Modelism - RHC Forum: Sbach_342_"scandurica " - Modelism - RHC Forum
Sbach_342_"scandurica " balsa
#1 Useril este offline   pccdtk
  • Postari: 1747
  • Inregistrat: 09-June 02
Postat 12 August 2013 - 06:12 PM
Vand "scandurica" din imaginile de mai jos ( pret 260 lei - fara electronica ) ca sa-mi pot finanta motorizarea pt. https://fbcdn-sphoto...255978122_n.jpg
Aceasta postare a fost editata de pccdtk: 12 August 2013 - 06:13 PM
#2 Useril este offline   `dasa
  • Postari: 349
  • Inregistrat: 14-March 12
  • Interests:Auto
    Navo
    Robotica
    Arduino
Postat 12 August 2013 - 08:51 PM
Vezi postareapccdtk, la 12 August 2013 - 06:12 PM, a spus:
Salut sunt incepator in ale avioanelor si am vazut modelul tau ,Sbach_342_"scandurica ", si as vrea sa te rog daca se poate sa imi dai si mie planul de la el.
Multumesc anticipat!
Scuze dar nu poti pm.
#3 Useril este offline   pccdtk
  • Postari: 1747
Postat 19 August 2013 - 11:39 PM
Pret nou : 200 lei - asa ramane cateva saptamani dupa care daca nu se vinde il retrag . A zburat in urmatoarea configuratie :
Avergura: 120 cm
Lungime : 110 cm
Greutate : 1245 gr.
Motor: Himax HC3516-1130
Elice : 12x8
Esc: TURNIGY_55 amp_Speed_Controller
Lipo: ZIPPY_Flightmax_2200mAh_3S1P_40C
Servo: MG90S - angrenaje metalice ( 13.2 gr.)
OBS.Modelul se vinde fara electronica !!!
#4 Useril este offline   pccdtk
  • Postari: 1747
Postat 26 August 2013 - 11:10 PM
UP !
#5 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2400
  • Inregistrat: 05-August 09
Postat 27 August 2013 - 07:33 AM
Vezi postareapccdtk, la 19 August 2013 - 11:39 PM, a spus:
Avergura: 120 cm
Lungime : 110 cm
Greutate : 1245 gr.
Elice : 12x8
Robert,
greutatea este full echipat sau fara electronica?
Olivian Diaconescu
Radio:
Multiplex Royal Pro 16 2.4GHz
Aero:
FREEWING - F22 Xicoy X45 Jet
T one F22-2.7 m in curand..
ROBBE - Mistral 2.0m
AERONAUT - Triple RES 2.0m
Auto:
TRAXXAS - E Revo 1/16
ARRMA - Typhon 6S
#6 Useril este offline   pccdtk
  • Postari: 1747
Postat 27 August 2013 - 08:29 AM
Gata de zbor !!!
#7 Useril este offline   pccdtk
  • Postari: 1747
Postat 02 September 2013 - 11:39 AM
UP !!!...ultima "strigare" - daca nu tenteaza pe nimeni il retrag .
#8 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2400
Postat 02 September 2013 - 12:18 PM
Vezi postareapccdtk, la 02 September 2013 - 11:39 AM, a spus:
Crezi ca merge pus un motor termic pe el? de 4 cmc?
Olivian Diaconescu
Radio:
Aero:
Auto:
ARRMA - Typhon 6S
#9 Useril este offline   pccdtk
  • Postari: 1747
Postat 02 September 2013 - 02:14 PM
Vezi postareaoachidori, la 02 September 2013 - 12:18 PM, a spus:
Da , insa trebuie modificat batiul - modelul este destul de solid ca sa suporte un motor termic ....mi-e teama insa sa nu devina greu de bot - acumulatorul + ESC-ul + motorul Himax au ~ 400 gr.
Aceasta postare a fost editata de pccdtk: 02 September 2013 - 02:19 PM
#10 Useril este offline   pccdtk
  • Postari: 1747
Postat 02 September 2013 - 02:20 PM
Cel mai bine ar fi sa-l vezi .....!!!
#11 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2400
Postat 02 September 2013 - 02:38 PM
Vezi postareapccdtk, la 02 September 2013 - 02:14 PM, a spus:
Pai motorul cu tot cu toba are 297 g iar acumulatorul are 60 g.Cred ca ar merge,ramane sa ne auzim la un telefon , poate ne vedem in weekend ca mai devreme nu pot.
Merci,
Olivian Diaconescu
Radio:
Aero:
Auto:
ARRMA - Typhon 6S
#12 Useril este offline   pccdtk
  • Postari: 1747
Postat 29 September 2013 - 08:48 PM
Vandut !!!
