aferent motoarelor vind si 10 perechi de elici aferente lor st +dr 10x 3.8 pretul este de 150 roni
caracteristici motoare
motor ST3512Brushless
ST1038 Propeller
ST3512 Performance parameter:
KV:920rpm/V
Shaft Diameter:4mm
Weight:80g
No_load Current :0.7A/10V
Max Current:19A /11.1V
Max Tension:1150g(ST1038?)
Max Power:210W
Battery : 3S Li-poly
Rotor:10x3.8
Screw:M3.00mm
Installation dimensions :16mm and 19mm
cum zboara cu motoarele din dotare
cum se vede de jos
Aceasta postare a fost editata de adi elicopter gl: 05 August 2012 - 09:07 PM
