Cu urmatoarele caracteristici:
Size Category: Ultra Micro servo
Type: Digital
Application: Ultra-Micro Aircraft
Speed: 0.12sec
Torque: 80g
Voltage: 3.7V~4.2V
Dimensions: 20.8 x 15 x 11mm
Weight: 1.7 g
Gear Type: Nylon
Connector type: Micro JST
Am doua bucati. Pret 45 RON/bucata.
Motor brushless ultra usor 5g !!! pentru aeromodel
Kv: 2400rpm/v
Max current (Burst): 3.9A
Max current (suststained): 3.0A
Max Power: 40W @ 11.1v (3S)
Shaft: 1.5mm
Weight: 5g
ESC: 5~8A
Cell count: 2s~3s Lipoly
Mount type: Tri-hole firewall mount (15mm width between mount holes)
Connection: Loose wire (for direct soldering)
Prop Test Data:
3.75x3 - 7.4V / 10W / 1.4A / 56g thrust
3.75x3 - 11.1V / 25W / 2.3A / 97g thrust
4.5x4.5 - 7.4V / 16W / 2.2A / 80g thrust
4.5x4.5 - 11.1V / 36W / 3.3A / 112g thrust
5x5 - 7.4V / 19W / 2.6A / 68g thrust
5x5 - 11.1V / 39W / 3.5A / 92g thrust
Am o bucata. Pret 90 RON/bucata.
Produsele sunt absolut noi, au fost desfacute pentru a fi testate ca merg, se poate verifica pe foaia de livrare.
Predare personala in Bucuresti.
Number of downloads: 118 -
