Modelism - RHC Forum: Vand Navomodel de viteza TRXXAS SPARTAN - Modelism - RHC Forum
Vand Navomodel de viteza TRXXAS SPARTAN Cel mai rapid navomodel RTR din lume
#1 Useril este offline   ganciurobert
  • Postari: 308
  • Inregistrat: 23-August 12
  • Gender:Female
  • Interests:Girl, Woman
Postat 03 September 2013 - 05:20 PM
Dupa cum scrie si titlul vand Navomodel de viteza TRXXAS SPARTAN cel mai rapid navomodel RTR din lume NOU + 2 acumulatori LI-PO Gens Ace 3S 5300mah+Incarcator acumulatori ECO SIX 80W toate abslut noi nefolosite cu fact si garantie.
Cel mai rapid navomodel RTR din lume: Traxxas SPARTAN® Brushless Muscleboat!
Pret 2500 ron.
50+mph cu 6s LiPo!
Deep-V real 36”
Sistem brushless Velineon® cu noul ESC VXL-6s Marine
Gata de cursa® cu acumulatori Traxxas Power Cell NiMH inclusi
Radiocomanda TQi 2.4GHz High Output cu Traxxas Link™
QUICK FEATURES ON SPARTAN (#5707)
36" deep-V hull for stable high-speed performance
Water-cooled, waterproof VXL-6s Marine speed control
6S LiPo compatible with built-in Low-Voltage Detection
Traxxas High-Current Connectors
Velineon 540XL high-output brushless motor with highflow water-cooling jacket
Quick-release Power Module integrates power system, waterproof electronics, and stuffing tube
Adjustable battery trays with hook-and-loop straps
Blue-anodized aluminum rudder support, rudder, and drive strut
Stainless steel turn fins, trim tabs, and hardware
TQi 2.4GHz High-Output radio system with Traxxas Link™
Includes two 7-cell Power Cell battery packs
Waterproof high-torque steering servo
Sleek design with factory-applied graphics
Ready-To-Race®
Traxxas factory support
MODEL 5707: Fully assembled, Ready-To-Race®, TQi™ 2.4GHz High Output radio system with Traxxas Link™, Velineon® 540XL Brushless Motor, VXL-6s Marine ESC and factory-applied graphics.
Velineon VXL-6s Marine Brushless System
Extreme Velineon brushless horsepower delivers the muscle you want with the reliability you expect from Traxxas. 30+mph out of the box on the included 7-cell battery packs is just the start. The VXL-6s Marine electronic speed control is built for true 6S LiPo power.* On-board low voltage detection helps you maintain your batteries. The extra voltage and current maximizes the potential of the Velineon 540XL motor for extreme 50+mph speed. The rebuildable, sensorless Velineon 540XL motor is designed for high-rpm performance and reliability with ultra high-temperature sintered Neodymium magnets, a precision-balanced rotor, and efficient, high-speed ball bearings. Cooling water is routed through the innovative speed control case and then into a unique sealed motor jacket that allows cooling water to flow directly against the motor for maximum possible heat transfer. The SPARTAN keeps its cool, run after run, for trouble-free all-day fun.
Velineon® VXL-6s Marine ESC
Innovative waterproof design
integrated water cooling
Three programmable drive profiles:
Sport Mode – 100% FWD / 15% REV
Race Mode - 100% FWD / No REV
Training Mode – 50% FWD / 15% REV
High-efficiency MOSFET transistors
Built-in two-stage low-voltage detection for LiPo batteries
Thermal overload protection
Voltage overload protection
Locked rotor protection
Throtle Neutral Setting protection
NiCad and NiMH battery packs: 6-18 cells (7.2 to 21.6 volts)
LiPo battery packs: 2-6 cells (7.4 to 22.2 volts)
12-gauge Maxx Cable wire
Ultra high-temperature sintered Neodymium magnets
Optimized for power and efficiency in marine applications
Consistent, high-power output, run after run
Low-maintenance design
Efficient, high-speed ball bearings
Precision-balanced rotor
High-efficiency bullet connectors
1600kV
5mm output shaft
Brilliant blue-anodized finish
Silicon steel laminations
Unique high-flow silicone water cooling jacket
#2 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 08 September 2013 - 09:53 AM
Pret nou 2000ron valabil pana la data de 18-09-2013, daca nu se vinde pana la data specificata revine la 2500.
Rog a nu se considera up.
Multumesc
#3 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 15 September 2013 - 10:50 AM
se mai adauga 2 acumulatori 7-cell Power Cell battery packs Traxxas 8,4v , 3000mah absolut noi, nefolositi
Pt. mai multe detalii intrati aici:http://######/acumulatori/nimh/acumulator-automodele-traxxas-7-celule-3000mah-nimh.html
#4 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 15 September 2013 - 10:57 AM
Se mai adauga 2 acumulatori 7 celule TRAXXAS NiMh 3000mAh, 8,4V fara a modifica pretul.
Pt. mai multe detalii intrati aici:http://traxxas.com/products/parts/batteries/powercellbatteries/nimh-gallery
#5 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 22 September 2013 - 07:39 AM
Up Up Up.
#6 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 29 September 2013 - 04:46 PM
Up Up Up.
Pretul ramane in continuare 2000 ron
#7 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 05 October 2013 - 10:04 AM
Up Up Up
Astept oferte pt tot pachetul prezentat mai sus.
#8 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 06 October 2013 - 08:08 PM
Super oferta
Urgent 1700 ron. valabil pana joi 10.10.2013.
Multumesc.
Aceasta postare a fost editata de ganciurobert: 06 October 2013 - 08:09 PM
#9 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 12 October 2013 - 08:56 PM
Incepand de astazi barca se vinde la pretul de 1500ron. fara acumulatori si incarcator.
Sau 2000ron. cu acumulatori si incarcator.
#10 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 12 October 2013 - 09:39 PM
Puteti vedea aici un film cu barca in actiune
#11 Useril este offline   MR-JW
  • Postari: 530
  • Inregistrat: 15-May 10
Postat 12 October 2013 - 10:18 PM
Fara suparare , ma intrebam si eu de ce nu :
- pui poze cu barca ta si pui pe cele de pe site Traxans
- de ce nu pui un film cu barca ta si pui ale altora
- de unde este cea mai rapid model
Poate asa o sa ai succes
#12 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 13 October 2013 - 09:29 AM
Pozele cu barca mea sunt identice cu cele de pe site.
Nu pot pune film cu barca mea deoarece este noua (dupa cum scrie si mai sus)si nu am pus-o pe apa.
Dupa cum scrie pe traxxas.com, traxxas.ro si la toate magazinele unde se comercializeaza navomodelul scrie clar Navomodel Traxxas Spartan cel mai RAPID NAVOMODEL RTR.
#13 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 13 October 2013 - 09:39 AM
Mai mentionez ca este noul model Traxxas Spartan cu Velineon® 540XL Brushless Motor, VXL-6s Marine ESC la care s-au rezolvat problemele cu overheating, si are o manevrabilitate mult buna fata de modelul precedent datorita noii forme imbunatatite.
#14 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 13 October 2013 - 10:41 AM
Si poze cu navomodelul.
#15 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 25 October 2013 - 11:55 AM
Sus pe val cu muscleboat
#16 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 31 October 2013 - 04:54 PM
Acumulatori s-au dat , deci ramane doar barca la 1500 ron.
#17 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 07 November 2013 - 09:23 AM
Sus cu barca.
A ramas doar navomodelul la 1500 ron.
#18 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 15 November 2013 - 09:35 AM
Sus cu barca ca se apropie Sarbatorile si poate fi in cadou deosebit.
1500 ron.
#19 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 24 November 2013 - 10:06 PM
Super pret de Black Week 1200ron valabil 7 zile
#20 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 01 December 2013 - 02:24 PM
Revine la 1500 ron.
#21 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 08 December 2013 - 10:25 PM
1500 ron sau schimb cu auto
Aceasta postare a fost editata de ganciurobert: 08 December 2013 - 10:25 PM
#22 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 16 December 2013 - 05:02 PM
Se apropie Sarbatorile si poate fi in cadou deosebit.
#23 Useril este offline   ganciurobert
  • Postari: 308
  • Gender:Female
Postat 21 December 2013 - 01:38 PM
Reducere: scade la 1200 ron
Pentru ca se apropie Sarbatorile si poate fi in cadou deosebit.
Produs nou nepornit si nepus la apa vine in cutie cu toate accesoriile de producator.
Aceasta postare a fost editata de ganciurobert: 21 December 2013 - 01:40 PM
