Elicopterul are:
Motor : Turnigy Typhoon 450H 2215H Heli Motor 3550kv : http://www.hobbyking...?idProduct=9021
servo coada : D922MG Digital Metal Gear Servo 1.8kg : http://www.hobbyking...idProduct=10976
servo swash : HXT900
ESC : TowerPro H40A
Pale : 325mm Fiber Glass Main Blades
Gyro : HobbyKing GA-250 MINI-MEMS Gyro
Upgrade-uri:
- HK450V2 Tail Holder : http://www.hobbyking...idProduct=11491
- HK450V2 Horizontal Fin Band : http://www.hobbyking...idProduct=11498
- HK450V2 Metal Landing Skid : http://www.hobbyking...idProduct=11500
- HK450 carbon tail boom : http://www.hobbyking...idProduct=17126
- HK450V2 Tail Servo Holder : http://www.hobbyking...idProduct=11496
- HK450V2 Tail Drive Gear Set: http://www.hobbyking...idProduct=11481
- HK450V2 Carbon Fibre & Metal Tail Support Rod : http://www.hobbyking...idProduct=11505
- Fiberglass canopy
Piese de schimb:
- Main Rotor Blade Assembly Tool (5mm) : http://www.hobbyking...idProduct=11041
- R/C Helicopter Pitch Gauge : http://www.hobbyking...?idProduct=9653
- HK450 Tail Holder (plastic)
- HK450V2 Stabilizer Bar : http://www.hobbyking...idProduct=11477
- HK450V2 Tail Blade : http://www.hobbyking...idProduct=11495
- HK450V2 Plastic Horizontal / Vertical Tail Fin : http://www.hobbyking...idProduct=11494
- HK450V2 Plastic Vertical Tail Fin
- HK450V2 Stabilizer Blade : http://www.hobbyking...idProduct=11478
- 1 x HK450V2 Main Shaft
- Plastic Tail Servo Holder
- HK450V2 Timing Belt : http://www.hobbyking...idProduct=11517
- HK450V2 Feathering Shaft Set (2 set x 3 shaft) : http://www.hobbyking...idProduct=11515
- Plastic Tail Drive Gear Set
- 325mm Wood Main Blades (Baked finish) : http://www.hobbyking...idProduct=14011
- HK-450 Metal Tail Rotor Shaft upgrade version (HS1203) : http://www.hobbyking...idProduct=10797
- HK450V2 Base Plate : http://www.hobbyking...idProduct=11490
- Heli Canopy Rubber Grommet Small (4pcs/bag) : http://www.hobbyking...idProduct=13123
- 5 x Main Drive Gear
- Original canopy
practic tot ce se vede in poza.
Nu dau nimic separat, doar totul impreuna. Am nevoie de bani pentru alt proiect.
Receptorul din poza nu se vinde. A ramas din greseala la photo shooting.
Pret 600 ron.
Acest topic e inchis
