Modelism - RHC Forum: Vand Kit HK FPV/UAV Fiber Glass V2 Long Range 168 - Modelism - RHC Forum
Vand Kit HK FPV/UAV Fiber Glass V2 Long Range 168 Kit nou , in cutie ( nemontat )
#1 Useril este offline   ggsolom
  • Postari: 128
  • Inregistrat: 28-August 11
  • Interests:Aeromodelism, FPV, pescuit
Postat 11 January 2013 - 07:01 PM
http://www.hobbyking.com/hobbyking/store/catalog/FPV168.jpg
http://www.hobbyking...Warehouse_.html
Featuring a full fiberglass fuselage with built up ply and balsa construction, the HobbyKing FPV / UAV is set to raise the bar in FPV flight performance. The large motor mount area allows for a variety of motor sizes depending on your application. A slick fiberglass finish provides superior aerodynamics to foam planes while the rigid airframe offers a greater level of flight performance. The large clear canopy is perfectly suited to FPV cameras or can be removed or modified with ease for a custom setup. The Fuselage boasts ample space for FPV equipment allowing a variety of custom setups and the split flaps will ensure low speed landings with heavier payloads.
You will require a 35 to 42 size burshless outrunner, 5 x 9g servos (one for each control surface and one for the steerable nose wheel), a 40 to 60Amp ESC, 3s to 4s 2200mah~4400mah Lipo battery and your own transmitter and receiver (Tx/Rx). All the general hard ware (Push rods, screws, landing gear etc) are included to get this kit underway.
Some modeling experience will be required to complete this kit, However the finished product will be of a high quality with superior flight characteristics to foam and will last a life time.
Specs:
Wing Span: 1660mm
Fuselage: 1190mm
Motor Mount Diameter: 58mm
Distance From Center of Mount to Fuse: 114mm (max prop diameter 8"]
Dry Weight: 1300g
5 Channel (throttle, aileron, elevator, rudder/steering, flaps)
Required:
Motor: 35 to 42 series Outrunner
ESC: 40a to 60A
Servo: 5 x 9g
Battery: 3s to 4s 2200mah~4400mah
PRODUCT ID: HK-UAV01
Pret 600 lei + transport curier rapid
0744-644321
Canard LRS FPV
Spider Quad LRS FPV
Quad Eachine 250 FPV
Egreta Glider
Phoenix 2000 Glider
Skyfun
Combat Wing
T-45 Goshawk
T9 & FrSky mod
FrSky Taranis Plus
Life is short, fly fast fly low !
