Motorul se preteaza pentru aeromodele intre 1.7-2 metri aerobatic sau scale si vine si cu toba MVVS cumparata ulterior, toba este noua, nemontata vreodata.
Cateva caracteristici ale motorului:
Displacement: 25,66 cm3
Bore/Stroke: 33/30,1 mm
Power Output: 3,9 PS/9000 RPM
Weight: 900 g
Description: The engine with glow plug for airplane model use. The RC carburettor is placed in front of engine and exhaust port is oriented to right side. The piston is made from Al alloy with high content of silicone, steel cylinder sleeve and piston ring from cast iron. The piston working surface is covered by molybdenum-sulphide layer for better run-in, friction reduction and lifetime extension. The fuel mixture is prepared by carburettor MVVS 3215. Engine is suitable for 1.7 - 2.0 m acrobatic and scale models. Compared to IFS version, this engine provides higher power (about 300-500 RPM) and weight is reduced by excluding the ignition system.
PRET nediscutabil 800 RON
Relatii pe PM sau la 0723004415
Number of downloads: 28 -
