Modelism - RHC Forum: Motoare brushless second hand - Modelism - RHC Forum
Motoare brushless second hand outrunnere + 2 inrunere mici 20x30
#1 Useril este offline   alexvid
  • Postari: 1494
  • Inregistrat: 30-April 08
Postat 11 November 2012 - 06:00 PM
motoarele de vanzare sunt mai jos.
Motoarele sunt second hand si le vand pentru ca renunt la hobby din lipsa de timp:
1 : MOTOR F2627 4100KV cu EDF 55mm 40RON
Specificatii Motor :
Rotational Speed: 4100 (kv)
Shaft : 2.3mm
Continuous Current: 21A
Max. Current: 25A
Input Voltage: 11.1v
Max. Torque: 700g
Weight (Motor With Fan ): 62 g
Motor Dimensions (Diameter x Length): 26 x 27 mm
EDF inclus 55mm
http://imageshack.us/a/img525/8713/edf2627kv4100.jpg
2 : Motor C2822 KV1200 + ESC 30A 45RON
Este inclus si ESC-ul.
Specificatii motor :
Rotational Speed: 1200 (kv) RPM/V
Continuous Current: 15A
Input Voltage: 6 - 11.1V
No Load Current: 0.5A
Internal Resistance: 382ohmi
Power: 135W
Motor Weight : 90g
Motor Dimensions (Diameter x Length): 28mm x 22mm
Propeller Dimensions: 8 x 5/ 8 x 6 / 7 x 5
Specificatii ESC:
Constant Current: 30A
Max Current: 40A/12s
BEC output: 3A
http://img705.imageshack.us/img705/6046/aeolianc28221200kvesc30.jpg
3 : EMGC A3714 893KV 30RON
built in propeller adaptor 6mm diameter
specificatii motor size 37mm dia 44mm
RPM 893KV
continuous current typical 40a
max current 50a
voltage 4v-18.5v (2s -5s lipo)
weight 115g
Recommended esc 60a
EMGC A3720 650KV 40RON
KV (RPM/V) 650
putere : 1000W
alimentare : 3S ~ 6S (6V-23V)
Operating Current 50A - 70A
Weight 150g
Recommended ESC 60A
Recommended propeller 12x6, 14x7, 15x5, 16x6, 18x4, 18x6
Size: 37mm (dia) x 49mm
Shaft Size: Propeller adaptor (6mm dia)
http://img18.imageshack.us/img18/108/emgc37203714.jpg
4 : Motor xpeed 2810 tip clopot 20RON
RPM : 2810KV
dimensiuni : 31 diametru x 36 de la prindere pana unde incepe axul
Rotational Speed : 2810 RPM/V <br>
Continuous Current : 20A
Max. Current : 25A
No Load Current : 0.7A
Internal Resistance : 56mOhm
http://img20.imageshack.us/img20/2008/xspeed2810.jpg
5 : Motor xpeed 2410 tip clopot 20RON
Rotational Speed: 2410 RPM/V
Max. Current: 20A
Input Voltage: 6 - 12V
No Load Current: 0.6A
Internal Resistance: 32mO
Motor Dimensions (Diameter x Length): 30.6mm x 33.4mm
http://img811.imageshack.us/img811/3562/xspeed2410.jpg
6 : tower pro 2408 21T 20RON
2408-21T-3A
Dimension:31*65mm
Weight: 50g
Idle Current:0.8A
Battery:2-3 Lipo
KV:1400 RPM/V
shaft Diameter:3.0
Max Efficency Current: 13.8 A
Max RPM r/min:8200 RPM/min
Max loaded current (A/60s): 16.2/60s
Max Power W/60s:113.4/60s
Suggest Propoller size:8*3.8thick/8.6thin EP09*4.7/SF10*4.7
http://img22.imageshack.us/img22/1217/towerpro240821t.jpg
7 : EMAX CF2822 25RON (pretul pentru ambele bucati 40RON)
Weight: 39g (with wire & sticker etc)
Shaft: 3mm
Motor Length: 46mm
Diameter: 28mm
Stator Size: 22x10mm
Suggested prop: 9~10inch
Voltage: 11.1v (3S)
Kv: 1200RPM/V
Prop size: 10x5; RPM: 7100; Max Curr: 14.5A; Thrust: 710g
Prop size: 10x4.7SF; RPM: 6100; Max Curr: 14.5A; Thrust: 745g
http://img856.imageshack.us/img856/9118/emaxcf28221200kv.jpg
Preturile sunt in bucuresti cu preluare de la mine din zona mall vitan.
Pentru livrare cu fan courier, in afara bucurestiului, se adauga 20ROn.
Detalii si contact pe MI.
#2 Useril este offline   alexvid
  • Postari: 1494
Postat 11 November 2012 - 06:02 PM
8 : RCSMART inrunner 3480KV 20RON
Rotational Speed : 3480 RPM/V
Continuous Current : 18A
Max. Current : 22A
Input Voltage : 2-3S
Internal Resistance 65mOhm
Motor Dimensions (Diameter x Length) 20mm x 33mm
Shaft Dimensions (Diameter x Length) 1.96mm x 10mm
http://img87.imageshack.us/img87/1627/rcsmartinrunner3480kv.jpg
9 : RCSMART inrunner 2900KV 20RON
Rotational Speed : 2900 RPM/V
Continuous Current : 16A
Max. Current : 22A
No Load Current : 0.6A
Motor Dimensions : 20mm x 30mm
Shaft Dimensions : 2mm x 10mm
http://img833.imageshack.us/img833/51/rcsmartinrunner2900kv.jpg
10 : Mystery 2632 1000KV 20RON
Rpm(Kv): 1000Rpm/V
Max Current: 23A
Recommended Input Voltage: 2-3S
Weight: 52g (Motor only)
Total Length: 32mm
Motor Body Diameter: 25.9mm
Shaft Diameter: 2.26mm(Front)
Shaft Length: 13mm
http://img838.imageshack.us/img838/6193/mystery26321000kv.jpg
11 : Turborix 1000rpm/v 20RON
KV (rpm/v) 1000
No Load Current (A) 0.7
Cont. Current (A) 10.6
Pull (g) 650
Recommended Propeller 9050
Input Voltage (v) 11.1
Shaft Diameter (mm) 3
http://img201.imageshack.us/img201/370/tuborix1000kv.jpg
12 : HK2836 EDF Outrunner 3800kv for 64mm 60RON
Nu include EDF
Kv- 3800
Dimensions: 75 x 28mm
Shaft diameter: 3.0mm
Shaft length: 10mm
Voltage: 14.8V
Weight: 97g
Output Power: 520w
Max current(<60s): 35A
RPM/V: 3800
Thrust: 1100g(38.8oz.)
Recommended model weight: 600-800g
Recommended model fans: 64mm Fans
Mounting Hole Bolt Circle: 18mm
Mtg. Hole Number & Size: 4 x M2
http://img834.imageshack.us/img834/8191/hk2836edfoutrunner3800k.jpg
#3 Useril este offline   R3dD3vil
  • Postari: 1076
  • Interests:Avioane, elicoptere si orice zboara
Postat 11 November 2012 - 06:23 PM
salut, pozitia 8
Max. Current : 22A
poate fata pe un auto 1:10 de 3,5 kile?
MultiRotor: MultiWii Quad
Tx: Turnigy 9X
Imagine postata
#4 Useril este offline   draude80
  • Postari: 273
  • Inregistrat: 25-August 09
  • Interests:Aero, FPV
Postat 11 November 2012 - 06:42 PM
Salut !
Rog sa rezervi pt mine pozitia 1 si 2.
multumesc,
#5 Useril este offline   alexvid
  • Postari: 1494
Postat 11 November 2012 - 06:47 PM
Vezi postareaR3dD3vil, la 11 November 2012 - 06:23 PM, a spus:
salut, pozitia 8 poate fata pe un auto 1:10 de 3,5 kile?
Sincer nu stiu. Nu prea ma pricep la auto, dar la cum am vazut ca arata motoarele de auto, nu prea cred. Pare mult subdimensionat pentru asa ceva.
Aceasta postare a fost editata de alexvid: 11 November 2012 - 06:52 PM
#6 Useril este offline   alexvid
  • Postari: 1494
Postat 11 November 2012 - 06:50 PM
Vezi postareadraude80, la 11 November 2012 - 06:42 PM, a spus:
Salut !
multumesc,
Salut, pozitia 2 este data. daca ti se potriveste, mai am un c2830 750KV cu regulator 30A rcsmart SH.
Regulatorul are doar setari de frana si lipo/nimh tot 45RON.
Pozitia 1, este inca disponibila.
#7 Useril este offline   draude80
  • Postari: 273
Postat 11 November 2012 - 06:59 PM
Sal !!
Pozitia 1 si regulatorul cu EMAX CF2822
este ok??
#8 Useril este offline   oachidori
  • F22 Raptor Fan
  • Postari: 2396
  • Inregistrat: 05-August 09
Postat 11 November 2012 - 07:18 PM
Salut Mircea,
imi trebuie mie pozitia 9.Te sun eu maine seara ca suntem vecini. :drinks:
Olivian Diaconescu
Radio:
Multiplex Royal Pro 16 2.4GHz
Aero:
FREEWING - F22 Xicoy X45 Jet
ROBBE - Mistral 2.0m
F22 depron
AERONAUT - Triple RES 2.0m
Auto:
TRAXXAS - E Revo 1/16
ARRMA - Typhon 6S
#9 Useril este offline   marianmoto
  • Postari: 117
  • Inregistrat: 04-February 10
Postat 11 November 2012 - 07:36 PM
sal ma intereseaza pozitia 7 si 10.
#10 Useril este offline   marianmoto
  • Postari: 117
Postat 11 November 2012 - 07:39 PM
si 3-5 si 8.astept raspuns.
#11 Useril este offline   alexvid
  • Postari: 1494
Postat 11 November 2012 - 08:37 PM
mai sunt disponibile doar pozitiile 5,11,12
Sper sa nu se considere UP.
Aceasta postare a fost editata de alexvid: 11 November 2012 - 08:39 PM
#12 Useril este offline   Sebiak
  • Postari: 16
Postat 11 November 2012 - 09:16 PM
Buna.
Ai PM!
#13 Useril este offline   Travel Air
  • Postari: 1225
  • Interests:Zbor
Postat 16 November 2012 - 11:29 AM
Salutare.
Vreau eu motorul de la pozitia 5.
Bogdan Floria
str. Dragos Voda, Nr. 42
Vaslui, jud. Vaslui
0757110983
Daca ai putea sa trimiti cu posta romana ar fi perfect.
Aceasta postare a fost editata de Travel Air: 16 November 2012 - 11:31 AM
Bogdan Floria
bogdan.floria@aeromodelism.ro
bogdanfloria@gmail.com
0757110983
#14 Useril este offline   alexvid
  • Postari: 1494
Postat 17 November 2012 - 02:40 PM
Salut din cele clopot, nu mai am decat pozitia 6.
Nu pot sa trimit decat cu fan courier.
Daca esti de acord, pot sa trimit, dar curierul e mai mult ca motorul in sine.
