Modelism - RHC Forum: Motor NGH 35cc (benzina) - Modelism - RHC Forum
Motor NGH 35cc (benzina) nou, pornit de 3 ori
#1 Useril este offline   sunchaser
  • Postari: 414
  • Inregistrat: 23-February 09
Postat 02 July 2013 - 03:06 PM
Se vinde motor pe benzina NGH 35 cc. A fost pornit de 3 ori, este inca nerodat.
Vine cu kit de conversie la evacuare prin spate, aprindere RCEXL, bujie NGK.
Voi reveni si cu fotogrfaii reale sau le trimit la cerere.
Pret: 700 lei
#2 Useril este offline   sunchaser
  • Postari: 414
Postat 09 July 2013 - 02:46 PM
Up !
#3 Useril este offline   sunchaser
  • Postari: 414
Postat 22 July 2013 - 01:34 PM
Up !
#4 Useril este offline   sunchaser
  • Postari: 414
Postat 12 August 2013 - 02:02 PM
Valabil doar pana pe 19 august !
#5 Useril este offline   flypol
  • Postari: 4092
  • Inregistrat: 01-January 09
Postat 13 August 2013 - 09:54 AM
Greutatea,cu tot cu aprindere?
#6 Userul este online   Mihai_supy
  • Postari: 5162
  • Inregistrat: 16-December 10
Postat 13 August 2013 - 03:21 PM
SPECIFICATIONS
CONFIGURATION:
Single cylinder two stroke - spark ignition - petrol fuel
DISPLACEMENT: 34.965 cc
BORE: 37.3 mm
STROKE: 32 mm
WEIGHT:
1280g complete
PROP’ RANGE :
18 X 8 - 20 X 8
...am tot citit despre motor....
Apoi am gasit si asta:
Displacement: 2.13 cu in.(34.95cc)
Bore : 1.47 in. (37.3mm)
Stroke: 1.26 in (32mm)
Engine (Only) Weight: 1280g
Ignition Weight: 1400g
Prop Range: 18x8,18x10,20x 8
RPM Range: 2000-9000
Cred ca e 1400 g cu totul....
Aceasta postare a fost editata de Mihai_supy: 13 August 2013 - 03:23 PM
