Modelism - RHC Forum: Controler brushless cu inversare de sens ? - Modelism - RHC Forum
Controler brushless cu inversare de sens ? adica: inainte-stop- inapoi
#1 Useril este offline   znecula
  • Postari: 845
  • Inregistrat: 03-April 05
Postat 13 July 2005 - 03:35 PM
Am cautat pe la navomodelisti, dar nu am gasit asa ceva.
Stie cineva cum se poate realiza asa ceva?
#2 Useril este offline   ron_van_sommeren
  • Postari: 124
  • Inregistrat: 03-June 05
Postat 13 July 2005 - 07:56 PM
Lets see if I can read Rumanian :(
To reverse the motor you swap any 2 of the three leads between the motor and the brushless controller. Never ever swap the wires between your battery and controller, that will fry/toast/ruin your controller.
#3 Useril este offline   Rares
  • Postari: 651
Postat 13 July 2005 - 08:43 PM
I quess he was trying to say this.....to use a brushless motor to spin in each way for a boat....just by playing at the throtle stick....a brushless ctrl-er that can do this. It's a little bit hard to this because you have to inverse the spin without any sensors. The ideea looks funny and interesting...a brushless motor on a boat with a gear ratio 3:1 -> 4:1 will be a rocket :(
keep in touch
@ron_van_sommeren all my respects for trying to understand romanian :(
#4 Useril este offline   ron_van_sommeren
  • Postari: 124
Postat 13 July 2005 - 11:16 PM
Too bad, I was beginning to think I'm a real polyglot :(
No, alas, I have not seen brushless controllers that can do this, although I have seen the question pop up more than once times on several fora.
Aceasta postare a fost editata de ron_van_sommeren: 14 July 2005 - 03:52 PM
#5 Useril este offline   znecula
  • Postari: 845
Postat 14 July 2005 - 09:57 AM
Mda... eu nu vreau sa folosesc motorul pt vre-un model ci pt cnc.
Deci va fi comandat din calculator si nu e nevoie de comenzi speciale si nu apar dificultati cu telecomanda.
Interfata cu calculatorul trebuie sa fie facuta ca atare.
Cred ca va trebui sa contina (interfata), un pin pt. a comanda schimbarea sensului.
Stima.
#6 Useril este offline   Minitechnicus
  • Postari: 88
  • Inregistrat: 01-June 05
Postat 14 July 2005 - 01:10 PM
Si ce ne-ar opri sa-i punem senzori? Pe un navomodel cred ca se poate mai usor.
Oricit de putin inseamna enorm de mult
#7 Useril este offline   znecula
  • Postari: 845
Postat 14 July 2005 - 03:46 PM
Nu senzorii rezolva problema, fiindca scula pe care o plimba cnc-ul nu are curse bine stabilite ca sa pun senzori la capat de cursa.
Schimbarea sensului de deplasare pe o anumita axa se face f des si in puncte cu totul si cu totul diferite fata de capetele de cursa ale axei respective.
#8 Useril este offline   ron_van_sommeren
  • Postari: 124
Postat 14 July 2005 - 03:53 PM
Maybe ask it here, the Open Source Motor Controller group:
http://www.yahoogroups.com/group/osmc
Or here, the 'bldc controller' thread:
http://www.rcgroups....ad.php?t=200567
Aceasta postare a fost editata de ron_van_sommeren: 14 July 2005 - 03:55 PM
#9 Useril este offline   Rares
  • Postari: 651
Postat 14 July 2005 - 11:21 PM
dar de ce brushless nu si pas cu pas?
#10 Useril este offline   znecula
  • Postari: 845
Postat 15 July 2005 - 06:47 AM
Vreau deplasari rapide pe axele X si Y pentru pozitionarea sculei.
Cu mpp imbatranesti langa cnc pana face o cursa de 1000-1500 mm
#11 Useril este offline   Omu
  • Postari: 157
  • Inregistrat: 16-April 04
Postat 15 July 2005 - 07:09 AM
Ai nevoie de servomotor brushless cu controler dedicat,
acel controler este singurul care stie ce sa faca cu semnalele primite de la calculator. Unde mai pui ca exista posibilitatea foarte mare ca sa nu existe programe care sa mearga cu acest tip de controler. De regula programele free sau shareware care se mai gasesc pe net scot numai step si dir pe portul paralel, fara sa primeasca nici un feedback de la encodere, unitatile Gecko servodrive iau cele 2 doua semnale (step, dir) si le transforma in semnal pentru servomotoare si aceste unitati sunt cele care au intrari pentru feedback de la encodere nu portul paralel.
Ai avea nevoie de soft care scoate step, dir, Unitati servodrive brushless care sa primeasca aceste semnale si sa le transforme in semnale pentru servomotorul brushless si aceste unitati sa aiba intrari pentru semnale de la encodere. Din cate stiu eu numai firma Gecko are servocontrolere care stiu sa faca chestia asta si numai pentru servomotoare cu perii
#12 Useril este offline   GIGEL09
  • Postari: 17
  • Inregistrat: 16-March 04
Postat 17 July 2005 - 12:43 PM
Un asemenea controller se poate construi cu ajutorul circuitului LM 628 , citeste cu atentie documentatia circuitului si notele aplicative.
Cu stima
