Modelism - RHC Forum: Controller multicopter Crius Lite - Modelism - RHC Forum
Controller multicopter Crius Lite multiwii 328 ITG3205 ADXL345
#1 Useril este offline   renatoa
  • Postari: 19177
Postat 08 June 2012 - 11:06 AM
Nezburat.
Se poate da cu interfata USB (8$) sau fara.
Accept si schimburi in domeniul multicopter, cum ar fi 4 ESC-uri, ne intelegem la pret.
With the same program for the open source compared to KK or ACM, MWC's more stable flight performance, flight skills required for novice lower debugging process more intuitive. Dedicated MWC GUI program can easily observe the PID parameters, flight control signal input / output status, sensor / switch-state, as well as aircraft attitude and heading sensor signal state of each group, sufficient for the initial configuration of the aircraft easier.
MultiWii Lite lightweight version supports the following aircraft models:
GIMBAL -------- PTZ stabilizer independent (non-flight control purposes)
BICOPTER ------ 2-axis aircraft Avatar
Tricopter ----- Y3 (Y-type 3-axis)
QUADP --------- 4-axis + classic mode
QUADX --------- 4-axis × mode
Y4 ------------ Y-type four-axis
Y6 ------------ Y-type 6-axis
HEX6 ---------- 6 axis + mode
HEX6X --------- 6-axis × mode
FLYING WING --- flying wing with a (non-multi-axis machine, the program is in testing phase).
Tool to connect the computer via FTDI, flight mode can be easily converted at any time.
MWC MultiWii Lite lightweight version of the hardware configuration:
· ATMEGA328P microcontroller
· ITG3205 three-axis digital gyroscope
· ADXL345 three-axis acceleration sensor
http://www.goodluckb...oard-quadx.html
Aceasta postare a fost editata de renatoa: 08 June 2012 - 11:08 AM
#2 Useril este offline   cristilo
  • Postari: 364
  • Inregistrat: 14-January 12
Postat 08 June 2012 - 11:40 AM
interesat da-mi te rog un PM cu pretul final + interfata USB. Merci.
#3 Useril este offline   R3dD3vil
  • Postari: 1076
  • Interests:Avioane, elicoptere si orice zboara
Postat 08 June 2012 - 01:33 PM
interfata aia usb este compatibila si cu turnigy 9x si kkboard? adica este usbasp?
MultiRotor: MultiWii Quad
Tx: Turnigy 9X
Imagine postata
  • Postari: 19177
Postat 08 June 2012 - 01:51 PM
Nu, e FTDI
Dar am usbasp disponibil, pret HK + posta in tara
  • Postari: 19177
Postat 08 June 2012 - 03:30 PM
Vandut
