Modelism - RHC Forum: Apprentice 15e - Modelism - RHC Forum
Apprentice 15e E-flite
#1 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
  • Inregistrat: 06-October 08
Postat 18 November 2013 - 01:28 PM
Treiner E-flite,in stare foarte buna.
Model gata de zbor,necesita statie si acumulator.
Specifications
Type: Aeroplanes
Wingspan: 58 in (1475mm)
Overall Length: 37 in (940mm)
Flying Weight: 40–45 oz (1135–1275 g)
Motor Size: 15-size brushless outrunner (installed)
Radio: Spektrum DX5e 2.4GHz (included)
Servos: 4 servos (installed)
Prop Size: 11 x 8 electric (installed)
Wing Area: 525 sq in (33.7 sq dm)
Wing Loading: 12 oz/sq ft
Charger: 3S Balancing Li-Po Battery Charger (EFLC3010) (included)
Speed Control: 30A Brushless Pro SB Brushless ESC (EFLA1030) (installed)
Approximate Assembly Time: 30 minutes
Recommended Battery: 3200mAh 3S 11.1V 15C Li-Po (EFLB1040) (included)
Experience Level: Beginner
Is Assembly Required: Yes
Trim Scheme Colours: White Z-Foam with red, black and silver decals
Approximate Flying Duration: 15 minutes
CG (centre of gravity): 3.25 in (83mm) back from the leading edge
Pret: 599 Lei
ADRIAN - Tel.0787 828 507
Ingerii zboara pentru ca o iau usor .....
#2 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 18 November 2013 - 02:26 PM
Necesita :Statie si acumulator.
Variante....
Film..
http://www.youtube.c...h?v=qpOORwpZ7wQ
#3 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 19 November 2013 - 10:37 AM
Poza la cerere.... Pretul se reduce la 499 lei- Variante
#4 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 21 November 2013 - 04:44 PM
Se mai adauga un model pentru accesorii de schimb.
Contine: fuselaj,aripa,stabilizator,tren
Pret: 249 lei
#5 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 26 November 2013 - 08:56 AM
Ultima reducere:
1.Model echipat : 449 lei
2.Model fara electronica :249 lei
Ambele modele negociabil .
#6 Useril este offline   Rottyrc
  • R/C PILOT
  • Postari: 2641
Postat 01 December 2013 - 09:11 AM
Preturi valabile o saptamana,dupa care se retrage.
1 Model echipat -399 lei fix (jumatate din valoare)
2.Model fara electronica-220 lei fix (sub jumatate din valoare)
