Planorul este impecabil, in cutia originala, cu toate accesoriile originale, este practic RTF, nu-i mai trebuie decat receptor. Are f. putine zboruri si toate aterizarile normale. Este un planor excelent, atat acrobat cat si termic sau pentru filmari aeriene. Motorul, regulatorul si bateria sunt chiar excelente si planorul urca la verticala. Timpul de zbor este dat la 40 min si poate fi real... totusi eu am zburat aprox. 30 min. Din linkul producatorului (de mai jos) este varianta cu regulator mare si flapsuri.
http://www.art-tech....p?ArticleID=261
Specificatii:
★ Wing span: 2500mm
★ Length: 1500mm
★ Wing Area: 55 dm2
★ Wing loading: 35g/dm2
★ Weight: 1900g/67 oz
★ Thrust rate: 1.26
★ Time for staying in the sky: >40mins
★ Motor: Out runner brushless motor A3720
★ Battery: Li-Po battery 14.8V,2500mAh
★ ESC: 60A
Feature:
★ Being with laminar flow airfoil and 2.5m wingspan.
★ Made of EPO material and has good capacity against impulsive
★ Configured with the powerful brushless motor and can climb vertically at high speed. Bring surprising flight joy by its stable flight and the flexible operation.
★ Easy to assemble and transport.
★ Configured with 2.4G radio,no frequency interference.
★ Suitable not only for intermediate flyers, but also for advanced flyers.
Number of downloads: 417 -
Number of downloads: 428 -
Number of downloads: 523 -
