#28 Useril este offline   incepatoru
  • Postari: 2869
  • Gender:Female
Postat 12 February 2015 - 09:20 AM
...breee @TANTAR pornisi dihania aia de SAITO in 3 pestoane??
#29 Useril este offline   tantar
  • Postari: 2748
Postat 12 February 2015 - 09:25 AM
Vezi postareaincepatoru, la 12 February 2015 - 09:20 AM, a spus:
A si dat un zbor ...
Trex 700 V BAR
FW 190 HYPE
Futaba T-8FG x 2
#30 Useril este offline   GigiGL
  • Postari: 2109
  • Interests:Aero
Postat 12 February 2015 - 08:17 PM
Vezi postareatantar, la 12 February 2015 - 09:25 AM, a spus:
Pe 'mucles' care va sa zica... ca de obicei! :drinks:
Gigi Sterian
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
