Modelism - RHC Forum: Messerschmitt ME 109-G - 1100 mm - Modelism - RHC Forum
#1 Useril este offline   dan1972
  • Postari: 1453
  • Inregistrat: 03-December 11
Postat 26 August 2012 - 03:51 PM
Vand Messerschmitt ME 109 G - PARKZONE-USA - 1105 mm -PNF aproape nou (a fost zburat de 4-5 ori).Cam asa zboara...:drinks:
Anvergura - 1105 mm
Lungime - 1000 mm
Greutate - 1000 gr
S.Portanta - 15,8 dmp
Sarc. Alara - 63,3 gr/dmp
Pachetul contine:
- Motor E-Max - 3548-720 kv - 420w
- ESC E-Flite - 30A (+ manual de programare)
- Servo-uri Parkzone Digitale 9gr - 4 buc
- Elici 11x8 tripala - 2 buc (au costat 5,90 euro/buc)
- Kit instalare flapsuri
- Instructiuni de montaj/utilizare
*** Toate componentele sant cele originale!
Pret - 600 RON (fix)
A costat - 179 usd + transportul
Tel.: - 0746/322.021
Zboara excelent!!! Este f. stabil !!! Poate plana lin la aterizari, dar poate face si acrobatie. Urca fara probleme la verticala, nelimitat!
Il vand pt. a putea demara alt proiect aero
Messersmitt ME 109 G - Parkzone - 1100mm
Magister-MULTIPLEX - 1630mm
Ryan NY-P - 1600mm
Piper Cub J3- 2310 mm - 28cc benzina
Diamond 1800mm
P40-Warhawk mini (645mm)
W-Fly-Flaspeed 2,4 GHz
#2 Useril este offline   dan1972
  • Postari: 1453
Postat 26 August 2012 - 03:53 PM
Poze:
Ryan NY-P - 1600mm
Diamond 1800mm
#3 Useril este offline   dan1972
  • Postari: 1453
Postat 26 August 2012 - 03:54 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#4 Useril este offline   dan1972
  • Postari: 1453
Postat 26 August 2012 - 03:56 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#5 Useril este offline   dan1972
  • Postari: 1453
Postat 26 August 2012 - 03:58 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#6 Useril este offline   dan1972
  • Postari: 1453
Postat 26 August 2012 - 04:05 PM
Decolare...
Ryan NY-P - 1600mm
Diamond 1800mm
#7 Useril este offline   tantar
  • Postari: 2748
  • Inregistrat: 01-November 08
Postat 26 August 2012 - 07:48 PM
Mare pacat ca il dai .... frumoasa pasare .
Trex 700 V BAR
FMS P-51 D MUSTANG 1700 mm
JU- 87 STUKA 1920 mm
A-10 Freewing 1700 mm EDF
FMS F 4U CORSAIR 1700 mm
FW 190 HYPE
Futaba T-8FG x 2
#8 Useril este offline   dan1972
  • Postari: 1453
Postat 27 August 2012 - 09:36 PM
Vezi postareatantar, la 26 August 2012 - 07:48 PM, a spus:
Merci...dar nu am ce face in acest moment! Poate pe viitor...
...Sau poate vine altul mai mare...de 1600 mm :good: Stii ca la mine se nasc diversi pasaroi... B)
Ryan NY-P - 1600mm
Diamond 1800mm
#9 Useril este offline   dan1972
  • Postari: 1453
Postat 01 September 2012 - 12:41 AM
UP!
Ryan NY-P - 1600mm
Diamond 1800mm
#10 Useril este offline   dan1972
  • Postari: 1453
Postat 07 September 2012 - 02:38 PM
UP!
Ryan NY-P - 1600mm
Diamond 1800mm
#11 Useril este offline   dan1972
  • Postari: 1453
Postat 16 September 2012 - 11:24 PM
UP!
Ryan NY-P - 1600mm
Diamond 1800mm
#12 Useril este offline   dan1972
  • Postari: 1453
Postat 24 September 2012 - 03:08 AM
Valabil !
Ryan NY-P - 1600mm
Diamond 1800mm
#13 Useril este offline   dan1972
  • Postari: 1453
Postat 01 October 2012 - 08:10 AM
...Ieri am profitat de intalnirea zburatorilor din Braila-Galati si am scos si Messerschmitt-ul la zbor...deja avea praf pe el... :unsure: ...
Cu toate ca a fost o zi cu vant destul de puternic, avionul a zburat fara nici cea mai mica problema...cu figuri acrobatice... aterizari line, ca la carte...spre uimirea tuturor...Zboara superb!!! M-a uns pe suflet!!! :pardon:
Ryan NY-P - 1600mm
Diamond 1800mm
#14 Useril este offline   dan1972
  • Postari: 1453
Postat 04 October 2012 - 09:56 PM
O poza de la ultimul zbor.
Ryan NY-P - 1600mm
Diamond 1800mm
#15 Useril este offline   dan1972
  • Postari: 1453
Postat 22 October 2012 - 06:18 PM
UP!
Ryan NY-P - 1600mm
Diamond 1800mm
#16 Useril este offline   dan1972
  • Postari: 1453
Postat 26 October 2012 - 05:49 PM
Valabil! 0746/322.021
Ryan NY-P - 1600mm
Diamond 1800mm
#17 Useril este offline   dan1972
  • Postari: 1453
Postat 19 November 2012 - 07:11 PM
Acum are si flapsuri, care pot fi setate sa se deschida de la 0 la 80 grd. Le-am facut diferite de ce a prevazut constructorul, pt. a pastra aspectul avionului real...Sant doua randuri de flapsuri care se deschid diferit. Pot fi folosite atat cu rol de flaps, cat si cu rol de frana aerodinamica.
Am preferat sa las eleroanele cu 25% mai mari decat indica fabricantul si sa le extind spre centrul aripii (exact ca la avionul 1:1) pt. a nu diminua prea mult efectul eleroanelor...
Zborul...s-a stabilizat f. mult atunci cand se zboara cu flapsurile deschise pe prima pozitie (15 grd)...Practic dispar reactiile nedorite ale unui avion cu aripa jos...Zboara ca un trainer cu aripa sus...
...Cu flapsurile deschise la maxim, viteza se micsoreaza mult, dar fara sa scada portantza...In aceasta pozitie, avionul vine f. incet la aterizare si aterizeaza extrem de lin...Poate fi coborat pe o panta abrupta, fara sa prinda viteza prea mare si fara sa aiba un zbor instabil!!!
...Ce este cel mai curios, e faptul ca la acest tip de avion, flapsurile nu au efect de ridicare a botului, ca la avioanele cu aripa sus (parasol) indiferent cat sant deschise...Doar se simte ca avionul capata mai multa portantza, zborul se stabilizeaza mult si scade putin viteza...Se poate zbura cu acceleratia la maxim si cu flapsurile deschise (lucru imposibil la avioanele cu aripa sus)...
...Efectul eleroanelor este f. bun (nu s-a inrautatit)...Avionul executa roll-uri destul de rapid si reactioneaza f. prompt la comanda eleroanelor.
...Cu Flapsurile deschise pe prima pozitie, spatiul de decolare s-a scurtat cu 50% (decoleaza in 3-4 m) si au disparut toate reactiile nedorite pe care le au toate warbirdurile (angajare stanga datorita cuplului motorului...decolari lungi in viteza, datorita suprafetzei portante mici...etc...)
...Operatia aceasta este o reusita...Rezultatele sant excelente!!! Nu ma asteptam!!!
Pretul creste la 650 RON, datorita componentelor adaugate (servo-uri...tije...butoiase...echii...cablu Y...etc...etc...etc)
Ryan NY-P - 1600mm
Diamond 1800mm
#18 Useril este offline   dan1972
  • Postari: 1453
Postat 19 November 2012 - 07:12 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#19 Useril este offline   dan1972
  • Postari: 1453
Postat 19 November 2012 - 07:15 PM
...Urmeaza si retract-urile...cat de curand... B)
Ryan NY-P - 1600mm
Diamond 1800mm
#20 Useril este offline   dan1972
  • Postari: 1453
Postat 06 December 2012 - 11:01 PM
UP!
Ryan NY-P - 1600mm
Diamond 1800mm
#21 Useril este offline   dan1972
  • Postari: 1453
Postat 18 January 2013 - 03:36 PM
Acum are si retract-uri... B)
A fost un volum enorm de munca pt. a le monta si pt. a le face sa arate ca la avionul real, dar a meritat...In final a iesit cum trebuie!
Cateva poze...
Ryan NY-P - 1600mm
Diamond 1800mm
#22 Useril este offline   dan1972
  • Postari: 1453
Postat 18 January 2013 - 03:38 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#23 Useril este offline   dan1972
  • Postari: 1453
Postat 18 January 2013 - 03:40 PM
Ryan NY-P - 1600mm
Diamond 1800mm
#24 Useril este offline   dan1972
  • Postari: 1453
Postat 18 January 2013 - 03:48 PM
In poze "pantalonii" trenului de aterizare nu sant lipiti perfect de intradosul aripilor, pt. ca inca nu alimentasem servomecanismele retract-urilor (retract-urile nu erau zavorate...)...In realitate se inchid perfect (pantalonii trenului de aterizare stau lipiti complet de aripi...
...Am specificat asta ca sa nu creada cineva ca sant facuti de mantuiala...
Curaj! Grabiti-va pana nu creste pretul !!! In pret se adauga si un con de elice pt. elice cu 2 pale.
Pretul este de 650 RON.
Ryan NY-P - 1600mm
Diamond 1800mm
