Modelism - RHC Forum: Vand mai multe modele si piese. - Modelism - RHC Forum
#1 Useril este offline   AlexZeu1997
  • Postari: 142
  • Inregistrat: 06-November 11
  • Interests:aeromodele
Postat 14 September 2012 - 06:45 AM
1.Aeromodel Easy Star anv.1300mm --->75 lei
2.Aeromodel Wing Dragon anv.1120mm --->75 lei
3.Aeromodel Easy Glider anv.1800mm cam obosit --->50 lei
4.Aeromodel Cessna 182 anv.1000mm cam praf --->25 lei
5.Aeromodel Cessna 182 500 class anv.1300mm cam praf+inca unul tot praf --->40 lei amandoua
6.Aeromodel Piaget 3d --->100lei
7.Altimetru 4gr --->100 lei
8.Motor Inrunner trage 1000gr --->50 lei
9.Motor Turnigy trage 1300gr dar se incalzeste cam tare --->35 lei
10.Elice APC 12*6 putin ciobita intr-un colt --->5 lei
11.Elice APC 7*3 --->3 lei
12.Servo HEXTRONIK HXT 900 3 bucati --->12 lei/buc
13.Servo Art-Tech AS100 2 bucati --->10 lei/buc
14.Radiocomanda E-FLY 100B 4 canale 2.4 GHz, bulk --->80 lei
15.Radiocomanda E-FLY ETC62, 6 canale, 2.4GHz computerizata --->180 lei
16.Acumulator Lipo 7.4 v(2s) 1000mah(15 cicluri) --->30 lei
17.Acumulator Lipo 7.4 v(2s) 800mah (10 cicluri) --->30 lei
18.Acumulator Lipo 7.4 v(2s) 850mah (15 clcluri) --->25 lei
19.Acumulator Lipo 7.4 v(2s) 1300 mah (30 clicluri) --->25 lei
20.Acumulator Lipo 7.4 v(2s) 1300 mah (20 clicluri) --->30 lei
21.Acumulator Lipo 11.1 v(3s) 1000mah (10 cicluri) --->40
22.Acumulator Lipo 3.7(1s) 150mah(30 ciluri) --->10 lei
23.Acumulator Lipo 7.4 v(2s) 1800mah (10 cicluri) --->40 lei
24.Acumulator Lipo 11.1 v(3s) 1300mah (40 cicluri)--->30 lei
Pe parcurs o sa mai adaug accesori.
Am uitat sa specific numarul meu de telefon 0740640741
#2 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 06:53 AM
Fisier atasat  DSC01773.JPG (59.49K)
Preturile sunt usor negociabile!
Aceasta postare a fost editata de AlexZeu1997: 14 September 2012 - 06:55 AM
#3 Useril este offline   passion
  • Postari: 658
  • Inregistrat: 10-September 03
Postat 14 September 2012 - 06:59 AM
Salut, vreau eu pct.3,9,13.Adresa mea.
Multumesc!
Aceasta postare a fost editata de passion: 14 September 2012 - 06:59 AM
Nu ma cãuta!
#4 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 07:12 AM
Punctele 9 si 13 vandute.
#5 Useril este offline   ccatalin
  • Postari: 241
  • Inregistrat: 10-May 11
Postat 14 September 2012 - 07:45 AM
interesat de pct 3 si 5 ..da-mi PM ca ai casuta plina
ZMR 250
Easystar/Bixler
Arcus Airy
Radjet 800
Zagi 1000/1200
#6 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
  • Inregistrat: 09-June 07
Postat 14 September 2012 - 03:55 PM
Pune o poza cu punctul 1.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#7 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 05:22 PM
2 si 7 sau dat
#8 Useril este offline   abdesign
  • Postari: 79
  • Inregistrat: 02-January 06
Postat 14 September 2012 - 07:16 PM
Sunt interesat de:
mai sunt valabile? sunt echipate cu ceva?
#9 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 07:18 PM
Vezi postareacasper20, la 14 September 2012 - 03:55 PM, a spus:
#10 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 08:13 PM
Continuare....
25.elice 11*7--->3lei
26.elice 7*6 --->3 lei
27.elice 6*3 --->3 lei
28.Acumulator Lipo 11.1 v(3s) 3 bucati (50 cilcuri fiecare) --->40 lei/buc
29.esc 33 amp --->40 lei
30.esc 25 amp --->30 lei
31.esc 20 amp am 3 bucati --->20 lei/buc
32.Servouri Pico am 3 bucati ca si noi --->23 lei/buc
33.Motor Turnigy trage 1400gr --->50 lei
34.Motor 2s trage 600 gr am 2 bucati --->30 lei/buc
35.Buzzer 3-8s --->15 lei
Poze cu celelalte accesori maine.
Punctul 2 este din nou valabil.
Aceasta postare a fost editata de AlexZeu1997: 14 September 2012 - 08:14 PM
#11 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 14 September 2012 - 08:30 PM
36.Acumulator Lipo 11.1 v(3s) 5000mah (40 cicluri) --->100 lei
37.Acumulator Lipo 11.1 v(3s) 2650mah (45 cicluri) --->40 lei
#12 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 15 September 2012 - 04:57 PM
Punctele 2,15,18,26,27,29,30,31. Au fost date.
Aceasta postare a fost editata de AlexZeu1997: 15 September 2012 - 04:58 PM
#13 Useril este offline   stelu82
  • Postari: 1073
  • Inregistrat: 06-January 12
Postat 15 September 2012 - 05:48 PM
ceva poze
#14 Useril este offline   Alinu
  • Postari: 6
  • Inregistrat: 13-September 12
  • Interests:Aeromodele
Postat 15 September 2012 - 08:46 PM
domnule stelu82 este o poza cu acel motor sub statia compiuterizata
#15 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 16 September 2012 - 06:18 AM
motorul acela sa dat!Adica punctul 33.
Aceasta postare a fost editata de AlexZeu1997: 16 September 2012 - 06:19 AM
#16 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 16 September 2012 - 06:34 AM
38.motor brushless turnigy cu urmatoarele specificatii:
Dimension: 35mm x 38mm, 53mm(with shaft)
Weight: 97g (kv1500) (not including connectors)
Diameter of shaft: 4mm
Length of front shaft: 18mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance
Voltage: 3S
Max current: 40A/20S
Prop: 10x5
Pull: 1850g
For 1400-1700g 3D airplane.
#17 Useril este offline   stelu82
  • Postari: 1073
Postat 16 September 2012 - 09:28 AM
Vezi postareaAlinu, la 15 September 2012 - 08:46 PM, a spus:
vad ca pe uni ii mananca limba
daca postai tu ai fi putut raspunde dar....
SCUZE OFTOPIC
#18 Useril este offline   stelu82
  • Postari: 1073
Postat 16 September 2012 - 09:30 AM
aici nu apare nici un 38 de ai am intrebat
#19 Useril este offline   AlexZeu1997
  • Postari: 142
Postat 18 September 2012 - 01:07 PM
Se retrag de la vanzare .
