Modelism - RHC Forum: Vand accesorii modelism - Modelism - RHC Forum
Vand accesorii modelism Sisteme radio,packuri,combo,gyro,antene...etc
#1 Useril este offline   vvrest
  • Postari: 907
  • Inregistrat: 29-September 09
Postat 30 September 2014 - 11:51 PM
1.Platforma dezvoltare STM32F3 DISCOVERY, cortex M4 noua plus barometru BMP085 - 70 RON
2.Antena 2.4Ghz 5db - 15 RON
3.Antena patch 2.4Ghz 7db - 20 RON
4.Placa captura audio video USB EASYCAP (buna pentru FPV pe laptop)- 30 RON
5.Cadru central octocopter format din doua bucati sticlotexxtolid (Mikrokopter Octo2) - 80 RON
6.Pack Life 9.9V 1800mAh 5C TX nou - 50 RON
7.Combo brushless sensorless 1/10 ETRONIX PHOTON SBS 2.0 (motor 9T 4370KV, ESC 60A, card programare) folosit de 2 ori - 250 RON
8.ESC brushless sensorless 1/10 60A ETRONIX PHOTON SBS 2.0 plus card programare folosite de cateva ori - 150 RON
9.Combo brushless sensorless 1/10 format din ESC TRACKSTAR 60A plus motor DRAGON-RC 3606KV folosite de 2 ori - 300 RON
10.ESC brushless sensored 60A Speed Passion (echipare originala Team Durango DEX210), nu are marsarier din fabrica - 100 RON
11.Suport caroserie 1/10 pe baza de arici - 50 RON
12.Packuri TIGERS 1S 600mAh (4buc)- 40RON
13.Roti MST echipate drift, jante offset 6MM plus cauciucuri (model disc frana) - 120 RON
14.Set doua motoare brushless gimbal - 60 RON
15.Gyro TELEBEE - 40 RON
16.Gyro MST LSD - 60 RON
17.Statie AXIAL 2.4 Ghz plus receptorul aferent (la statie lipseste usita culisanta de deasupra trimurilor) folosite foarte putin- 130 RON
18.Pack LRP BIG-MAMA 1/10 2S 7200mAh 50/100C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 150 RON
19.Pack Turnigy nano-tech 2S 6000mAh 65/130C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 100 RON
20.Egalizor lipo 1-6S TRAKPOWER - 25 RON
21.Egalizor lipo 1-6S ROBBE - 25 RON
22.Incarcator 10A TEAM CHECKPOINT TC1030 (varianta cu backlight a celebrului ICE) plus egalizor lipo 1-6S robbe foarte putin folosit- 200 RON
23.Pack GENS 3S 1000mAh folosit de 2 ori - 35 RON
24.Pack LIGHTMAX 3S 1300mAh folosit de cateva ori - 35 RON
25.Pack TURNIGY NANO_TECH 3S 850mAh folositi de cateva ori - 35 RON/buc (2 buc disponibile)
26.Pack TX Ni-MH 800mAh 7.2V fara mufa (nou)- 20 RON
27.Pack lipo TX LIGHTMAX 2500mAh folosit de cateva ori - 60RON
28.Caroserie HPI Porsche crapata putin in spate si reparata cu solutie speciala lexan - 60 RON
29.Caroserie TAMIYA BMW E30 crapata putin in spate si reparata cu solutie speciala lexan (vopsita exterior)- 60 RON
30.Statie ABSIMA CR4T 2.4Ghz 4 canale touch screen plus 2 receptoare si setul de senzori pentru telemetrie, impecabila, folosita de cateva ori, folia originala pe ecran - 500RON
31.Pale carbon multicopter 14x5,5 (2 seturi CW-CCW) - 100 RON (ambele seturi)
32.Cauciucuri drift PVC - 40 RON
33.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele gri, o janta a fost usor atninsa si reparata cu putina oja)- 130 RON
34.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele albe, nu sunt zgariate doar murdare de negreala de pe la caroserii)- 140 RON
35.Roti HPI BBS offset 3mm cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele negre)- 120 RON
36.Set eleron-intercooler-toba - 25 RON/set (doua seturi disponibile)
37.Receptor SPEKTRUM AR6110e folosit de 2 ori - 100 RON
38.Receptor SPEKTRUM AR7000 plus satelitul aferent, folosite ocazional - 150 RON/ set (3 seturi disponibile)
39.Sistem telemetrie SPEKTRUM TM1000 (senzori curent si temperatura inclusi) - 100 RON
40.Receptor FRSKY D8R-II PLUS noi - 80RON/buc (2 buc disponibile)
41.Mini flight control board Features:
• 7CH DSM2 Compatible Receiver (PPM SUM)
• Self-voltage checking
• FTD1 protection
• ATMEGA328P Microcontroller
• MPU6050 Accelerometer and Gyro
• BMP085 Digital Barometric Sensor
• HMC5883L Digital Manometer/Compass
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
• GPS Port (GPS not included)
• OLED Screen Port (OLED not included)
Pret 80 RON/buc (Disponibile 2 buc)
42.Multiwii MINI OLED Display Module Dual I2C 128x64 Dot ( MWC MINI )- 20 RON
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 200 RON setul
44.Pack ZIPPY 3s 5000mAh (a fost atinsa de suflanta fara a-i afecta functionalitatea- 100Ron
45.Pack 3S 2200mAh VOLTZ - 100 RON setul
46.Power board microcopter - 10 RON/buc (disponibile 2 buc)
47.Neck strap aluminium support - 20 RON/buc (disponibile 2 buc)
48.Prelungitoare stickuri m3 - 20 RON
Pozele produselor se pot gasi in galeria de mai jos:
https://picasaweb.go...CMjG2Z285reQeg#
Contact: 0721846149
Se pot expedia si catre alte localitati numai prin intermediul courieratului rapid, exclus posta din cauza programului de munca.
#2 Useril este offline   dumitrescu.petrisor
  • Postari: 146
  • Inregistrat: 10-January 14
Postat 01 October 2014 - 12:11 AM
Salut, vreau sa rezerv si eu :
- pct 3
- pct 40 ambele bucati
- pct 47 o bucata
Te sun maine sa-ti dau datele de contact
Cu respect,
Petrisor
#3 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 12:14 AM
Vezi postareadumitrescu.petrisor, la 01 October 2014 - 12:11 AM, a spus:
- pct 3
- pct 47 o bucata
Cu respect,
Petrisor
In regula, le iau la mine maine si astept telefonul tau ca sa ti le si expediez.
Cu respect.
#4 Useril este offline   ivan alexandru
  • Postari: 651
  • Inregistrat: 09-March 10
Postat 01 October 2014 - 08:42 AM
ce roller este cel din poza?sprint 2?
1:10 MST XS-Drift, Ford mustang cabrio Reely 1:10, Rc plane Piper J Cub 2.6m, Traxxas E-MAXX brushless, Axial SCX 10
#5 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 09:02 AM
Vezi postareaivan alexandru, la 01 October 2014 - 08:42 AM, a spus:
http://www.rhcforum....iguratie-drift/
#6 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 09:06 AM
4.Placa captura audio video USB EASYCAP (buna pentru FPV pe laptop)- 30 RON (rezervata @draude80)
2.Antena 2.4Ghz 5db - 15 RON (rezervat @RedDevil)
12.Packuri TIGERS 1S 600mAh (4buc)- 40RON (rezervat @RedDevil)
Aceasta postare a fost editata de vvrest: 01 October 2014 - 09:08 AM
#7 Useril este offline   nxpress
  • Postari: 58
  • Inregistrat: 12-October 13
Postat 01 October 2014 - 09:49 AM
iau eu stm-u (p1)
noob
#8 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 10:00 AM
Vezi postareanxpress, la 01 October 2014 - 09:49 AM, a spus:
iau eu stm-u (p1)
1.Platforma dezvoltare STM32F3 DISCOVERY, cortex M4 noua plus barometru BMP085 - 70 RON (rezervat @nxpress)
Astept date livrare.
Cu respect.
#9 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 01:44 PM
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 200 RON setul (set rezervat @ XoreX EkraM)
#10 Useril este offline   vvrest
  • Postari: 907
Postat 01 October 2014 - 04:03 PM
5.Cadru central octocopter format din doua bucati sticlotexxtolid (Mikrokopter Octo2) - 80 RON (rezervat @worms)
#11 Useril este offline   vvrest
  • Postari: 907
Postat 08 October 2014 - 11:13 AM
33.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele argintii, o janta a fost usor atninsa si reparata cu putina oja)- 130 RON
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
47.Neck strap aluminium support - 20 RON/buc (disponibila 1 buc)
48.Prelungitoare stickuri radiocomanda metric 3 (Turnigy, Spektrum, FrSky) - 20 RON
La lista de mai sus se mai adauga:
49.Monitor FPV 7inch 800x600 12V stare foarte buna - 100 RON
50.ESC brushed AXIAL AE-1 (Forward and Reverse Function, Motor: 15T or greater, Rated/Peak Current-Forward: 60A/150A) - 70 RON
51.3x Servo HITEC HS-635 HB, foarte putin folosite - 200 RON (toate 3)
Pozele listei de produse actualizate se pot gasi in galeria de mai jos:
https://plus.google....=CMjG2Z285reQeg
Contact: 0721846149
Aceasta postare a fost editata de vvrest: 08 October 2014 - 11:17 AM
#12 Useril este offline   vvrest
  • Postari: 907
Postat 08 October 2014 - 09:14 PM
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
52.Set 4 jante drift 1/10 6mm noi au fost doar montate cauciucuri pe ele sa vad cum cad pe caroserie - 60 RON
Contact: 0721846149
#13 Useril este offline   vvrest
  • Postari: 907
Postat 29 October 2014 - 08:50 AM
6.(2x) Pack Life 9.9V 1800mAh 5C TX nou - 50 RON/buc
7.Combo brushless sensorless 1/10 ETRONIX PHOTON SBS 2.0 (motor 9T 4370KV, ESC 60A, card programare) folosit de 2 ori - 235 RON
8.ESC brushless sensorless 1/10 60A ETRONIX PHOTON SBS 2.0 plus card programare folosite de cateva ori - 135 RON
9.Combo brushless sensorless 1/10 format din ESC TRACKSTAR 60A plus motor DRAGON-RC 3606KV folosite de 2 ori - 275 RON
14.Set doua motoare brushless gimbal - 50 RON
18.Pack LRP BIG-MAMA 1/10 2S 7200mAh 50/100C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 135 RON
19.Pack Turnigy nano-tech 2S 6000mAh 65/130C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 90 RON
27.Pack lipo 3s TX LIGHTMAX 2500mAh folosit de cateva ori - 50RON
28.Caroserie HPI Porsche crapata putin in spate si reparata cu solutie speciala lexan - 50 RON
29.Caroserie TAMIYA BMW E30 crapata putin in spate si reparata cu solutie speciala lexan (vopsita exterior)- 50 RON
33.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele argintii, o janta a fost usor atninsa si reparata cu putina oja)- 120 RON
34.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele albe, nu sunt zgariate doar murdare de negreala de pe la caroserii)- 130 RON
35.Roti HPI BBS offset 3mm cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele negre)- 110 RON
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
Pret 75 RON/buc (Disponibile 2 buc)
45.(2x) Pack 3S 2200mAh VOLTZ - 100 RON setul
51.3x Servo HITEC HS-635 HB, foarte putin folosite - 150 RON (toate 3)
52.Set 4 jante drift 1/10 6mm noi au fost doar montate cauciucuri pe ele sa vad cum cad pe caroserie - 50 RON
La lista de mai sus se adauga:
53.Sistem nou RX-TX auto/navo Dragon RC 2.4 GHz in 3 canale DTS-1 cu ecran LCD iluminat albastru:
- memorie 10 modele
- revers servo pentru acceleratie si directie
- EPA pentru acceleratie, directie si al-3-lea canal
- functie ABS
- EXPO pentru acceleratie, directie si al-3-lea canal
- Dual Rate pentru acceleratie si directie si al-3-lea canal
- triming pentru acceleratie si directie
- Failsafe
- Receptor in 4 canale
Sistemul a venit la pachet cu un onroad de la Serpent care s-a dat intre timp si de aceea nu are ambalaj.
Pe canalul 3 are switch cu 3 pozitii cu posibilitate adjustare endpointuri(recomandat sistem lumini sau winch crawling/scale)
Pret : 200 RON
54. Incarcator nou turnigy Dlux 1-6S 80W (10A):
• High power 80W charger
• Delta-peak sensitivity (NiMH/NiCd)
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents
• Fast charge & storage charge function
• Time limit function
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 5 packs in memory)
Specs:
Input Voltage: 10~18v DC
Charge Current Range: .2~10.0A
Ni-MH/NiCd Cells: 1~16
Li-ion/Poly Cells: 1~6
Pb Battery Voltage: 2~24v
Pret: 150 RON
Contact: 0721846149
#14 Useril este offline   vvrest
  • Postari: 907
Postat 29 October 2014 - 11:25 AM
S-a dus edit-ul si mai erau de adaugat punctele 55 si 56 ...
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
- memorie 10 modele
- functie ABS
- Failsafe
Pret : 200 RON
Specs:
Pret: 150 RON
55.Sistem nou (doar probat) RX-TX auto/navo Reflex Wheel Pro II LCD (blue backlight) 2,4 GHz FHSS BEC (3-channel 2.4 GHz transmitter, 5-channel receiver and BEC):
- memorie 15 modele
- reverse pentru toate canalele
- EPA pentru acceleratie, directie si al-3-lea canal auxiliar
- functie ABS
- EXPO pentru acceleratie si directie
- trimming pentru acceleratie si directie
- BEC receptor cu protectie pentru subvoltare
- Voltaj recomandat receptor 4.8 - 7.2 V (bun pentru servourile high voltage)
- Failsafe pentru acceleratie
- Socket incarcare acumulator
Pret: 250 RON (voi adauga pozele reale in galerie dupa amiaza)
56.Sistem RX-TX auto/navo folosit de 5 ori Turnigy 3XS FHSS 2.4GHz 3 Channel Radio:
Features:
• EPA adjustment
• Sub trim
• Dual rates
• Servo reversing
• Programmable steering curve
• Programmable throttle curve
• ABS (anti-lock braking)
• 15 model memory
• Programmable steering/throttle speed
• Throttle hold function
• Integrated timer
Pret: 200 RON (voi adauga pozele reale in galerie dupa amiaza)
Contact: 0721846149
#15 Useril este offline   vvrest
  • Postari: 907
Postat 07 November 2014 - 11:28 AM
Disponibile in continuare:
11.2x Suport caroserie 1/10 pe baza de arici - 50 RON/set
36.Set eleron-intercooler-toba - 25 RON(Disponibil setul cu: toba simpla, eleronul negru si intercoolerul argintiu)
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 199 RON setul
- memorie 10 modele
- functie ABS
- Failsafe
Pret : 200 RON
- memorie 15 modele
- functie ABS
Features:
• EPA adjustment
• Sub trim
• Dual rates
• Servo reversing
• 15 model memory
• Integrated timer
Contact: 0721846149
#16 Useril este offline   vvrest
  • Postari: 907
Postat 14 November 2014 - 04:09 PM
Up, accept schimburi si cu receptoare auto 2.4Ghz spektrum sau sanwa (airtronics).
#17 Useril este offline   vvrest
  • Postari: 907
Postat 25 November 2014 - 02:46 PM
6.(2x) Pack Life 9.9V 1800mAh 5C TX nou - 45 RON/buc
7.Combo brushless sensorless 1/10 ETRONIX PHOTON SBS 2.0 (motor 9T 4370KV, ESC 60A, card programare) folosit de 2 ori - 230 RON
8.ESC brushless sensorless 1/10 60A ETRONIX PHOTON SBS 2.0 plus card programare folosite de cateva ori - 130 RON
9.Combo brushless sensorless 1/10 format din ESC TRACKSTAR 60A plus motor DRAGON-RC 3606KV folosite de 2 ori - 260 RON
10.ESC brushless sensored 60A Speed Passion (echipare originala Team Durango DEX210), nu are marsarier din fabrica, vine fara ventilator si condensator - 60 RON
11.1xSet suporti caroserie 1/10 pe baza de arici - 45 RON/set
13.Roti MST echipate drift, jante offset 6MM plus cauciucuri (model disc frana) - 110 RON
18.Pack LRP BIG-MAMA 1/10 2S 7200mAh 50/100C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 130 RON
33.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele argintii, o janta a fost usor atninsa si reparata cu putina oja)- 115 RON
34.Roti drift Yokomo offset 9mm(spate) si 5mm(fata) cu cauciucuri HPI #4406 - T-DRIFT TIRE 26mm stare foarte buna (cele albe, nu sunt zgariate doar murdare de negreala de pe la caroserii)- 115 RON
38.Receptor SPEKTRUM AR7000 plus satelitul aferent, folosit ocazional - 150 RON/ set (2 seturi disponibile)
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 180 RON (setul format din ambele bucati, nu se descompleteaza)
45.(2x) Pack 3S 2200mAh VOLTZ - 80 RON setul
48.Prelungitoare stickuri radiocomanda metric 3 (Turnigy, Spektrum, FrSky) - 20 RON (setul)
51.3x Servo HITEC HS-635 HB, foarte putin folosite - 140 RON (toate 3)
- memorie 10 modele
- functie ABS
- Failsafe
Pret : 200 RON
Contact: 0721846149
Accept schimburi si cu receptoare auto 2.4Ghz Spektrum DSM2 sau Sanwa (Airtronics).
Aceasta postare a fost editata de vvrest: 25 November 2014 - 02:48 PM
#18 Useril este offline   vvrest
  • Postari: 907
Postat 04 December 2014 - 03:32 PM
6.(2x) Pack Life 9.9V 1800mAh 5C TX nou - 40 RON/buc
8.ESC brushless sensorless 1/10 60A ETRONIX PHOTON SBS 2.0 plus card programare folosite de cateva ori - 125 RON
9.Combo brushless sensorless 1/10 format din ESC TRACKSTAR 60A plus motor DRAGON-RC 3606KV folosite de 2 ori - 250 RON
10.ESC brushless sensored 60A Speed Passion (echipare originala Team Durango DEX210), nu are marsarier din fabrica, vine fara ventilator si condensator - 50 RON
14.Set doua motoare brushless gimbal - 50 RON(pentru set)
18.Pack LRP BIG-MAMA 1/10 2S 7200mAh 50/100C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 125 RON
27.Pack lipo 3s TX(statie) LIGHTMAX 2500mAh folosit de cateva ori - 50RON
32.Cauciucuri drift PVC - 35 RON
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 175 RON (pentru setul de 2 buc) (setul format din ambele bucati, nu se descompleteaza)
49.Monitor FPV 7inch 800x600 12V stare foarte buna - 90 RON
51.3x Servo HITEC HS-635 HB, foarte putin folosite - 120 RON (toate 3)
- memorie 10 modele
- functie ABS
- Failsafe
Pret : 200 RON
Contact: 0721846149
#19 Useril este offline   alex 88
  • Postari: 124
  • Inregistrat: 22-November 14
Postat 10 December 2014 - 05:07 PM
Ma intereseaza 9in1 usb r/c sau interfata usb care suporta
simulator phoenix rc .ms frumos
#20 Useril este offline   vvrest
  • Postari: 907
Postat 10 December 2014 - 06:42 PM
... 75RON ...
Pentru ce statie vrei s-o folosesti?
#21 Useril este offline   vvrest
  • Postari: 907
Postat 22 December 2014 - 10:40 AM
9.ESC brushless sensored TRACKSTAR 60A folosit de 2 ori - 150 RON
18.Pack LRP BIG-MAMA 1/10 2S 7200mAh 50/100C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 120 RON
19.Pack Turnigy nano-tech 2S 6000mAh 65/130C folosit dar in stare buna, ff putin umflat, asa l-am luat de pe forum asa a ramas, se echilibreaza perfect - 85 RON
• FTD1 protection
• C8051F330 MCU
• CYRF69103 Radio
• Dual IIC Ports
• UART
43.Packuri LRP 3S hardcase 4300mAh , cel de sus putin umflat, asa le-am luat de pe forum asa au ramas, se echilibreaza perfect- 160 RON (pentru setul de 2 buc) (setul format din ambele bucati, nu se descompleteaza)
- memorie 10 modele
- functie ABS
- Failsafe
Pret : 200 RON
54.Motor brushless Novak Ballistic Spec Brushless Motors 10.5T - 200 RON
55.Statie Spektrum DX3S, stare impecabila, cumparata de noua (in cutia originala, inclusiv receptor SR3300t cu setul complet de telemetrie) - 650 RON
56.Statie Sanwa MT-4, stare impecabila (in cutia originala cu toate accesoriile incluse in packet, receptor RX381, acumulator lipo cadou) - 800 RON
Contact: 0721846149
#22 Useril este offline   Tealk
  • Fly Low, Go Fast, Turn Left
  • Postari: 763
  • Inregistrat: 13-May 09
  • Interests:Aero, Navo
Postat 10 January 2015 - 03:16 PM
salut,
mai e valabil?
Cessna 182 2.2m
DJI Mini 4 PRO
Hornet Tunel Hull Sprint F1
Fly Low. Go Fast. Turn Left.
Do. Or do not. There is no try.
#23 Useril este offline   vvrest
  • Postari: 907
Postat 10 January 2015 - 10:34 PM
Da, este inca disponibil.
#24 Useril este offline   dumitrescu.petrisor
  • Postari: 146
Postat 10 January 2015 - 10:48 PM
ce model sau ce diametru au motoarele de la pct 14 ?
Petrisor
#25 Useril este offline   Rares
  • Postari: 651
Postat 10 January 2015 - 11:58 PM
Salut! Te rog, fa un pachet cu una bucata poz 6 si 47. Adica pack tx 1800LiFe, 9.9V si neck strap-ul aluminiu. Adresa o sa o gasesti pe mesageria privata. Multumesc.
Aceasta postare a fost editata de Rares: 10 January 2015 - 11:58 PM
#26 Useril este offline   vvrest
  • Postari: 907
Postat 11 January 2015 - 05:43 AM
Vezi postareadumitrescu.petrisor, la 10 January 2015 - 10:48 PM, a spus:
Petrisor
Salut, sunt motoare rc-timer seria 5010, gasesti pe net toate infornatiile de care ai nevoie.
#27 Useril este offline   vvrest
  • Postari: 907
Postat 11 January 2015 - 05:44 AM
Vezi postareaRares, la 10 January 2015 - 11:58 PM, a spus:
Salut Rares, vezi pm te rog.
#28 Useril este offline   kepikanu
  • Postari: 154
  • Inregistrat: 02-September 13
  • Interests:Aero-Navo
Postat 11 January 2015 - 10:44 PM
Imi poti spune ce dimensiuni are :
#29 Useril este offline   vvrest
  • Postari: 907
Postat 12 January 2015 - 05:30 AM
Vezi postareakepikanu, la 11 January 2015 - 10:44 PM, a spus:
100x28x23mm
#30 Useril este offline   NAVOMARIUS
  • MARIUS
  • Postari: 4699
  • Inregistrat: 04-October 10
  • Interests:AEROMODELE
Postat 12 January 2015 - 05:56 AM
Cand ai timp treci pe la mine si lasa asta:
Tel 0740850863
Grea 6--POZE CET VEST
