Avionul vine echipat cu motor brushless cu urmatoarele specificatii:
High torque inrunner, excellent for running propellers without needing a gearbox.
The unique stator design creates a low current and high torque motor great for outrunner replacements and much more efficient than inrunners of the same size.
Dimension: 28mm x 56mm, 70mm(with shaft)
Weight: 131g (kv2600) (not including connectors)
Diameter of shaft:4mm
Length of front shaft:14mm
Lamination thickness: .2mm
Spec.
Battery: 3 Cell 11.1
RPM: 2600kv
Max current: 50A
No load current: 1.8A
Internal resistance: 20.72ohm
Data;
3S 11.1V
Prop: 6x4, 8x3.8
Max Current: 45A, 49A
Pull: 1100g, 1400g
Regulator brushless Turnigy Trust de 55A cu urmatoarele specificatii:
Turnigy® TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors.
The large heatsink and simple PCB layout make heat dissapation consistant, enabling the ESC to be run at its limit, without failure.
The ESC is program-card and transmitter programmable with clear and easy to understand instructions included.
Default factory settings are;
Brake: off
Battery: LiPo Auto Detect
Low Voltage: 3.2v (power down motor)
Spec.
Max Motor Current: 55A
Max BEC Current: 3A
BEC Voltage: 5.5v (Switching)
LiPo: 2~6S
NiMH:5~16cells
Weight: 53grams
Programming Options.
Battery Type
Forward/Reverse
Soft Start
LV Setting (Ignore, Reduce Power, Stop Motor)
Timing (Auto, Med, High)
Switching (8,16kHz)
Factory Restore
3 servouri Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g / 0.10sec pe eleroane si elevator :
Weight: 13.4g
Dimension: 22.8*12.2*28.5mm
Stall torque: 1.8kg/cm (4.8V) - 2.2kg/cm (6.0V)
Operating speed: 0.10sec/60degree(4.8v) - 0.08sec/60degree(6.0V)
Operating voltage: 4.8-6.0V
Temperature range: 0- 55deg
Servo Plug: JR (Fits JR and Futaba)
1 servo Turnigy TGY-9025MG Metal Gear Servo 1.8kg/11g/0.09 pe profundor:
Model: TGY-9025MG
Operating Voltage: 4.8V / 6.0V
Operating Current: 200mA / 250mA
Operating Speed: 0.10sec.60º/ 0.09sec.60º
Stall Torque: 1.5kg.cm /1.8kg.cm
Weight: 11g
Dead Band: ≤7uSec
Operating Travel: 60º +/- 10º
Potentiometer: indirect Drive
Ball bearing: Top Ball Bearing
Gear: Metal
Connector wire: 180mm 26AWG
Plug: JR/Universal
Operating Temperature Range: -20c+60c
1 bucata baterie turnigy 3s 2200mAh 20-30C , bateria este cam consumata, se incarca 1600mAh si ofera un timp de zbor de 10 minute
Constant Discharge: 20C
Peak Discharge (10sec): 30C
Pack Weight: 185g
Pack Size: 103 x 33 x 24mm
Charge Plug: JST-XH
Discharge Plug: XT60
Avionul mai este echipat si cu con de aluminiu si 2 elici 4,75x4,75
Avionul este modificat astfel incat in fuselaj are aprox 60 leduri SMD albe iar pe aripi alte 40 leduri rosi si 40 de leduri verzi ultrabright :drinks: .Ledurile se alimenteaza de la bateria avionului printr-o mufa.In total toate consuma 1,2A/h
Greutatea este de aprox 65 g in plus.
Avionul are cateva rupturi dar a fost lipit ca la carte si zboara foarte bine.
Valoarea la tot ar fi cam asa:
1. motor - 90 lei
2. regulator - 100 lei
3. servouri - 100 lei
4. baterie - 20 lei
5. fuselaj - 100 lei (doar ledurile au costat 75 lei ... sa nu mai punem munca ..)
Motorul si regulatorul si servourile sunt din primavara asta au 4 iesiri dintre care una la RR
Pretul meu 359 lei easy star cu eleroane complet motorizat si echipat mai trebuie o statie
Acest topic e inchis
