Modelism - RHC Forum: Nevoie de ajutor pentru piese si CNC pt automodel de la zero. - Modelism - RHC Forum
Nevoie de ajutor pentru piese si CNC pt automodel de la zero. Constructie automodel 1/10
#1 Useril este offline   Mariannu
  • Postari: 6
  • Inregistrat: 07-September 13
Postat 21 February 2014 - 08:08 PM
Salut.
Vreau sa fac un automodel 1/10 de la zero si am nevoie de urmatoarele piese daca ma puteti ajuta sa le gasesc la un pret acceptabil as fi recunoscator.
Toate piesele sunt verificate dar din pacate nu le-am gasit in Romania sau la un pret accesibil.
Caut:
CNC aluminiu
Debitare Fibra carbon
(detin model CAD pentru toate piesele)
Piese: BUC
Button Head Allen Bolt 2x6mm 11
Button Head Allen Bolt 3x6mm 1
Button Head Allen Bolt 3x8mm 18
Button Head Allen Bolt 3x10mm 8
Button Head Allen Bolt 3x16mm 2
Button Head Allen Bolt 3x20mm 4
Button Head Allen Bolt 3x25mm 4
Countersunk Socket Allen Bolt 3x8mm 14
Countersunk Socket Allen Bolt 3x10mm 16
Countersunk Socket Allen Bolt 3x12mm 1
Allen Bolt Socket Cap Screw M1.6x6 4
Allen Bolt Socket Cap Screw M2.5x25 2
Cup Point Grub Screws M2x2 17
Cup Point Grub Screws M2x4 4
Cup Point Grub Screws M2x8 4
Hex Full Nuts M3 13
Nyloc Lock Nuts M2.5 2
Nyloc Lock Nuts M3 8
Nyloc Lock Nuts Flanged M4 4
Ball Stud D4.8x6 26
Ball Stud D4.8x10 2
Stabilizer balls 6.8 4
Ball Cup D4.8 16
Rulment 10x15x4 8
Rulment 5x10x4 6
Rulment 3x6x2.5 8
Rulment 5x8x2.5 4
Axial Ball Thrust 2.5x6x3 4
O-ring silicon 8x1.5 mm 4
O-ring silicon 5x1.5 mm 4
O-ring silicon 3x2 mm 12
Turnbuckle 30mm 5
Turnbuckle 40mm 2
Pinion Spur 106T (64DP) 1
Pinion Spur 110T (64DP) 1
Pinion Spur 116T (64DP) 1
Pinion 25T (64DP) 1
Pinion 29T (64DP) 1
Pinion 31T (64DP) 1
Servo saver/arm 1
Ceramic Diff Ball 3mm 20
Springs set d14x25mm 4
Diff Spring 2.5-3x6.5-7mm 1
Carbon Fiber Pante 200x300x2.5mm 1 minim 2 placi de 100x300x2.5mm
Curele S3M cu urmatoarele specificatii
latime curea= 4mm sai mai mult, am inteles ca se pot taia la dimensiunea dorita
Dinti Lungime Buc
62 186 1
96 286 1
115 344 2
134 401 1
167 501 1
Belt Pulley for S3M 4.5mm latimea canalului curelei din aluminiu care vor urma a fi prelucrate la cnc pt. a se ajunge la specificatiile dorite, cu:
19 dinti 1
20 dinti 1
39 dinti 2
Asta-i tot. :yahoo:
#2 Useril este offline   marincas23
  • Postari: 64
  • Inregistrat: 21-January 14
Postat 25 February 2014 - 04:44 PM
Ai incercat sa cauti si pe ##########?
Aceasta postare a fost editata de sandrei: 26 February 2014 - 01:50 PM
