Modelism - RHC Forum: Vand Easy Star Brushless ARTF cu eleroane - Modelism - RHC Forum
Vand Easy Star Brushless ARTF cu eleroane Fuselaj, motor, regulator, servouri, baterie
#1 Useril este offline   ionut EZ
  • Postari: 929
  • Inregistrat: 28-November 09
  • Interests:Modelism
Postat 08 September 2012 - 11:43 AM
Asa cum zice si titlul, vand prima dragoste Easy Star facut de Multiplex
Avionul vine echipat cu motor brushless cu urmatoarele specificatii:
High torque inrunner, excellent for running propellers without needing a gearbox.
The unique stator design creates a low current and high torque motor great for outrunner replacements and much more efficient than inrunners of the same size.
Dimension: 28mm x 56mm, 70mm(with shaft)
Weight: 131g (kv2600) (not including connectors)
Diameter of shaft:4mm
Length of front shaft:14mm
Lamination thickness: .2mm
Spec.
Battery: 3 Cell 11.1
RPM: 2600kv
Max current: 50A
No load current: 1.8A
Internal resistance: 20.72ohm
Data;
3S 11.1V
Prop: 6x4, 8x3.8
Max Current: 45A, 49A
Pull: 1100g, 1400g
Regulator brushless Turnigy Trust de 55A cu urmatoarele specificatii:
Turnigy® TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors.
The large heatsink and simple PCB layout make heat dissapation consistant, enabling the ESC to be run at its limit, without failure.
The ESC is program-card and transmitter programmable with clear and easy to understand instructions included.
Default factory settings are;
Brake: off
Battery: LiPo Auto Detect
Low Voltage: 3.2v (power down motor)
Spec.
Max Motor Current: 55A
Max BEC Current: 3A
BEC Voltage: 5.5v (Switching)
LiPo: 2~6S
NiMH:5~16cells
Weight: 53grams
Programming Options.
Battery Type
Forward/Reverse
Soft Start
LV Setting (Ignore, Reduce Power, Stop Motor)
Timing (Auto, Med, High)
Switching (8,16kHz)
Factory Restore
3 servouri Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec pe eleroane si elevator :
Weight: 13.4g
Dimension: 22.8*12.2*28.5mm
Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm (6.0V)
Operating speed: 0.10sec/60degree(4.8v) - 0.08sec/60degree(6.0V)
Operating voltage: 4.8-6.0V
Temperature range: 0- 55deg
Servo Plug: JR (Fits JR and Futaba)
1 servo Turnigy TGY-9025MG Metal Gear Servo 1.8kg/11g/0.09 pe profundor:
Model: TGY-9025MG
Operating Voltage: 4.8V / 6.0V
Operating Current: 200mA / 250mA
Operating Speed: 0.10sec.60º/ 0.09sec.60º
Stall Torque: 1.5kg.cm /1.8kg.cm
Weight: 11g
Dead Band: ≤7uSec
Operating Travel: 60º +/- 10º
Potentiometer: indirect Drive
Ball bearing: Top Ball Bearing
Gear: Metal
Connector wire: 180mm 26AWG
Plug: JR/Universal
Operating Temperature Range: -20c+60c
1 bucata baterie turnigy 3s 2200mAh 20-30C , bateria este cam consumata, se incarca 1600mAh si ofera un timp de zbor de 10 minute
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 185g
Pack Size: 103 x 33 x 24mm
Charge Plug: JST-XH
Discharge Plug: XT60
Avionul mai este echipat si cu con de aluminiu si 2 elici 4,75x4,75
Avionul este modificat astfel incat in fuselaj are aprox 60 leduri SMD albe iar pe aripi alte 40 leduri rosi si 40 de leduri verzi ultrabright :drinks: .Ledurile se alimenteaza de la bateria avionului printr-o mufa.In total toate consuma 1,2A/h
Greutatea este de aprox 65 g in plus.
Avionul are cateva rupturi dar a fost lipit ca la carte si zboara foarte bine.
Valoarea la tot ar fi cam asa:
1. motor - 90 lei
2. regulator - 100 lei
3. servouri - 100 lei
4. baterie - 20 lei
5. fuselaj - 100 lei (doar ledurile au costat 75 lei ... sa nu mai punem munca ..)
Motorul si regulatorul si servourile sunt din primavara asta au 4 iesiri dintre care una la RR
Pretul meu 359 lei easy star cu eleroane complet motorizat si echipat mai trebuie o statie
Robbe SZD-54
O aripa otravita de 1m
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#2 Useril este offline   ionut EZ
  • Postari: 929
Postat 10 September 2012 - 01:57 PM
Regulatorul s-a dat, ramane restul valabil si pretul la tot pachetul scade la 300 lei :pardon:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#3 Useril este offline   ionut EZ
  • Postari: 929
Postat 24 September 2012 - 02:44 PM
Valabil :unsure:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#4 Useril este offline   marius11
  • Postari: 1397
  • Inregistrat: 30-August 08
  • Interests:Aeroclub Fagaras - Facebook
    Aero, Heli, Navo , RC cars , and drone
Postat 01 October 2012 - 09:50 PM
Buna ...mai ai THE STAR LIGHT ? ?
#5 Useril este offline   ionut EZ
  • Postari: 929
Postat 07 October 2012 - 09:21 AM
DA :clapping:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#6 Useril este offline   ionut EZ
  • Postari: 929
Postat 27 October 2012 - 08:07 PM
Valabil :) 299 lei
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#7 Useril este offline   marius11
  • Postari: 1397
Postat 11 November 2012 - 10:13 PM
Ultimul pret .......
Noroc
#8 Useril este offline   laur58
  • Postari: 195
  • Inregistrat: 14-July 11
Postat 11 November 2012 - 10:24 PM
Ai PM !
#9 Useril este offline   ionut EZ
  • Postari: 929
Postat 12 November 2012 - 02:37 PM
295 lei :rofl:
Cu un regulator de pe forum cu 50-60 lei aveti avion de incepatori BRUSHLESS cu servouri METALICE si baterie LIPO :)
Cheers :rofl:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#10 Useril este offline   ionut EZ
  • Postari: 929
Postat 02 December 2012 - 11:13 AM
285 lei :drinks:
Aceasta postare a fost editata de ionut EZ: 02 December 2012 - 11:14 AM
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#11 Useril este offline   ionut EZ
  • Postari: 929
Postat 26 December 2012 - 05:03 PM
up :drinks:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#12 Useril este offline   ionut EZ
  • Postari: 929
Postat 05 January 2013 - 02:52 PM
280 lei
yonutz_thebest94@yahoo.com sau 0764670339 :drinks:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
  • Postari: 3965
  • Inregistrat: 19-August 12
Postat 05 January 2013 - 03:07 PM
Mai multe poze??
#14 Useril este offline   ionut EZ
  • Postari: 929
Postat 15 January 2013 - 05:35 PM
poze
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#15 Useril este offline   ionut EZ
  • Postari: 929
Postat 15 January 2013 - 05:38 PM
poze
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#16 Useril este offline   ionut EZ
  • Postari: 929
Postat 27 January 2013 - 10:20 AM
275 lei :clapping:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#17 Useril este offline   ionut EZ
  • Postari: 929
Postat 03 February 2013 - 04:08 PM
270 lei :drinks:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#18 Useril este offline   ionut EZ
  • Postari: 929
Postat 10 February 2013 - 10:02 AM
265 lei :drinks:
Astept oferte :rolleyes:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#19 Useril este offline   ionut EZ
  • Postari: 929
Postat 17 February 2013 - 08:55 PM
260 lei
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#20 Useril este offline   ionut EZ
  • Postari: 929
Postat 24 February 2013 - 11:28 AM
259 :clapping:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#21 Useril este offline   ionut EZ
  • Postari: 929
Postat 03 March 2013 - 08:59 AM
255 lei + un reg de 50 lei (botosani) + o statie 80 lei de pe forum si aveti EZ cu eleroane, brushless RTF :drinks:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#22 Useril este offline   ionut EZ
  • Postari: 929
Postat 10 March 2013 - 12:35 PM
up 250 lei :clapping:
are pe el motorul din imagine, 3 servo ( foto 2)si 1 servo (foto 3)
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#23 Useril este offline   ionut EZ
  • Postari: 929
Postat 17 March 2013 - 10:54 AM
up 240 lei :clapping:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#24 Useril este offline   ionut EZ
  • Postari: 929
Postat 24 March 2013 - 10:57 AM
up 235 lei :clapping:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#25 Useril este offline   ionut EZ
  • Postari: 929
Postat 31 March 2013 - 09:56 AM
up 230 lei :clapping:
nu vrea nimeni un avion ARTF ? :unsure:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#26 Useril este offline   ionut EZ
  • Postari: 929
Postat 07 April 2013 - 11:46 AM
up 219 lei avion ARTF :rolleyes:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#27 Useril este offline   ionut EZ
  • Postari: 929
Postat 14 April 2013 - 10:08 AM
up 215 lei avion ARTF :rolleyes:
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
#28 Useril este offline   ionut EZ
  • Postari: 929
Postat 20 April 2013 - 11:48 AM
Si ..., s-a dat !
Robbe SZD-54
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
